Mitsubishi WS-55511 55" Rear Projection Television Logo
Anonymous Posted on Sep 29, 2011
Ws-55511 green light changed caps. where is pico fuse located ?
Anonymous
Level 3:
Top Expert:
  • Mitsubishi Master 14,553 Answers
  • Posted on Sep 29, 2011
Anonymous
Mitsubishi Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718394
Points
48227
There are at least two pico fuses in the DM unit along with the caps; DM is large metal box on left as you look from behind.
Blinking green light that does not stop means problem is in DM unit that is not booting up.
If you have questions let me know.
SD TECH
I have a mitsubishi ws-55511 had power failure blinking light asked expert was told to un hook front control box which left tv working with remote control functions only. now we had a fower failure &...
I am the one here who first posted about taking the front keyboard out; if you replaced the caps in the DM unit and or pico fuses and still have the 'blinking green light of death" consider sending the board unit to PTS electronics.
You can get a quote from them for the repair and they have a 800 number; if you tried the usual things and it does not work go that way. Even with the factory service manual and schematics you will find it nearly impossible with the Unit in the set to take voltages and troubleshoot it.
DM unit in correctly working set should cause set to have blinking power light for about 70 seconds and then go out--it is DM booting up---if it does not stop blinking either a problem with DM or connections where it plugs into main board.
Let me know if you have questions or need help, I am here to help
SD TECH
I Have a mitsubishi WS-65857 and after doing the diagnostic i get teh 2,2 that some of the gurus have mentioned it is to resolve. I was wondering if you can tell me how to resolve this? Thank you very...
Check the two green pico fuses F9A04 and F9A05 on the "Center Board" if either of those two fuses are blown then convergence ICs are the reason its shutting down with a 22 error code.The pico fuses look just like resistors but dont have color bands and they will be bright green.
Power will not stay on
u have a problem with the convergen ic , and 2 pico fuse on power supply , this repair normally cost about $300
Held the menu and the input buttons, got 2,2 what is the fix
Thats the error for short protection shutdown. Check The two Bright green pico fuses on the center board for continuity F9A04 and F9A05 if they dont have continuity. The convergence ICs and both picos will need to be replaced.
1helpful
WS-55511 shuts off with in 1 secound when turned on.
See my reply to your last posting---The set needs The Stk-393-110 and whichever of the two pico fuses is blown replaced--I have instructions AND photos of what the fuses look like.
SD TECH
WS-55511 code 22.
Check these two green pico fuses F9A04 and F9A05 to see if they have continuity, if they dont have continuity the Convergence iC and those two picos will need replacement.
Ws 55511 convergence lines bowed down at bottom of screen
Check resistors might have cold solder joints are changed resistance values around replaced STK393-110
Pay attention to faded colored or fried resistors.
You can download service manual for WS-55511 from HERE to get schematics and technical info. (download all 3 parts of file and use WinRAR to extract file)
Good luck.
1helpful
Mitsubishi WS-55511 Convergence problem ? Unable to adjust. Picture is blurred with green shadows around images on screen
Convergence ICs and the two pico fuses need replacement. You can get replacements at the following link with instructions.
http://servicemanuals.vstore.ca/
Mitsubishi ws-48511 same green light problem
go to this site and leave them a email with your model number and they will email you the info you require.
Mitsubishi WS 55511
posible bad convergence with open pico fuse
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
