Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera Logo
Anonymous Posted on Sep 29, 2011
When i insert the memory card into my canon sd780 and it reads no pictures, when i know there are picture in the memory card, also when i insert the memory card in the computer it wont recognize it, what can i do? can i save the pictures i dont car eif the memory card ever works again!!
CameraR
Level 3:
  • Canon Master 4,738 Answers
  • Posted on Sep 30, 2011
CameraR
Canon Master
Level 3:
Answers
4738
Questions
Helped
1195961
Points
12483
Sounds like the card has become corrupted. Try the recovery software, along with the corrupted card procedures at this link. Of the software listed, try MiniTool first, and if that doesn't work, next try PhotoRec.
2answers
How do i delete pictures on sd780is canon
Go to menu, select pictures, run though menu for pictures tell you see delete
tip
How to Recover Lost Photos and Video from Canon PowerShot SD780 IS
<span> <span><img src="maggiena_8.jpg" /><br /></b></span>Canon PowerShot SD780 IS</b> may be the slimmest Digital ELPH Canon has ever created with dimensions 2.10" h x .70" w x 3.40" l, .26 pounds and 2.5 display size. It captivates the senses with bold saturated colors and a daringly original design that matches the intensity of Canon's most innovative camera technology.</span> <span><br /></span> <span><span> <p>Owning to its wonderful picture quality as well as high resolution, it becomes the first choice for many photographer lovers. One more reason that it turns out to be so popular is it supports various standard storage media like SD/SDHC, Multimedia Card, MMC Plus and HC MMC Plus memory cards</b>. images, Video and other multimedia file like songs can be saved there. Usually, keeping a backup of data like pictures and other multimedia files is recommended at the very beginning in case the data was lost by mistake in the process of using the camera. However, if you forgot to backup, you have to use a third party program to <a href="http://www.card-data-recovery.com/">retrieve Canon PowerShot SD780 IS data</a>.<br /> <p><br />Cases about losing data</b><br /> <ul> <li>1. When connect Canon PowerShot SD780 IS to your computer and being transferring vocation photos from SD card to computer, accidently your camera shut down due to low battery. After change the battery and restart camera again, you may encounter the error message "memory card error" that means the memory card is inaccessible.</li> <li>2. While reading data or writing data to SDHC card, "I/O device error" occurs and all photos and video miss.</li> <li>3. On the process of shot, message "memory card is full" pops up to you. However, after deleting some pictures, it shows the same result.</li> <li>4. Connect your SD card reader to computer, the window pops up with message "you have to format SD card before using it". After formatting SD card, all your pictures and video lose.</li></ul> <p>Resolution</b><br />If the above phenomena happen, don't panic, lost photos and video in Canon PowerShot SD780 IS are recoverable. First thing to do is stop using camera to shot for fear that the data was overwritten. For the first two cases, make sure the SDHC memory card is properly inserted. If it still can't be recognized, try to use a card reader to connect it to PC. Or else you have to format memory card and use effective photo recovery software to get back lost photos. For the last two cases, you should rely on <a href="http://www.card-data-recovery.com/">Canon PowerShot SD780 IS picture recovery</a> program. There are many effective Canon digital camera photo recovery program available in the internet, just choose the perfect one for your camera. <br /></b><br /><br /></span></span>
on Jul 20, 2011 • Cameras
After a computer crash I've lost the driver for Canon Powershot SD780. Where can I download it?
You can download Canon software from
www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd780_is
You might want to consider NOT using a driver. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
I hav lost canon ixus 100 is softwear cd want to install it on my new labtop
The IXUS 100 is called the SD780 in some parts of the world. You can download software for the SD780 from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd780_is#DriversAndSoftware
You might want to consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
1helpful
Unable to find a driver download for the Powershot SD780 IS. Have checked all the cords and ports.
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
How to transfer pictures from PowerShot SD780 IS to PC? Any specific software required?
Problem with SD card, Canon Ixus 100 IS
Could be the camera isn't seeing/reading the card properly.
I'd check the contacts on the card, and in the camera are clean, free of grease & dust.
Rather than do anything drastic, Have a look at the Canon website and or contact them, Details below.
http://www.canon.co.uk/Support/index.asp
2helpful
Canon PowerShot SD780 IS Vista Help PLEASE!
Use a card reader to download your pictures to a folder you create on your desktop.
Canon PowerShot SD780 IS will not download pics on
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
