Question about Bunn NHB Coffee Maker
Does not heat water or dispense water and warmer light does not turn on i have tried multiple times to fill the resivor but still nothing. i have followed the instructions to the letter and to no avail i still cannot get coffee!!!
  • 147 Answers
There may be a thermal cut-off switch inside that has failed. I've by-passed the switch myself, but don't recommend it. Another option is to replace the cut-off switch.
Posted on Sep 19, 2008
No steam is coming out?
Try salt in the water, booklet in mine recomends salt to create steam, but don't add too much or you'll end up with a mini giser!!!
Hope this helps, if not, it's possible that the heating element is bad. Try the salt, then turn on for 1/2 hour or so, remove the cartridge from the water resivore and slowly stick a finger in to see if the water is hot or cold...
Apr 14, 2013 | Vicks Warm Mist V745A 1 Gallon Humidifier
Our brand new keurig mini plus wont heat or dispense water
I had the same problem with my Mini ! I also had this problem with my last Mini which was given to me and I tossed out. So I replaced with the new one which just went on the fritz. Called Keurig who were very helpful and told me to descale, but I explained the machine is almost new. So I prodded them for what else could cause the problem and its water that is too cold.
Turns out the problem is that I was using very cold water and the machine can sense the water is cold and will not heat. It does not heat so it wont damage the heating element. I was using 40 degree water from the fridge.
My symptoms were: I would fill it, that the blue light would flash, I would push the button, then the red light would flash and then nothing it would shut off after a while. Now with not so freezing water it works fine!
Hope this helps as I threw out a good machine because the water was too cold!
Jan 22, 2013 | Keurig Mini B31 Plus Red Coffee Maker
Giaggia Brera descaling problem
been talking to Gaggia (Philips) and they told me that with the newer Breras, you need to ill the water tank, put the machine into standby, then press the long and short cup buttons together for 6 seconds. This will start an auto descale programme (that they didn't mention in my manual!). A small amount of water will be dispensed through the coffee nozzles, then it will stop and the warning triangle and the prime warning light will come on. Place a large container under the panarello, then turn the knob to the right to dispense water. It will dispense about 50 - 100 mls (cold) water, then stop for about a minute. Just leave it and eventually it will empty the tank. Refill it and start again, but it will stop after a few seconds. Turn the knob back to central position, then it will dispense another small amount of water from the coffee nozzles, then stop with warning lights again. Turn the knob back right to dispense water, if it stops because of empty tank, just refill it. Eventually, the machine will stop and go to standby. Turn the knob back to the centre, refill tank yet again and the machine will start normally WITHOUT that descale warning light. HOORAY !!
Jan 22, 2013 | Coffee Makers & Espresso Machines
Fabric conditioner not going down
Fabric conditioner does not always go down, maybe you have a blockage on soap drawer, This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Jun 03, 2012 | Whirlpool Washing Machines
Reservoir heats but won't dispense
If you are pouring water in the manual brew basin, then check the sprayhead holes, then the spray tube, those could be blocked. If using the auto brew, check the solenoid and or brew switch.
Apr 26, 2010 | Bunn 12 Cup Coffee Brewers with 3 Lower...
I have an old Kenmore 26 side by side that dispenses water and ice. At one point it stopped producing ice and dispensing water. I changed the inline filter and it worked perfectly. Happened again shortly...
It sounds like you need to replace your water inlet valve , it is a dual valve for ice and water in the door and they go out often , the solenoid is not opening anymore , it is located where you hook up the water line.
Let me know if you have any other questions.
Apr 10, 2009 | Whirlpool GD2SHGX Refrigerator
Air in water line how to bleed out
the frig ha a plastic resivor that has air in it
you can bleed the line by continuing to use the water dispenser and diverting it into a pitcher
you can make a transfer funnel etc out of tin foil should not take more than 2 containers ( 1 /2 gal each)
Dec 11, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Dishwasher not working
Nothing by the sound of it. The humming may mean the main pump is stuck. If you are able, remove the pump & turn the impellor by hand (or screwdriver) just to make sure its free moving. Put it back into machine & see what you get. Could also mean that the capacitor on the main pump (if it is a capacitor start motor) has failed.
Jul 19, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
Bunn NHB Coffee Maker Logo
205 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
