Question about Behringer EUROPOWER EP2500 Amplifier
CHANEL 1 NOT WORKING
IF I GET A DIAGRAM I CAN FIX MY EP2500 CAN U FURNISH ME WITH ONE?
  • 1 more comment
  • gaudios Sep 30, 2008
    It powers up runs perfectly for 2 minutes, then starts to break up on channel 1 all the o/p transistors seem ok, all voltage lines are giving same levels as channel 2 on the meter all components seem as expected, 1 diode near the thermistor on heatsink (thats what i think it is) measures ok when off but seems s/c when powered up! Any ideas.
  • ronhouston Oct 17, 2008
    my channel 1 is breaking up after warming up.. and nobody in town will touch it because its a beringer and documentation is imposible to find... i need a diagram so i can fix the problem. if i cant find a diagram or cant get this repaired i will never purchace another beringer product and i will be dumping my beringer mixers and other equipment for other supported brands. ron houston661 330 5142
  • widi834 Mar 04, 2009
    I Have Ch 2 Problem,Ch2 No Working/ Protect
  • 790 Answers
Hi
i can teach you if you are a qualified technician!?
Thanks!
Posted on Sep 22, 2008
IF U R WILLING TO HELP ME PLEASE SEND THE DIAGRAM SO IF I ENCOUNTER ANY OTHER PROBLEMS I WILL NOT HAVE TO JOURNEY BACK TO THIS INTERNET CAFE
TO EMAIL U ,SO PLEASE THE DIAGRAM WILL SOLVE ALL MY PROBLEMS . THANK YOU PLEASEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE.
My Behringer PMP1280S INPUT Chanel 1 is no longer working, after pulling out the mic XLR plug whilst the amp was still turned on.
You should be able to unplug a mic from the xlr input with the unit on with no problem.
I beleive the problem is that the xlr input jack has one or more legs broken off the board. If you dsassemble the board and resolder the three legs to the board you'll probably fix the problem.
Dec 01, 2015 | Behringer Music
Europower ep2500 amp the protection light is on ,on Chanel 2 ,channel 1 is ok orange.
Maybe there is DC on the speaker Outputs which activates protection circuit. Could be caused by broken power transitors. This is what I Would try first
Nov 30, 2013 | Audio Players & Recorders
Audio input line
Behringer Power Amps has the input lines on the back, it has either XLR balanced and 1/4 unbalanced inputs, now what are you trying to ask?
Oct 11, 2013 | Behringer EUROPOWER EP2500 Amplifier
I have EP2500 amp i want to use it to push 6 tops, what should i switch it to? one channel must push 3 tops and the other as well pushing 3 tops.
OK, you can use ep2500 amp to power 3 tops each,But the only challenge is that you are about to over load your amplifier. might get hot too fast .
You can use a cooling system to make it not too hot..It also depends on how the event your using it for...Using 3 EP2500 amplifier to drive three 6 top, using two top for each amplifier. Just a suggestion.
Using 2 amplifier, you will need to drive on one channel to drive 2 tops, and 1 top for the other channel.
That will do. But make sure you turn on the volume of the amplifier to the max volume ,so that it will be able to work properly for your tops...
Mar 31, 2011 | Behringer EUROPOWER EP2500 Amplifier
Red light on permanently one 1 channel, that channel just buzzes
on beringer europower ep2500 if both clips lights is on chane d9 d10 d11 d12 and the two 220uf caps for the +15 and -15 voltage supply for the op-amps it a common fault alvan dawkins
Oct 24, 2009 | Behringer EUROPOWER EP2500 Amplifier
During scheduled recording for 1 1/2 hours, chanell changes
I called panasonic and they sent me @ no charge a cd update that fixed my problem. I talked to
John @ 1-800-211-7262 ext 5070. He seemed very knowledgeable and spoke ENGLISH!
This cd may fix other problems for this model.
Dec 26, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Unit behringer xenyx 1204 fx does not work
i'm trying to find the circuit diagram for a xenyx 1204 mixer
Nov 08, 2008 | Behringer EUROPOWER EP2500 Amplifier
Behringer EUROPOWER EP2500 Amplifier Logo
264 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
