Question about Siemens 24 in. SE64A630GB Built-In Dishwasher
Siemens SF65660EU stops after 2-3minutes
I have al
little problem with my siemens dishwasher. After 2-3 minutes it stops working
and if I notice closer I hear a mmmm sound (may be motor blocked!) 2 seconds before it stops.
If i open the door water still at the botom , if I reset pump DOES drains the water.
I think the problem is that thw water does not start spraying!....
  • curlytips Oct 05, 2008
    I've got a Siemens SR 64. When switched on the water seems to bypass the inside of the machine. I can hear it start running, but if opened, there is none in the machine. It attempts to go through programme - but no water. Have checked pressure is OK and both spray heads are clean. I can see the inlet filter at side at back of cupboard, but it doesn't look as if it is a user-serviceable part.
  • 4 Answers
SOURCE: SIEMENS SE64630GB NOT TAKING IN WATER
I know sounds stupid, but I must ask: Are the water supply valves turned on? Is the water supply pressure good?
A pump usually isn't found on the inlet side. Most such appliances have sediment screens located in the water inlet connections. These will sometimes get blocked with sediment such as lime, for example. Otherwise, you may have a defective controller or defective solenoid. Most units have two solenoids (hot & cold). The solenoids are located at the water inlet hookup (the screen is usually a part of the solenoid). When the washer is started, a metallic click should be heard from the solenoids. Beyond checking the screens and water valves, a repairman should be called in, unless you're skilled with a voltmeter, electrical troubleshooting, and appliance disassembly.
BTW- is this a new installation or has the unit been in service for awhile?
Good luck.
Posted on Apr 13, 2008
SOURCE: Our Siemens dishwasher retains water and smells
I would check the bottom of the dishwasher to see if there are any bones, old food built up as some of these collection systems have a small disposer built into them.
If you find any food, it's probably that.
Also, you can make sure that the drain line is the proper length and high enough as this is a common problem. Do a good search on proper drain height for dishwasher.
You may run an empty load of dishes with a cup of bleach added to eliminate the odor as well. Bleach will kill any bacteria causing the smell. More than likely the drain hose wasn't installed correctly.
Posted on Sep 10, 2009
Krazytech
  • 725 Answers
SOURCE: Siemens hydro sensor dishwasher not draining
sounds like a drain pump ... you may have a damaged drain pump or something stuck in it.. turn off the power the the dishwasher... .remove toe panel and you can see the drain pump on the left ..you can remove plastic hose on the left to drain the dishwasher ...be sure to catch the water will come out ... you can remove drain pump press release tab and turning drain pump ...hope it helps
Posted on Sep 19, 2009
  • 115 Answers
SOURCE: How to extend the drain hose Siemens SL34A006UC/22 Dishwasher
get another hose same diamiter and two hose clamps and a splice nipple from hardware store, cut hose to lenght with some extra insert nipple into both hoses and clamp with hose clamps make sure you get them tight.. use a metal nipple as a plastic one may crack when you clamp hoses
Posted on Dec 13, 2009
  • 2501 Answers
SOURCE: lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Posted on Dec 14, 2009
Testimonial: "Thanks for a speedy and v helpful reply. Sounded obvious, but I hadn't checked the water inlet(which was calcified)just the jets on the arm itself! "
I have the E01 error code appearing on my Siemens dishwashers
(E:01 to E:30) A technical fault has probably occurred. Switch off appliances with the ON/OFF switch 1I. After a minute restart the appliance or 2l unplug for 1 minute restart.
Feb 01, 2018 | Siemens Dishwashers
Siemens dishwasher- start button is flashing but will not start. some water in bottom of dishwasher.
Did you try turning off the circuit breaker to it, waiting about 15 minutes and turning it back on?
If that doesn't do it, I would start by checking your drain pump.
Oct 24, 2014 | Siemens 24 in. SL84A305UC Built-in...
Error code E:14 Siemens Dishwasher - stops after 1 min of cycle
It might be helpful if you provide the full model number of the Siemens dishwasher. Most likely E14 error has something to do with water flow sensing. Check if your mains water pressure is ok (tap under sink is fully open). But can provide more details only if you can tell me the model number.
Apr 03, 2014 | Siemens Dishwashers
Siemens dishwasher has stopped taking in water red light on indicating this problem, I have checked water supply that's ok
Click this link for tips : Inlet valve
Check the voltage to the valve to confirm that the control panel is working,
Jan 24, 2013 | Siemens Dishwashers
I need a user manual, in English, for a Siemens AL 170 Duo phone.
Click HERE and select Siemens AL 180 from the drop down box.
AL 180 has few more functions.
The setup instruction should be the same as AL 170.
Jul 28, 2011 | Lands Phones
My siemens dishwasher model SL34A002UC/22, does not go to the dry cycle. It keeps washing and stays on the last minute and doesn't stop. Could it be the control board?
it is probably the timer , if u open it and pull off the plastic lining inside you can get at it just unplugs pay attention to the little peices and springs so u can put it back together ...
Apr 08, 2011 | Siemens Dishwashers
Why does my siemens dishwasher take 4 hours to finish running
Should only take 120 minutes to run a complete cycle. Your drain pump might not be expelling all the water.
Jul 18, 2010 | Siemens 24 in. SL34A006UC Built-in...
Siemens dishwasher stored for 6 months.Not working.
might be water valves stuck try giving entry pipes a tap. no too hard though
Jan 15, 2009 | Siemens 24 in. SE25T250 Free-Standing...
Siemens dishwasher
My siemense dishwasher (2 month old) stopped working
No matter which program I choose, after 1 min the program stops and I get "tap" symbol on the led display.
Instructions says it might be a problem with the water source but i checked and it is fine.
ideas?
Aug 17, 2008 | Siemens 24 in. SE25T250 Free-Standing...
Siemens 24 in. SE64A630GB Built-In Dishwasher Logo
148 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
