Question about Bosch Dishwashers
Hello, My husband bumped into our Bosch dishwasher door when it was open. It won't close now, one side is about an inch higher than the other. Also the inside of the door (not the hinge) looks bent. What can we do? Can a repairman fix the door or do we need to get a new one?
  • 126 Answers
THE DOOR NEEDS TO BE RESET IN ITS POSITION.THAT A REPAIR MAN CAN DO BEST YOU GET THE AXPERT IN TO ASSIST YOU.
GOODLUCK.
MOHAMED
Posted on Sep 19, 2008
How do i operate a basic bosch dishwasher
On many Bosch dishwshers (especially those with the controls on top), they expect your to press the appropriate cycle and option(s) buttons, and then press the Start key, ALL WITH THE DOOR OPEN. Immediately after pressing the START button, close the door (within 3 seconds), and the dishwasher should start.
On other Bosch dishwashers, if you open the door, the poser button is automatically turned off. On those models, you must close the door, turn the Power button ON, and THEN press the appropriate cycle & options buttons. If your dishwasher has a START button, then press it; otherwise just wait 10 second with the door closed.
See? There is no such thing as a "basic bosch dishwasher". Next time, if you have a question, please provide the model number of your dishwasher (or other appliance).
Mar 20, 2015 | Bosch Dishwashers
Door hinge tension adjustment
You have to change the springs at the bottom back.It; s easy.You must buy the item 0509 at this page or anyother you like http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/All-Products-Parts/Model-SHX45P05UC60/1794/0130000/1010702P/00005?blt=06&prst=&shdMod=
Then you must access the bottom side of the base of dishwasher and with a screwdriver pull off the old springs.After this you will see a cordon that you must remove it and connect this to the new springs.
Sep 05, 2013 | Bosch Dishwashers
Bosch Logixx won't start - Stuck on "Close the door" even though door is closed.
Open the door, look along the top stainless on the door and you should find the ENr number (model number) etched into the stainless, may need to give it a wipe and look at an angle to read it. Post the ENr and that should help with diagnosis.
Mar 15, 2013 | Bosch 24 in. SGS69L02 Logixx Built-in...
Have to slam dishwasher door to make it go electrolux 4000
Hello David Horn - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may also prevent the unit to start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Nov 18, 2012 | Electrolux Dishwashers
Dishwasher won't power on- no lights. My husband just cleaned out the appliance- could he have knocked something loose?
Hello, welcome to Fixya. When you state your "husband just cleaned out the appliance" what do mean exactly. I would suspect a poor line connection at the junction box where the power enters the dishwasher, or a broken wire in the door panel at the point it bends as the door opens & closes is common...based on what you've described. Let me know by posting a reply what you find and what you meant. **Make sure the breaker is OFF before attempting any repairs** I'll try and assist you through a diagnosis and repair if need be. Good luck macmarkus :)
Jul 07, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Burning plastic smell, big flash & now its dead - Bosch SHU8805UC
remove the water and, the burnt plastic that probanly melted on the dish drying heater coil
close and, lock the door turn the dishwasher back on and, reset the circuit breaker to see if the motor will run or, is damaged
Jul 01, 2009 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Where do I put the Jet Dry in my Bosch Sensotronic? I bought a house with this dishwasher but no manual. Many thanks!
ON SOAP CUP WITH DOOR OPEN LEFT HAND SIDE IT WILL HAVE A DOOR IT OPENS LIKE A TUPPER WARE BOWL FRONT TO BACK LEFT HAND SIDE OF SOAP CUP LIFT UP AND SLOWLY POUR 3 OZ OF JET DRY OVER DIAL INDICATOR MAKE SURE YOU POUR SLOWLY MAKE SURE YOU CLOSE THE DOOR CLOSE D/W AND REOPEN DOOR THIS BURPS THE DISPENSER. JET DRY IS NOT SOLUBLE IN WARM WATER SO IF YOU SPILL ANY TAKE A RAG AND CLEAN IT UP GOOD ONEC A MONTH YOU REFILL W/ 2 TO 3 OZ
dON
262-893-4840
May 19, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Bosch dishwasher won't latch
No you did good in ordering a latch ,that is a common issue i find with the bosch d/w, for no apparent reason the latch locks itself with the door open. Look at the door where the male part of the latch goes into the door, you will see that is locked. if you take it apart and manually unlock the latch u stand to break it. Again you did good on ordering the latch.
Jan 09, 2009 | Bosch 36 Inch Pyramid Chimney Hood - Black
The Rinsing aid door keeps opening in my Bosch dishwaser
I believe paddy55 is correct about the rack position affecting the rinse agent door. When the top rack is moved to the higher position, the rack hits the latch on the rinse agent door, causing it to pop open.
Move the rack back to the lower position and see if the door stays closed.
Apr 06, 2008 | Dishwashers
Can't close Bosch Dishwasher door
I had same problem and was alarmed at the idea of taking the door apart, so I tried the 2 screwdriver option described below - it works!
Open door and get two small screwdirvers behind each side of the catch inside the top of the door and gently apply pressure. The catch should reset itself on 'open' and allow you to shut the door again.
Thanks to all for their postings and helpful advice!
Nov 10, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwashers Logo
117 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
