I cannot connect to the internet on my laptop
  • 35 Answers
You should firstly try to check the settings of internet connection according to your ISP (Internet Service Provider) that is by My Network Places. Also u should check your Physical connection if u r using Wired network then check LAN wire and also DSL connection.
Also u should check your IP address is it coming valid or not. If it is incorrect than you should contact your ISP for your problem.
Hope it will help U.
Posted on Sep 19, 2008
Wifi Connection/Capability is lost
go to the laptop's home page, download and install latest drivers
Dec 31, 2013 | Acer Aspire Computers & Internet
Tip
How to Share your Internet Connection through laptop's WLAN(Wifi) card?
Every Windows Operating System after Windows 98 can share its Internet Connection using this Technique. Microsoft defines this technique as Internet Connection Sharing (ICS). But setting ICS is very obscure to most of the users. This comes very useful if you live with your roommates and you guys have single internet source like a USB modem Connected to one laptop only. Using Internet Connection Sharing(ICS) that laptop can Broadcast its Internet to other laptops in the room. Technically, the range of a laptop's WLAN adapter is around 20-25 meters. So it can easily handle near by rooms also. This can also be done with a PC having a WLAN card.
To setup and broadcast your internet it is mandatory that you are accessing internet using anything other than Your WLAN card like a USB modem, Ethernet etc. This is because your Wireless adapter(WLAN) will be used for Broadcasting your Internet connection to your friends.
Server laptop:- Laptop with Internet Connection.Client Laptop:- Laptops accessing the internet of server laptop.
Follow the steps to share your internet connection..here it goes:--0b73509.gif
  1. Open the "Control Panel" of the laptop that is accessing Internet and go to "Network and Internet" then "Network and Sharing Center".
  2. On the right side of the "Network and Sharing Center" click the "Change Adapter Settings" and you will see all the available network adapters in your laptop.
  3. Now Right-Click the adapter through which you access internet and click "Properties" option. The properties window will open.
  4. In "properies" Window click the "sharing" tab check "Allow other network user to connect through this computer's Internet connection"97ac799.jpg
  5. In the sharing tab, Select "Home networking connection" type as "Wireless Network Connection" click "OK" and select "Yes" to the Confirmation warning. see above image.
  6. Now Right-Click the "Wireless Network Connection" in "Change Adapter Settings"and Open Its Properties.
  7. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and select the "Use following IP address"
  8. Enter the IP address as "192.168.000.001" and "Subnet mask" as "255.255.255.0"
  9. Leave all other fields blank in Server laptop, which has access to internet.0219162.jpg
  10. Now setup a wireless "ad hoc" computer to computer connection using "setup a new connection or network" in "network and sharing center" and Name it as anything like "Internet_sharing".c2debe7.jpg3a69972.jpg
  11. Now bring other laptops that will use the Shared Internet connection.
  12. Open "Change adapter Setting" (Described in step 2).
  13. In "Change adapter settings" Right-click "wireless Network Adapter" and Click its properties.
  14. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and enter following IP address:-
  15. IP address-"192.168.000.002", Subnet mask "255.255.255.0", Default gateway-"192.168.0.001" and Preferred DNS server: "192.168.000.001".
  16. Use the same step from 11 to 15 to connect other laptops and Increase the IP address by +1. Ex- 192.168.0.3, 192.168.0.4 & so on. Rest of the settings like Default gateway etc will be same on all laptops. Only the server laptop will have blank entries in these settings.
  17. Now connect all the laptop with the Wireless network(ad-hoc) named "Internet-sharing" that you had previously broadcasted in step 10 in server laptop.
  18. Now in the server laptop, disconnect and then reconnect the internet connection(This is a necessary step for Internet Connection sharing(ICS) to work).
  19. Now access internet in all laptops...ENjoy.
Note:- For Advance Users.. this information is necessary only--The IP address of server laptop work as the "Default gateway" and Preferred DNS server of Client laptop and on server laptop these fields are blank. Use same series of IP address as used in the server.
please vote if you found this helpful.. --Abhishek
on Sep 30, 2010 | Computers & Internet
How to connect internet my laptop through my mobile (ASUS P527)
Connect your mobile to Laptop by data cable. Ensure you have activated GPRS/Internet service from your providers & also installed settings for the same on mobile.
Then on mobile screen go to Programs>Internet Sharing; select PC connection - USB, Network connection- Internet & press CONNECT. After some seconds you will see laptop is connected to internet.
Aug 11, 2009 | ASUS P527 Smartphone
Router won't connect to the internet
I managed to figure it out. I had to clone the MAC address to get the router to connect to the Internet.
I still have another problem though, my laptop still won't connect to the router. I'm using Vista, is this a possible network adapter issue? My laptop is fine at connecting to other wireless networks round my friend's houses/libraries...
Mar 21, 2009 | Belkin (F5D7230-4) Router (587009)
Mobile internet access via laptop
yes its possible. first install motorola phone tools on your computer. then configure the phone setting/connection/data/fax connection. then connect the phone with usb cable. then click default profile-ok. it detects your phone. when the phone appears in the right down side of your pc,then click connect to the internet button. cofigure the connection according to your service provider and continue the process. any further infomation contact with me at 008801714731453.
Jul 20, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Laptop can see the desktop where access point is connected and yet not connect on internet
The way this should be connected is..
Modem connects to DWL-2000ap (wan port)
Peterscomp connects to DWL-2000ap via ethernet
Laptop connects to DWL-2000ap via wireless.
May 15, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Laptop won't connect to internet
your internet link is connected but your browser is not configured for wireless.usually once connected,if you restart laptop you can access internet.if this dont help right click on ur wireless icon(in sys tray) and select properties;in property box check wireless connections.
if ur not using a wireless manager put tick in box for let windows manage.press ok or apply.then restart.
Apr 09, 2008 | Acer Aspire 5100 Notebook
THE internet is coming up internet explorer can not be connected, when it's wireless. we can plug it in and then the internet comes up.
you have to configure your wireless modem (wep/wpa) so that your laptop can connect to the internet. the reason why you cannot connect in the internet thru wireless is that the connection between the modem and the laptop has not been established. so, try to establish the connection between your laptop and the modem.
Apr 01, 2008 | Computers & Internet
My laptop cannot connect to internet
check your ip address and default gateway are correct
Mar 20, 2008 | Computers & Internet
How do I hookup ps3 using wireless laptop
I'm assuming here that you mean that you want to connect your ps3 to the internet through a windows laptop connected to the internet wirelessly, correct me if i'm wrong...
  1. connect an ethernet cable into your ps3 and the other end into your laptop
  2. Connect to the internet on your laptop
  3. go to control panel on the laptop
  4. go to network connections
  5. select "Local area connetion" and "wireless network connection"
  6. right click on one of them while they're selected
  7. click bridge connections
your ps3 should now act as if it was directly connected to the internet
Feb 16, 2008 | Video Game Consoles & Games
Computers & Internet Logo
David Payne
David Payne
