Question about Brother SE-270D Computerized Sewing Machine
I have a Brother SE-270D which I tried for the first (maybe last) time to make buttonholes. Not only did the bobbin thread consistently knot making buttonholes impossible, but the thread continues to knot with all sewing--does so immediately, activating the safety device. I have: 0 changed the needle 0 changed the bobbin 0 rethreaded the upper thread 0 thoroughly cleaned the bobbin shuttle o checked bobbin and shuttle for nicks The machine sews only without the bobbin thread! Can you help, please?
  • 5 more comments
  • rosiekid Sep 19, 2008
    When attempting for the firsts time to make buttonholes on my Brother 270D, the lower thread continually knotted. It now knots immediately when I start to sew. As a solution, I have:
    . changed the needle, thread, bobbin
    . checked bobbin and shuttle for nicks
    . thoroughly cleaned bobbin and shuttle
    Unable to sew at all.
    Answers are unresponsive. I don't need to know how to make buttonholes, and I have studied the manual--no need for a download. If you don't know how to fix this problem, say so and I'll ask for a refund.
    Please reread my first or second comments which outline my dilemma. I have a SPECIFIC problem which has nothing to do with routine maintenance since the machine has only about 6 hours of use. The problem appears to be with the bobbin or shuttle; I have tried all the logical, routine items, as previously outlined.
  • rosiekid Sep 20, 2008
    The last response sounds plausible. But, I can find no large screw as you suggested. This is a Brother SE-270D, if that helps. Timing belt may need adjusting but shouldn't need replacing since the machine is brand new. Help me find that screw and I'll try it. Thanks.
  • sdobler Feb 21, 2009
    When sewing a button hole, I am able to complete the left side but once the needle comes to the spot where it should complete the top of the buttonhole and come down to sew the right side, a big knot/bulge/ball of thread develops and the machine keeps sewing back and forth at the one spot, not moving the fabric.
    I've asked around and was told to do the following, which I have done and which have not helped, the problem persists:
    change needle
    use interfacing
    keep the material taut by holding it
    Any thoughts?
    Thanks, Steph
  • Anonymous Mar 18, 2014
    It will sew about an inch and hang up. The thread on the bottom is long & bunched up
  • Anonymous Mar 20, 2014
    after the bobbin is put in the slot to start sewing
    President:
  • 1,952 Answers
First of all, take care of the simple things- make sure that the needle is in the machine correctly (flat side to the back), make sure that the needle is the proper size to carry the thread that you are using, and make sure that your upper tension is clamping on the thread. If all of these things have been checked and or corrected and you are still experiencing the problem, take the hook out the machine by removing the race cover and inspect the hook. You'll probably find chips and burrs near the tip of hook. If so, polish it down with an emery board, oil the hook, and replace. This should take care of your problem. If you need further assistance,
Posted on Sep 20, 2008
    Sergeant:
  • 399 Answers
Its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
Posted on Sep 19, 2008
  • 2,071 Answers
    Scholar:
  • 148 Answers
Here a few instruction.
  • Zander Rovic Ocampo
    Zander Rovic Ocampo Sep 19, 2008
    this one pict is clearer than the other
    Scholar:
  • 163 Answers
Have a look if your manual below helps. Download it from link:
http://www.brother-usa.com/manuals/default.aspx?ProductGroupID=3
    Master:
  • 497 Answers
My thread keeps getting knotted up underneath. I have followed all the trouble shooting procedures and it still won't work.
Usually it is the top threading, tangled thread or a bent needle that causes that problem. You can call Brother at 1-877-276-8437 and maybe they can suggest something else to try.
Oct 01, 2010 | Brother SE-270D Computerized Sewing...
My Brother SE270D keeps jamming up and getting thread all tangled up The feed is not advancing either.
Make sure you are using 60 weight bobbin thread only in the bobbin, also make sure you are using only SA156 ( SFB-XA5539-151) bobbins, the size 156A are not for this machine. I have used Singer size 15J bobbins with no problem. The bobbin should have slightly rounded ends, not flat like a regular bobbin. This helps the thread over the bobbin at high speeds.
I threw my machine out of time the first three times I used it for embroidery and decorative stitches. Had I read the manual, I'd have known to use 60 wt bobbin thread. I have also used 90 wt with no problems...60 wt is what comes with the machine.
If you have to take the machine in for service, make sure to take sample of the problem and the embroidery unit, thread you used, etc. Take it all and tell them to test it all.
My Brother dealer felt these Disney machines were great little workers..and said they are not hard to repair...some dealers don't know enough about how to repair the thread cartridge, so tell you the machine is not worth repairing. It is...I've had mine for 4 years.
Hope this helps some. You may have to take the machine in to be timed / cleaned...once that's done and you are using proper thread and bobbins (upper thread - you can use any, bobbin it's 60wt)...you will love your machine.
Apr 14, 2010 | Brother SE-270D Computerized Sewing...
Having issues with my Se-270D can you help
The brother machines are notorious for jamming if there is even a tiny bit of lint in the machine. Take out your bobbin, unscrew the plate, take out the bobbin holder. Use a pipe cleaner or paint brush to brush all around inside the machine and pull out any little threads/lint that has collected in there. Replace the bobbin holder by lining up the screw toward the front. Replace the plate and screws. Make sure your bobbin doesn't have any little nicks around the edges that could catch thread. Replace the bobbin and rethread. Replace your needle (this needs to be changed often) rethread your upper thread. Test stitch.
Mar 16, 2010 | Brother SE-270D Computerized Sewing...
I have a Brother SE-270D. The top thread is not
A bent needle will cause this. Otherwise the shuttle is out of time, have it serviced..
Feb 09, 2010 | Brother SE-270D Computerized Sewing...
Brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
Feb 04, 2010 | Brother SE-270D Computerized Sewing...
I'm new to embroidering. I have BrotherSE-270 Disney. I have read through the manuel several times and am confused about the bobbin thread. Do I use tread specficaly for embrodering or will regular thread...
Your machine probably came with brother embroidery bobbin thread (one spool, white)...I used it until it was gone and did buy more embroidery bobbin thread at a regular superstore (it wasn't brother brand though)...however, I have since used regular thread and not had problems. HOWEVER, be sure it is good, quality thread - none of that $.50/spool stuff. That knots up and simply doesn't look good if it does work. Good luck!
Jul 08, 2009 | Brother SE-270D Computerized Sewing...
Instrucitnos for Brother SE-270D Timing Problem
This is not really something you can do yourself (been there, tried that!). The machine has to be almost completely disassembled to get to the timing mechanism. Trust me, it's worth the 30.00 to have it timed.
I think http://www.allbrands.com has a generic timing explaination for sewing machines (use the drop in bobbin one)...I found it easy to follow...but once I realized I had to unplug all the components for the computerized functions... I took it in to the dealer. If you contact Brother & your machine is under warranty, they will pay for the repair (they paid for my first two re-timings). Now I know you HAVE to use BOBBIN thread that is 60 WT only in the bobbin. You will continue to have problems if you don't. Also, this machine uses the class 15 bobbin, but make sure its model number SA156A, which is a hair taller than the SA156 bobbin..both are class 15, but the tiny difference is very important.
Jul 26, 2008 | Brother SE-270D Computerized Sewing...
Bobbin Problem
there is a thread tenchener screw that the repair center has to ajust so it will have the tenchen Dan
Apr 02, 2007 | Brother SE-270D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
734 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
