Question about Karcher 1750 psi Electric Pressure Washer
Instruction Manual Could I get a manual online for my Karcher 1750 electric washer ??
  • fslook Sep 19, 2008
    model K 3.68 MR
  • yadayada
    yadayada May 11, 2010
    Is 1750 the model number or the PSI rating?
  • 92 Answers
Dear fslook,
Try by entering in google KARCHER. Then find the home page. Find where to choose your country, and choose...INTERNATIONAL.
Then press MANUALS........then enter the model.
Now if you do not manage I give you some hints myself.
Always attach gun and water supply before switching on electricity. I advise that you start the machine without a lance first. See that when you close the gun the machine stops. If it does not stop, press quickly the gun again, and then switch off the electricity. If this happens you have a fault.
Now let us say the machine stops as it suppose to do, you can put on the lance. If you have a variable lance change from low to high by holding from the lance and not from the gun.
When you use chemical or detergent see that afterwards you rinse with pure water.
When you finish using machine, NEVER store with pressure in the system!!
Lubricate with silicon grease, connection of "gun hose" to machine.
Never use high pressure on car paint work or more important " not on car tyers"!!
Electricity and water do not go together. So inportant that you have a safety circuit breaker where to plug the machine.
If machine starts jerking when gun is closed or when gun is open, STOP instantly, and give to technician for servicing.
Never leave the machine on and with pressure when you are going somewhere. Always switch off and release pressure.
Regards,
MG.
Posted on Nov 05, 2008
    Top Expert:
  • Karcher Master
  • 77,514 Answers
Go to this web site for a PDF owners manual for your pressure washer.
http://www.karcherresidential.com/support/downloads/pdfs/usermanuals/5962-0870.pdf
Posted on Sep 19, 2008
Clogged filter karcher k 367
im sorry to say but your gonna have to take it apart and manually unclogg the filter
Jul 22, 2012 | Karcher K 367 M 1750 PSI 15 GPM Electric...
I need an instruction book for my Karcher pressure washer model no. K2.87m
The Karcher manual is available at this address.
Hope it helps!
http://www.karcheroutlet.co.uk/Manuals/Pressure%20Washers/K%202.87%205960-759.pdf
Feb 21, 2011 | Electric Eyeware Karcher Electric Pressure...
Karcher pressure washer hunts ~ off/on ~ when running. How do I fix?
HI Your machine wil start and stop if you have any external leaks when the machine is running at not pressing the trigger. Please start the machine and not pull the trigger and look form leaks. A common one is around the high pressure hose outlet and also the trigger.
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
Low pressure on the pressure washer
Most likely your "O" rings or seals have gotten hard and are leaking. Sorry I don't know your equipment well enough to tell you how to change them but you can most likely find the info at your manufactures web site.
May 26, 2010 | Karcher 1750 psi Electric Pressure Washer
My Karcher K9.8 electric pressure washer started
Not Simple.
I have the same Problem, the leak is from the seam of the Manifold or on the pressure side of the Pump and the hose housing. In my case there is a small crack in the seam of the Manifold Housing. A manufacturing defect.. A New Manifold Complete Replacement about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
May 18, 2010 | Karcher 1750 Psi Elec Pressure Washer
How to connect the cold water supply to K 3.65 Jubilee? In the instruction leaflet, figure J, number 1, 2, and 3 I seem unable to connect it. The above is a pressure washer.
Hi all you need is a 3/4 tap fitting from a diy store.
Maybe a hoselock 3/4 male and female fitting that will fit a standard 1/2" hosepipe. If struggling I can send you a link to the fitting on ebay but if you type in karcher tap connector you will see it by the seller vavcandwash.
Feb 14, 2010 | Karcher 1750 psi Electric Pressure Washer
Just started using my kb4040 and water i s leaking
Sounds like the water seals are bad. For Karcher parts go here: LINK
Jan 18, 2010 | Karcher 1750 psi Electric Pressure Washer
Karcher K2.19 Pressure Washer - Hose Coming Off
yeh this is what happen if you remove the yellow cover and you will see the metle u clip that is all that part holds on. you will needa new one from your local pressure washer supllier
Jan 17, 2010 | Karcher 1750 psi Electric Pressure Washer
LOST KARCHER INSTRUCTION BOOK, ARE INSTRUCTIONS ON LINE
Here is the offical link to manuals and warranty cards for the residential models of Karcher Pressure Washers
http://www.karcherresidential.com/us/Service/usermanuals.htm
Jan 22, 2009 | Karcher K2.26 Electric Power Washer
Karcher 1750 psi Electric Pressure Washer Logo
635 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
