Question about IBM Wheelwriter 30 Typewriter
Pica or pitch?
How do i set the pica or pitch... the one that makes the letters closer together on my ibm wheelwriter 5 typewriter?
  • IBM Master
  • 3,594 Answers
To change the pitch install a printwheel with the desired pitch 10, 12, 15, or PS.
DickyO
Posted on Sep 19, 2008
How do I change the size/font of the letters? Bold and underline too?
To change font and pitch, you need to buy a different printwheel. machines came with a prestige elite 12 printwheel. Prestige elite has small letters and 12 puts 12 charactors per inch. Letter gothic is larger size letters. Google search for ibm wheelwriter printwheel, also called a daisy wheel.
Mar 03, 2016 | IBM Wheelwriter 30 Series II Typewriter
The typewriter is suddenly squeezing all the letters really close together???
Depending on the typewriter, there is a "PITCH" control putton or keyboard function, 10 pitch is pica (10 characters per inch) 12 is elite or 12 characters per inch and there is a 15 pitch which will crowd letters together. set the pitch to 10, make sure the printwheel is a 10 pitch wheel and this may work. Also there is a chrome rod runs from left to right, place a small drop of 3/1 oil on tis rod and move the carrier back and forth either by hand or tab and carriage return...
Sep 20, 2013 | Royal TA Adler-Satellite 40 Electric...
How can I make print smaller on IBM Wheelwriter 6 series 2?
You will have to purchase a wheel with different font. Is your machine capable of both 10 and 12 pitch? If it is, there will be a lever near the platton to make this change. For more information, ask at the office supply place where you go to get your new wheel.
Mechanical typewriters are not able to use scalable font. Every letter on a typewriter is the same size as every other letter. You can get larger and smaller letters (font) ... but they will occupy exactly the same size space. The only other option, as I say, is the 10 pitch or 12 pitch (how many letters you "pitch" up on the paper per inch). If your machine has this capacity, you can use both pitches.
I hope this answers your question. Thanks for your interest in FixYa.com
Feb 23, 2010 | Lexmark Wheelwriter 6 Series II Typewriter
We have a IBM Wheelwriter 5. Need to use
Correction is pretty simple type a letter, press the correction key and it should lift the wrong letter off.
DickyO
Sep 30, 2009 | IBM Wheelwriter 30 Typewriter
10 pt printwheel printing 12 pt spacing
Some type styles do have thinner print than others. The pitch is automaticly selected when you change printwheels. You can measure the pitch by printing 12 letter "i" and putting a ruler up to it.
12 spaces per inch is elite and 10 is pica.
Nov 19, 2008 | Lexmark Wheelwriter 1000 Typewriter
Ibm wheelwriter 5
Most likely the plastic cap on the print solenoid is broken they are available but are a bit tricky to install.
DickyO
Mar 27, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 5--Carriage advance problem
Try code (lang) key either the X or L depending on when it was made
DickyO
Dec 31, 2007 | Lexmark Wheelwriter 5 Series II Typewriter
IBm Wheelwriter 5--6 keys won't advance after typing
Press and hold the code key while pressing the lang key Either "X" of "L" key.
DickyO
Dec 31, 2007 | Office Equipment & Supplies
Character spacing
Joany, look for a function,usually on the left side of the keyboard on the IBM,that has the markings 10,12 and 15. And if my memory is correct,there will be a series of lamps which light up at the selected pitch. I would look for a key marked "pitch" and press that. Good luck.
Nov 21, 2007 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 30 Typewriter Logo
117 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
