Question about Hoshizaki Refrigerators
Hello, I have a HOSHIZAKI IM-21CLE. The 5 amp main fuse blows instantly. What could the cause be ?
  • bjuran Sep 19, 2008
    Hello.
    Thx for the quick reply. Very grateful for that. I am used to repair Audio / Video products but
    with this i have noe experience. I am not sure what company have the service for this product
    here in Norway.
    Thought maybe i could get some tips on faults that is well known for this modell.
    Maybe you could help me with which company or tech i could contact in Norway?
    Best Regards.
    Lars B
  • 126 Answers
THAT INDICATES THERE IS A SHORT CIRCUIT ON THE APPLIANCE.YOU NEED TO GO THROUGH A LIST OF OPTIONS TO ASTABLISH WHICH COMPONENT IS CAUSING IT.I ADVISE YOU CALL A TECH AND LET HIM ASSIST YOU.
GOODLUCK.
MOHAMED
Posted on Sep 19, 2008
  • MOHAMED UZAIL ESSACK
    MOHAMED UZAIL ESSACK Sep 19, 2008
    ITS ONLY MY PLEASURE TO ASSIST YOU LARS B.THE FEW THINGS THAT CAN CAUSE THE FUSE TO BLOW IS A FAULTY ELEMENT,FAN MOTOR,BI METAL SENSOR OR EVEN WIRING.IF YOU DONT NO THE MANUFACTURE OF THE APPLIANCE THAT SHOULD'NT BE A PROBLEM YOU CAN USE ANY GOOD TECHNICIAN IN YOUR AREA HE SHOULD BE ABLE TO FIX IT WITH NO HASSELS
Will it hurt to replace the 20 amp fuse in my cigarette liter to a 25 amp it keeps blowing fuses
I am wondering if the fuse blows instantly or whether it lasts a while?
Fuse ratings for cars are usually mean or average values so a 20 amp fuse needs roughly 40 amps to cause it to instantly fail. I have not heard of a cigarette lighter needing that much current so I guess there is a fault that should be located and cured before you have a fire.
Maybe it is the element that is faulty...
I think fitting a 25 amp fuse would be slightly foolish...
May 12, 2017 | Cars & Trucks
Coleman furnace dgaa077bdta
The control fuses keep blowing tells me one or more of the control that operate the control on 24 volts is malfuctioning. Most controls operate at about 5 watts and on a clamp on amp meter normally pull about 0.2 amp (p = current x voltage, 5 watts = 0.2 amps x 25 volts) I install 75 watt 24 volt transformer with a resettable overload to save on fuses. I reset the transformer and quickly go to the controls and determine the amp draw. When I find the one >0.2 amps I found the problem. The things to check is the emergency heat sequencer, fan control sequencer, reversing valve for heat pumps, main contactor on the condensing unit and any other 24 volt control loads. I have had to replace the themostat wire because the increase current for the thermostat wire can cause the entire length of wire to form a long heater and cause insulation degradationa and cause the thermostat wire to short out and blow the fuses.
Hope this helps
Aug 30, 2014 | Coleman Mobile Modular Home Gas Furnace...
My york heat and air unit with emergency heat is blowing 30 amp fuses and sparking at the fuses and contactor when turn main breaker back on. I have replaced contactor, transformer and the compacitor on...
You either have something wired wrong or you have a direct short in the system. Are you starting the A/C or the furnace? If it's the A/C, it could be a shorted compressor, capacitor, fan motor or it's wired wrong.
Oct 30, 2013 | Heating & Cooling
Can a bad voltage regulator cause the main 30 amp fuse to blow?
Usually a bad regulator will only cause problems with charging...
Sounds like you've got a short somewhere in the wiring...I'd start by checking the ignition switch wiring and the connections going into the fuse box.
Mar 19, 2012 | kawasaki VN 1500 Vulcan Classic...
Internal fuse on cambridge a1 mk3 has blown and when replaced,blew instantly??
When the fuse blows suspect an overload in either the power supply or Main Amp section.
Check for burnt/damage parts first!
Power Supply faults that will blow the fuse are: Transformer, Rectifier, Voltage Regulator, Large Electrolytic Capictors, Diodes & any other semiconductor connected with it.
Main Power Amp faults are: any semiconductor device on the heatsink.
Jan 04, 2010 | Audio Players & Recorders
My ice maker 10amps fuse burn out when turn on the machine
This may sound too simple. A fuse is a safety. It usually blows when the amps are higher than the fuse rating. Since yours blows immediately, I would look very closly for a pinched wire, a crossed wire, or a wire that has rubbed through. Once that is eliminated, start isolating components one at a time. Check their web site. It's pretty good. Also, their tech support line is pretty good. It's worth the wait. 1-800-233-1940.
Jan 22, 2009 | Hoshizaki Freezer Commercial Ice Machines...
My sd-533hd5 keeps blowing the 5 amp 125v fuses
Yes! it sounds like a power supply problem! or the flyback in the main board needs replaced ( part is in the $70.00 range
Dec 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Short Circut, blows fuses instantly.
OK usually the fuse goes because the Amp's IC's are drawing too much current thus the fuse blows... either this OR the Power Supply has gone Kaput. It is possible to replace the output IC's.. as it is to fix the PSU.. But it really is a shop job..
Jul 28, 2008 | Durabrand 5.1 Surround Sound Computer...
Keeps Blowing The 5 Amp Fuses
There is a short in either or both the main power supply or one of the scan amplifier sections and or the high voltage section.
You will not bel able to service this yourself. This type of repair can be fairly involved and complicated to troubleshoot.
An expericed TV tech should be able to service this for you.
Jerry G.
Jul 07, 2008 | GE 35GT695 TV
Refrigerators Logo
209 people viewed this question
Top Hoshizaki Refrigerators Experts
Tom Donaldson
Level 1 Expert
J Rosado
Marat Brikov
Are you a Hoshizaki Refrigerator Expert? Answer questions, earn points and help others
