Question about ASUS A8V-E Deluxe Motherboard
Adrian I have 2 memorys ddr 400 512Mb originaly and y get 1gb memory same speed, but when I put this , the Pc don't boot.
  • aspunta Sep 19, 2008
    I don't receive any error or blue screen. The screen doesn't apear. It's dark like when the machine is in stand by mode. ... and no beeps.
  • Phani Kiran Vayuvegula
    Phani Kiran Vayuvegula May 11, 2010
    does it gives any beep codes or any error on blue screen ??
  • 67 Answers
Could be bad memory or dust in the memory slot. Take it off and blow dust under it and try again. If still not working. Remove the 512 and place the 1g in its place. Try it with only the 1g alone
Posted on Sep 20, 2008
I bought 2 x 1 GB 128M x 72 333MHz PC2700 DDR SDRAM cards to upgrade my HP Compaq dx 6100 MT Pentium 4 Desktop - Upgraded the BIOS as prescribed...BUT if i insert these memory cards in any order in the...
wrong parts, its not support by chipset
Memory
One of the following
2-GB DDR Synch Dram PC3200 (400-MHz) Non ECC (2x 1GB)
Memory Speed Supported DDR Synch DRAM PC3200 (400MHz) non-ECC
Product documentation
Dec 20, 2014 | HP Computers & Internet
Can i just install memory and computer configure itself
(1) re-install the memory. or (2) check that computer support 2gb memory, if yes then check the memory bus speed which must be support by computer. if bus speed mis-match then it would not be work. also check memory type. ddr or ddr2 .. and which is your computer memorty slot.
Jul 09, 2012 | Gateway MX Computers & Internet
I wish to add RAM in the PC. Mine motherboard-Epox-EP-4BDA533(I). ID(identification)-05/09/2003-i845d-6A69VPA8C-00. On it costs RAM 256Mb -DDR PC2100 266Mg FSB-400Mg. How many Mb it is possible to add....
Manufacturer Specifications - EPoX EP-4BDA533I Number of Slots:
Slot 1
Slot 2
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.*
*Not to exceed manufacturer supported memory.
  • 184-pin DIMM Banking: 2 (2 banks of 1)
  • Chipset: Intel 845D
  • Error Detection Support: ECC and non-ECC
  • Graphics Support: AGP 4X
  • Max Component Density: 512Mb
  • Max Unbuffered DDR SDRAM: 2048MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR SDRAM only
  • USB Support: 1.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR memory with support for DDR PC2700,DDR PC3200 speeds.
Because DDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible DDR speeds listed below, even if your manual calls for PC1600 or PC2100 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: No.
Your system does not support dual channel.
Q: Does my computer support ECC memory?
A: Yes.
Your system supports ECC. You can put non-ECC modules into an ECC system, but be sure not to mix ECC and non-ECC modules within a system. Install the same type of modules that are already in your system.
Jan 13, 2010 | ASUS Intel 845D Chipset P4B266 (P4B266-PA)...
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
What type and how much memory can i put in the MB MS 6577 Ver 4.1?
1GB Of PC2100/PC1600
According to:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph07843
Apr 24, 2009 | Computers & Internet
RAM compatibility with MK79G motherboard
Hi, I am assuming that the original piece of memory was a 256mb ddr pc2700/333mhz ?
i have looked at your board on the product maker website and it supports memory to 2gb of pc2100,pc2700/pc3200 type memory. Be certain however that the new piece added is the same clock speed as the original that you are trying to use with it. You cannot mix clock speeds, either pc will not boot or it will only recognise the compatible piece. Have you tried booting with just the new piece 9 leaving out the older piece)if yes what was the result. Need more help ?? compdoctor2005@btinternet.com
Jan 03, 2009 | AOpen MK79G-N (91.8B110.101) Motherboard
Upgrade ECS FSB800 memory from 1 GB to 2 GB wont work
This board will support up to 2gb as shown below extacted from the website product page.Don't forget that if you have ddr 333 memory installed originally, you can only add the same clock speed memory, i.e. ddr 333. If you add ddr333 and ddr400 you will have problems as the clock speeds do not match. If you are matching clock speeds, the try bootin the system with the new piece of memory on its own to see if there is a problem with that stick, trial an error of both sticks individually, will give a positive result
MEMORY ecs_buttom_03.gif Single-channel DDR memory architecture ecs_buttom_03.gif 2 x 184-pin DDR DIMM socket support up to 2 GB ecs_buttom_03.gif Support DDR400/333 DDR SDRAM
Nov 02, 2008 | EliteGroup ECS P4M800-M Socket...
K7VT4A-Pro Mobo
Greetings,
The motherboard will read 1GB DDR400 memory per slot only.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Asrock K7VT4A-Pro Motherboard
ASUS A8V-E Deluxe Motherboard Logo
56 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
