I cant get one of my playstation games to work on the internet but all my other ones do, and it says its because of the DMZ and NAT settings......how or wat do i do to change this?
  • 3 Answers
I'm guessing you mean PlayStation 2 or PlayStation 3? And are you connecting via ethernet (Cable/DSL) or via phone line (Dial up)? Also if you have a PS2 is it slim or fat? If you have a PS3 then go to Settings-Network Settings-Internet Connection Settings. If you have a PS2 then I think you need the network software disc that came with it, but you might be able to do it from system configuration.
Posted on Sep 19, 2008
I cant play online becouse of this a NATtype3 what dose this mean
Nat 3 is the result of being hooked into a router without being properly setup for data transfer. essentially it is restrictive.
There are 3 ways to change your Nat type to type 2 or 1. (Nat type 2 meaning that it is properly setup without restrictions behind a router, and Nat 1 being a direct connection to the Internet).
1.) Hook the PS3mag-glass_10x10.gif directly into the modem will result in a Nat type 1, but of course that means disconnecting everything but the ps3 and that's an unnecessary hassle.
2.) Going into the router settings and Port Forwarding the PS3's necessary ports to the Ps3's ip address.
3.) Probably the simplest (on most routers) and most effective is to go into the router and set the PS3's ip address in the DMZ (DeMilitarized Zone), essentially the router doesnt have any say from what comes and goes to the Ps3, which is good so the connection isn't hampered.
Feb 14, 2011 | Sony Playstation 3 (PS3) Console
Im playing call of duty and cannot get onto any online games. I have an internet connection and im at the rank of lance cpl 2nd class but I cant play on any games?
Make sure that you NAT TYPE isn't moderate or strict if so factory reset the modem/router and if that doesn't do it, go into your modem/router via PC and set your PS3 as a DMZ host. NOT: Setting you PS3 system as a DMZ host puts your console outside the firewall.
Feb 11, 2011 | Sony Playstation 3 (PS3) Console
I have NAT type 3 (NAT: Strict) on my Playstation 3. I've tried everything, including currently having my PS3 in the DMZ, opening the correct ports & turning off the firewall completely. I can't figure...
i have the same problem, try calling your internet provider they gave me some steps to follow that didn't work but you might luck out and they can help you
Dec 28, 2010 | Video Game Consoles & Games
How do i change my nat type
go on a computer.
1. in the internet address bar type in 192.168.1.1 or routerlogin.net
2. enter admin and password in the fields
3. your now in your routers setup
4. find a setting called nat
5. set it to open instead of secure
this changes your nat type to 2
if that doesnt work
1. login to router as usual, but find a setting called default dmz server
2. enter the IP address of your PS3 as the dmz server (to see what your ps3's ip is go to network > connection settings and have a look.
this should definitley make it a nat 2 - but try the first method
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
I can't play online ps3 games
it could be what type of router are you using? Are you able to sign into the playstation network? You could try setting up a static ip address on your ps3 and setting it as a dmz server. This will open up all ports for your ps3 and should enable you to play games. It should be a workaround for upnp. If you tell me what router make and model your using i can tell you how to do this.
Apr 16, 2010 | Sony Playstation 3 (PS3) Console
Nat problems cant change my nat 3 to nat 2 or 1 on my ps3 1 tried everything i have siemens speedstream 6520 router
To reduce the NAT
1 ) Disable the firewall in the router
2) Enable the Playstation in the DMZ
3) Make sure UPnP is Enabled
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
Nat help
Hi jman92592,
Here are some options with that router. Some online games and videoconferencing applications are incompatible with NAT. The WGR614 router is programmed to recognize some of these applications and to work properly with them, but there are other applications that may not function well. In some cases, one local PC can run the application properly if that PC’s IP address is entered as the default in the PORTS Menu. If one local PC acts as a game or videoconferencing host, enter its IP address as the default
To set up an additional computer to play games like Half Life, KALI or Quake III:
1.Click the button of an unused port in the table.
2.Select the game again from the Service Name list.
3.Change the beginning port number in the Start Port box. For these games, use the supplied number in the default listing and add +1 for each additional computer. For example, if you've already configured one computer to play Hexen II (using port 26900), the second computer's port number would be 26901, and the third computer would be 26902.
4.Type the same port number in the End Port box that you typed in the Start Port box.
5.Type the IP address of the additional computer in the Server IP Address box.
6.Click Apply
The WAN Setup options let you configure a DMZ server, change the MTU size and enable the router to respond to a Ping on the WAN port.
Connect Automatically, as Required
  • Normally, this option should be Enabled, so that an Internet connection will be made automatically, whenever Internet-bound traffic is detected. In locations where Internet access is billed by the minute, if this causes high connection costs, you can disable this setting.
  • If disabled, you must connect manually, using the sub-screen accessed from the Router Status menu "Show WAN Status" screen.
•Disable SPI Firewall
  • Normally, this option should be Enabled, so that your local network will be protected by the Stateful Packet Inspection (SPI) firewall included in the WGR614. However, certain communications functions like VPN may require turning off the SPI feature.
Setting Up a Default DMZ Server
  • The default DMZ server feature is helpful when using some online games and videoconferencing applications that are incompatible with NAT. The router is programmed to recognize some of these applications and to work properly with them, but there are other applications that may not function well. In some cases, one local PC can run the application properly if that PC’s IP address is entered as the default DMZ server.
Note: DMZ servers pose a security risk. A computer designated as the default DMZ server loses much of the protection of the firewall, and is exposed to exploits from the Internet. If compromised, the DMZ server can be used to attack your network.
The WAN Setup menu, shown below lets you configure a Default DMZ Server.
  • To assign a computer or server to be a Default DMZ server, follow these steps:
1.Click WAN Setup link on the Advanced section of the main menu.
2.Type the IP address for that server. To remove the default DMZ server, replace the IP address numbers with all zeros.
3.Click Apply.
Good Luck and don't forget to leave a rating.
Thanks Mark
Apr 23, 2009 | NetGear WGR614 Wireless Router
Playstation 3 networking problem with belkin n1 router
To REDUCE NAT ON PS3 /Xbox
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the PS3/Xbox
Step 7: Get the IP Address of the PS3/Xbox
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the PS3/Xbox in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Jan 05, 2009 | Belkin (F5D8231-4) Wireless Router...
My PS3 has no NAT Type!!
there is something known as NAT strict that can happen due to many reasons , NAT or network address translator helps in converting the WAN ip address to LAN side IP address or public to private ipaddress . In a case of NAT strict or no NAT type ur PS3 or the router to which you have connected the PS3 is not able to convert the IP address...
Solution: try logging on to the router manager or PS3 settings and enable the NAT ( it would be in a disabled state or DMZ ( de militarized zone ) state )....
If the nat is already enabled Then try to manually configure NAT by opening the port numbers on the router manager or PS3. Port numbers can of UP or TCP protocol depending upon the games ur tyring to play....
If u donno how u do it then contact sony or the people who gave u the router or ur ISP
Feb 18, 2008 | Sony Playstation 3 (PS3) Console
PS3 Internet Connection/Upgrade System/Online Play
Do an internet connection test. Your NAT type should be either 1 or 2. If not then there are some restricted ports on your router.
I find that putting your PS3 in your router's DMZ (demilitarized zone), solves all connection problems.
Dec 11, 2007 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
