Would like to know how long to chg battery before using the comp.
    Scholar:
  • 97 Answers
4 to 6 hours is usually more than enough but you'd probably want to charge it longer. It doesn't matter much if you charge it longer since it doesn't get over-charged because it has it's own device that allows it to only take in what it needs.
Posted on Sep 19, 2008
My pro 39 scanner loses memory after unplugged for 24 hrs..Question: is there a memory storage battery inside unit..
Here's a link to your radio's manual. Make sure the rechargeable batteries are able to accept a full charge. If they have been recharged more than a couple of hundred times, they may need to be replaced.
Pay attention to which jacks your are powering the radio through. The PWR and CHG jacks perform some similar, but very different functions.
The AC or DC adapter can be connected to the CHG jack when you wish listen to the radio (and recharge at the same time) ONLY when NiCad batteries are installed (or to simply recharge the NiCad batteries with the radio off). Recharging with the radio off will allow the batteries to recharge fastest (10 - 18 hrs).
As per the manual, you should not connect a power source to the CHG jack if using anything other than NiCad batteries in the radio, as they will heat up and could explode, instead connect to the PWR jack whenever using regular, non-rechargeable batteries.
Jul 26, 2012 | Radio Communications
What l need to know is if after chg. why power light will not go on we cannot ck any buttons until we get power right
You might check the connections at the battery. Be sure they are tight and corrosion free... I hope this will help you...
Jan 07, 2011 | NRS Hoveround MPV 5 - Used Power...
When I plug in the ac adaptor to charge unit,the instructions state the chg light will go off when charged. Is it possible that it is charged and the light stays on. I charged it (in the off position)...
The unit still,work?The battery when it low,the battery light turn yellow or red?Than when it fully charge it turn green?Just unplug the unit and use it dosen't matter,if the light don't turn off the light,that find.Or the battery is old and not taking full charged anymore that another resoan the charging light still on.
Jun 14, 2010 | Mintek MDP-1770 Portable DVD Player
My cell get heated when i put charge batt chg circuit of cell isnot functioning i get batt chg from universal charger nokia1100
Usually it is the battery hat is becoming old enough to internally short and this will cause it to work poorly and not ever fully charge, and get warmer than normal or hot when attempting to charge for more than 1/2 hour. Sometimes the chargr can go bad and over charge, thus making the battery too warm. if you have a car cell phone charger that plugs into cigarette lighter outlet , you can atach this and see if battery gets too warm, but these chargers usually charge faster than electric plug-in type, so expect some warmth within 20 minutes, but again if too warm than you know itis the battery. For these unnits batteries are not expensive.
Apr 28, 2010 | Nokia 1100
Screen goes blank and it says chg in small letters on the right lower side
Actually, "chg" means "change" in this case. Since this is a solar watch, it is not necessary to change the battery. I let my watch sit in the dark for a few months and I came back to the same screen when I dug it out of a drawer. Simply allow the solar cells to get some light to recharge. I left the watch under a lamp overnight because I needed a stopwatch in the morning, and it was charged by the time I woke up. Also, this watch has a power saver function you can turn on and off. If the watch is left in the dark for about an hour, the screen will turn off but the normal functions will continue in order to save power..
Apr 09, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
I bought a 99 C-V PI blown engine chg out with 97
You have a ground wire off or theres a plug maybe your over looking that needs to be plugged in
Dec 08, 2009 | 1999 Ford Crown Victoria
92 Camry, have to start several times before engine turns on, onl
weak fuel pump, clogged injectors, air or coolant temp sensors out of specs. Timing belt was put on wrong. Timing is off. Map sensor out of specs. You do have a light on. Fixing why the light is on may fix your problem.
Aug 06, 2009 | 1993 Toyota Camry V6
CHG Light Showing, in our 81 Corolla CS what dose this mean?
Your chg light is your charging system. It could be your alternator, battery, cables, wires etc. Generally pretty easy to diagnose with a multimeter. To check the alternator the old fashion way, you can start the car and disconnect the battery while it is running. If the engine stops then the alternator definately has a problem. This is not recommended as it is much safer to use a multimeter.
Apr 30, 2009 | 1983 Toyota Corolla Deluxe
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
