Question about Hampton Bay 73554 Antigua Ceiling Fan
Fan motor does not turn
Purchased from Home Depot. After hanging fan, it did not work. I put motor on my work bench. Have directly applied 110vac to black and white wires coming from fan motor and there is no movement. Help!
  • 126 Answers
FIRSTLY HOW MANY WIRES ARE COMING OUT THE FAN MOTOR AND WHAT COLOUR DO YOU GUYS USE AS LIVE AND NETURAL IN YOUR COUNTRY.
MOHAMED
Posted on Sep 19, 2008
Which direction do fan blades turn for cooling ?
Counter clockwise. If you purchased this at Home Depot or Lowes I can understand why you don't feel anything.
Aug 04, 2014 | Hunter 52" Ceiling Fan With Light And...
I have a" Nautilus Microtek
The motor is getting worn to the point it will stop soon. Remove the screen and you find the fan/motor directly behind it. You can try to put some machine oil on the motor shaft next to the motor housing. It may quieten it some. Recommend you replace it. Be sure you disconnect power before you do anything else. The motors and fan assembly is small in size and can be bought in Home Depot or an appliance store. If you need assistance in removing the motor/fan and installing new one, please let me know. Those brands are found at Home Depot.
Jun 18, 2011 | Kitchen Ranges
I just installed a Honeywell HE 360 Humidifier I purchased at Home depot. I replaced a Aprilaire model 110 . I have a 120v power duplex that is hot with the furnace blower motor, on so I assumed the sail...
Hello, in order to turn your humidifier on with the furnace the 120 volts coming from your humidifer you must hook it up to a step down transformer, then the transformer will provide 24 volts to you humidistat and solenoid valve. So you need a wire from the HUM on your control board to transformer primary side and a wire from neutral on the board to primary side of transformer. Then you need low voltage wire from secondary side of transformer to humidistat from humidistat to humidifier.
Feb 20, 2011 | Honeywell HE360A1027 Whole House...
Capacitor
The best place to find that is back at Home Depot...you may be able to match it up at a local electrical supply house, but usually they are a forgien made cap and are not readily accessible to the consumer in the states...
heatman101
Jul 24, 2010 | Hampton Bay 73554 Antigua Ceiling Fan
Ceiling fan problem
This fan company will warranty to 5 years. Sorry.
Jan 23, 2010 | Hampton Bay 24002 Ceiling Fan
Altura 68" fans will not operate on high speed.
I jtoo, ust bought The Altura (68" fan from home depot)
Home depot makes hampton bay through various chinese manufacturers.................
The fan ran slow on high speed, and barely ran on medium or low.
home depot gave me a number for their tech department that knew right away.....that the capacitor(s) are defective in many of the Altura fans.
They are sending the capacitors in 3 days to me no charge.
They are located under the fan ( remember the white square plastic plug you had to connect and the 2 wires for the optional light kit?.....)That plug is for the capacitors that everyone is having a problem with.
My guess is they are under rated for a fan that big and are sending better ones to those with problems.
Hope this helps.
The number is:
1-800-330-3267
Aug 18, 2009 | Hampton Bay 24002 Ceiling Fan
Where is a Hampton bay repair center in Mich. I need a the part hangs the celing fan to the Elc box.
Hampton bay is owned by home depot and to the best of my knowledge there are no repair centers for hampton bay fans. That bracket can be purchased (or ordered) from home depot. You could try searching "king of fans" online, they manufacture hampton bay fans for home depot.
Aug 10, 2009 | Dryers
I need a celing mounting bracket for 52in 5 blade encon ceiling fan. where can i get one the model # is 94b03-0395
I just uninstalled my 29 year old Encon flush mount fan light. The number on the base is E101004. It was a lighted base. The mount bracket is built into the base. It is the 4 prong and hook style the allows the motor to hang suspended while wiring and then swings up. There is a glass ring that is sandwiched between the base plate and decorative bottom.
It's the only usable part besides the 4 glass light covers. You can save this from the land fill if you haven't purchased a replacement fan.
May 08, 2009 | Encon Industries 78716 Contempra Ceiling...
Hampton Bay 73554 (56-ANT) from Home Depot
You need a new motor, are you still in warranty?
Oct 26, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Diamater of downrod
the fan must be tight fit to downrod.
Jan 19, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Hampton Bay 73554 Antigua Ceiling Fan Logo
126 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
