Sharp Print Server
Problem for Sharp (AR-NB2N) (ARNB2N) Print Server
Router sends my printer invalid ip address
By chad648 on Sep 19, 2008
My router is sending my printer an invalid ip address so, even though it is connected to my computer via ethernet cable, the printer will not print anything that I send it. Can anyone help me?
I have the computers and the printer connected to a switcher, which is connected to a router and modem.
I am running Windows Vista 32 bit with service pack 1.
Comments:
Sep 19, 2008
- well its a linksys but I cant get the model number cause the router is locked up and I dont have the key! The printer is brother HL-4040CN. Which network settings would you like? I don't know a whole lot about this stuff but I can print off network settings on printer through the control panel.
Sep 19, 2008
- I was printing just the day before yesterday. It was yesterday that the thing just stopped working. After a short power outage we got kicked offline. I was able to get the internet working again by unplugging the router and modem and then plugging them back in, but the printer never came back online. I called the printer company AND the router company AND the company that makes the switcher we have in between them. None of them could figure out what the problem was :-(
ip: 169.254.165.249 (this is an invalid address but this is what it shows)
gateway: 0.0.0.0
From computer, ipv4: 169.254.127.228
default gateway field is BLANK
I tried but couldnt get the model number of the router to display, so sorry.
Sep 19, 2008
- The switcher is a Dynex DX-ESW8
I did notice from Googling my problem that Dynex products have been known to quit working after short power outages. Not sure why, but the lights are on and everything seems fine.
I don't know how to change the printer info on my PC to 169.254.165.249
Thanks.
Sep 22, 2008
- OK I connected the printer directly to my computer via ethernet and the ip address is now 169.254.165.249, same as before. subnet mask is 255.255.0.0 and ip gateway is 0.0.0.0.
I tried printing with the printer connected directly to my computer using ethernet and it still won't print. HOWEVER it will print if i connect it directly to my computer using USB. What does that mean?
Sep 22, 2008
- I just tried to post this message and got a error message from fixya that their server was overloaded and they couldn't post my comment. When I hit the back button everything I had typed was gone. Has anyone else had this problem with fixya? Anyways, here it all is again...
Sep 23, 2008
- Hello - I did eliminate the switch when I connected the printer directly to my computer, is that what you meant? Anyways, I really appreciate your help very much. The printer is working now. I unplugged the switch and plugged it back in and that got it working. The problem was somewhere in the switch, but it still doesn't make any sense to me.
Clarification Request
Posted by techbwoy on Sep 19, 2008
Hello Chad,
3 quick questions, Whats the model router, whats the model printer, also can you display the current network settings on the printer?
Best Solution
posted on Sep 19, 2008
Very Helpful)
techbwoy
Rank: Guide
Rating: 82%, 4 votes
ok,
print out the settins and write the ip address and gateway here.
Also on your computer..
click on start, then run
type 'cmd' without the quotes
then type
'ipconfig' without the quotes.
give us the (where it says ipv4) ip address and gateway info as well.
the gateway should be the address of your router.
if you open up your browser and type in the address http://x.x.x.x you will see the model number.
Also you never confirmed if you were printing before
Comments:
Sep 19, 2008
- based on this
gateway: 0.0.0.0
your computer and printer cannot see each other.
I am surprised that you are even connected to the net.
Please explain how you are connected now to the net.
You will have to reset the router by holding a pen or a pin in the reset socket for 30 seconds while you power on the router.
You can try to cheat and print by changing the printer information on your pc to 169.254.165.249 (i wouldnt recommend it though) but you could try this until you physically reset the router.
169.x.x.x represents the ip address devices get when they dont get a valid address from a router.
one quick question :
whats the model of the switcher ?
Sep 19, 2008
- ok,
the quickest way then is to add a new printer .
it will be same printer just a different address.
try using the cd. I will provide steps for a more advance option if you wish.
I will research your router and see if we can at least reset it.
failing that for smooth sailing i would recommend a new router, linksys,dlink,belkin are decent stable devices
Sep 19, 2008
- just to eliminate the switch
connect the pc directly to the router and see what your ip address is
Sep 22, 2008
- Your printer has 2 interfaces
ethernet and usb.
you can print to the printer via either method.
right now you are having a network issue so your ethernet communications wont work.
your computer's ethernet and the printer ethernet have to use the same 'gateway' to communicate.
since right now they dont know where the 'gate' is they cant talk to each other.
please try to eliminate the switch as suggested previously
Sep 23, 2008
- cool
it was probably in a loop.glad you are all sorted ..
Was this helpful?
Yes
No
Solution #2
posted on Oct 24, 2008
Not Rated)
mickspaceNET
Rank: Guru  Sharp Expert
Rating: 88%, 114 votes
Wow what a mess, this is hard to explain easily?
All network printers should be set to a Static IP address. (Fixed address). Somewhere in your Printers network settings you will find this, it should not be set to DHCP...
Your router is probably set to DHCP, which reassigns all address.
Your computer will send out a communication telling everyone on the network the PCs new address...
Your network printer will not do this.
In your PC in the Print Driver Properties you will see Ports which should have the IP address of your printer, which is a TCP/IP port.
Which will stay the same as when you installed the printer.
When your printer reboots and a new is address assigned if set to DHCP, the pc will still look for the old address, while the printer has a new address.
That is why the printer should have a static IP address assigned from within the machine
The gateway, subnet mask should reflect the same as your network. (The gateway does not have to be in there to work by the way, if you’re using it on the same router)
If you reinstalled the printer after your system rebooted, you probably have the printer installed more than once.
If you do not set the printer to a static IP address this probably will happen again when it is restarted or there is a loss of electricity.
Hooking a patch cable directly from your PC to Your printer will not work; it will work with a crossover cable and a few minor changes to the settings.
USB and Network use different protocols. TCP/IP uses a completely different addressing system.
I don’t think your problem was with your network, as much as it is with the Static address of the printer.
If it is printing for you now the easiest thing to do here to prevent future hassle...
print the network settings
go into your printers IP Networking settings and set the IP address and Subnet as what the printed page is ( I usually turn off DHCP, IPV4, IPV6, NetBIOS etc, and only have tcp/ip on, if your machine offers this?)
Good Luck
Was this helpful?
Yes
No
Popular Solutions for Sharp Print Server
Questions and Unsolved Problems for Sharp Print Server
Do you recommend Sharp (AR-NB2N) (ARNB2N) Print Server?
Answer
Answer
no puedo imprimir deja la impresion pendiente por hacer
Answer
dlink 1260 works on to wired pc's but my other 2 wireless pc's can't see the print server on the... (More)
Answer
I just installed a new photoconducter kit for my lexmark e450dn. The ip address was changed somehow... (More)
Answer
my printer is a transfer printer from a store to my home. tried to connect through the router but... (More)
Answer
my printer is connected to router in network but my computer cannot see it. my printer is a transfer... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Print Servers Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
