Question about Samsung (SP0822N) 80 GB Hard Drive
Connecting data pins broken
When I was connecting the data pins which is 19 in nos , I broke 2 pins on the hard drive. Now I am unable to access my hard drive. Please advise.
  • 95 Answers
If you are good with soldering you can fix it. If not - get another SP0822N drive and swap the cards.
Posted on Nov 08, 2008
Broken connecting pin on the hard disk
From my experience, it is not even close to cost effective to try and repair a hard drive with a broken pin. A new enclosure/board would have to be purchased and that board would have to be a match to the one you are pulling for the hard drive to be usable. This all needs to be done in a clean room.
It would cost hundreds less to just replace the drive.
Backup, backup, backup, and then when you are done with that backup again.
Mar 21, 2012 | Computers & Internet
I have a working hard drive (Barracuda 7200.7) from a 2007 HP Pavilion a430n that contains files that I would like to retrieve.
Your description has me confused. I'm not clear on which power and data cables you are using. You described pulling one cable from first hard drive and connecting it to your second drive. Extra power connections should have been in a loose wire bundle somewhere in the computer. (Often they are tucked into an unused drive bay.)
The SR1720NX has 2 SATA controllers and two IDE controllers. Thus it can have 2 SATA and 4 IDE devices. The computer sometimes shipped with a SATA hard drive or an IDE hard drive. In all cases, the hard drives must be connected to the data cable (and to the motherboard) and then the power connection from the power supply has to be connected. So there should be 2 cables plugged into each drive. The optical drive is usually an IDE drive for this model, also a master drive.
The IDE power connection is a large 4-pin Molex connector; the SATA power cables are a smaller 5 pin connector. There is also a small 4 pin connector that powers a floppy drive, if present. IDE data cables are a wide 40-pin ribbon cable (sometimes an 80-pin cable for master/slave). The SATA data cable is a 15 pin cable.
First make sure that the jumper on the drive from the A430n is across the two pins in the second position (counting from the side away from the power connection). This is the cable select option. Next make sure that the IDE cable is firmly connected to both drives and the motherboard. (I've sometimes loosened the data cable while connecting the drives.) Finally check that the appropriate power cables are firmly connected to all the drives. Then power up the computer. (With the second drive on the Slave connection, if the device on the Master connection isn't powered up/recognized, then weird things may occur.)
BTW: you should be alert to the power needs for the computer. The original power supply could be overloaded with the extra drive. You might be better off using an external drive enclosure (USB) or a USB/SATA/IDE dongle that leaves the drive out in the open. Connect these with extreme care following the directions for when to connect the power supply. Some enclosures won't work without reformatting the drive - you do not want one of those.
I hope this helps.
Nov 24, 2011 | Seagate Computers & Internet
Bag carrying the HDD banged to the wall, now when connecting I hear a click..click noise- unable to access the data in the HDD, will it work if open the same
When a hard diskmakes a clicking sound and the computer does not detect it then the hard diskis faulty. This is commonly known as "The click of death".
There is no way of fixing this hard drive, if you need to recover your data,then there are companies that can recover data off faulty hard drives BUT itwill cost you an arm and a leg for their services.
Jun 27, 2011 | Seagate (ST9100801U2-RK) (9W3638556) 100...
I'm attempting to save data from a broken hard drive. I bought an encloser to transfer the broken hard drives data and put it onto a new external hard drive. The encloser powers up, but when I connect the...
kozpaul2310
It is possible the drive is pulling more power than the enclose can handle. Also it is possible that there is a problem with the hard drive controller card as well.
Also clarify you are connecting a standard hard drive and not a notebook drive correct. If this is a standard drive I would recommend you try to connect the drive directly to your computers IDE controller to see if the drive will work. If it does not most likely there is a problem with the drives controller card.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jan 16, 2011 | Rocketfish Hard Drive Enclosure Kit for...
Pin connector hard drive.
I'm afraid I don't exactly understand what you mean. is there a problem connecting the hard drive the laptop because of broken or missing Hard Drive pins?
Aug 12, 2010 | MPC Computers TransPort T2300 Notebook
If pins on cd driver is broke will that prevent the cd player from playing
Pins are mainly used to transfer data and control signals from the mother board to the player.
So if the pins are broken then it will be difficult or impossible for the player to play in its usual way.
It would be advisable for you to change the player but try connecting once . The player might work.
Thank you.
Good luck !
Jul 02, 2009 | Dell Computers & Internet
Power connection, but no Data (Mac)
Take a look at this photo. There are two different firewire connections on it. If your Mac has the one on the left, it is the four pin and needs a power source to run it. If it is the one on the right side, you have a six pin and should have power to run it.
Jul 04, 2008 | FireLite (USBFLB80) Hard Drive
Aspire 3000 laptop the ac power is not connecting with notebook. Before the yellow light went out it came on then went off when i wriggled the connecting plug.Now their is no yellow light and the battery...
If you are referring to the files inside the hard drive, then as long as it is not defective, it will last a very long time. Most hard disks can retain data indefinitely .
As to your concern with the laptop's charger/power supply jack, it is very possible that the connector simply lost its connection inside the motherboard. This could be easily remedied by re-soldering the two (2) pins of the said jack. What might be a challenge is the opening of the laptop to expose the underbelly of the motherboard.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 24, 2008 | Computers & Internet
Samsung (SP0822N) 80 GB Hard Drive Logo
106 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
