Question about Toshiba Satellite A45-S250 Notebook
Power light blinking
I have a toshiba satellite a45-s250- while using the computer, the computer shut down last night. When I attempt to start it using the power button, i press the button and nothing happens. I tried unplugging the computer, taking the battery out then put the battery back in and plug the computer in and the same thing; nothing. I tried with the battery out and the plug in and the samething happened; nothing. Two things to note are; 1. when I unplug and replug the computer, with or without the battery, the power light is a solid green. When I turn it on, it starts to blink. 2. It sounds like the computer is trying to do something because when I press the power button, I do hear the CD Rom move, but thats it.
Suggestions?
  • padillajoseg Sep 23, 2008
    Exactly the same problem. I took it apart cleaned it, tried to reset de BIOS, tried booting alternating RAM Modules, tried booting without a hard drive, nothing worked.
  • 107 Answers
That is because either you screen is dead(test by connecting a exteral monitor) or you motherboard is dead and I have been seeing many dead motherboards as of late
Posted on Dec 09, 2008
Driver toshiba satellite a45-s250 wireless network connector
Toshiba Support > Satellite A45-S250 Notebook PC > Atheros 802.11 a/b/g WiFi driver with Cisco WPA support for Windows XP and 2000,
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=555703&rpn=PSA40U&modelFilter=A45-S250&selCategory=2756709&selFamily=1073768663
HOWEVER, it requires the Atheros Client Utility v2.4.2.18, to be installed. If it isn't installed on the laptop, this utility needs to be installed first. Then the Driver above.
If you need guidance in downloading, or installing please post in a Comment.
Regards,
joecoolvette
Oct 08, 2011 | Toshiba Satellite A45-S250 Notebook
My toshiba satelite A45-S250 doesnt start the windows, it keeps rebooting and I am not being able to install it again, my dvd drive isnt working
Unplug the power cord, take out the battery and hold the power button down for 10-15 seconds. This should take your computer out of the reboot loop that it is stuck in. If it doesn't, try using an external CD drive from Wal-Mart or Radio Shack, your computer should register it and you can load the windows CD from there.
Mar 12, 2011 | Toshiba Satellite A45-S250 Notebook
How to replace the dvd drive in a toshiba Satellite A45-S250
Most toshibas have a small screw on the bottom of the computer, next to the memory cover. take screw out and the use a paper clip or turn on laptop, to eject dvd drive, then turn off laptop, unplug power, then pull on drive outward, shold slid out of laptop,.
if replacing with new drive remove metal screw clip off the back of old dvd drive and screw onto new dvd drive, slide in and replace screw!
Jan 13, 2010 | Toshiba Satellite A45-S250 Notebook
The right hinge on my screen is broken. Can it be
Here's a link to hinge repair procedures...
http://www.laptopka.com/2007/08/01/replacing-satellite-a45-broken-hinges/
It also has a link to search for the replacement part you may need.
Jan 01, 2010 | Toshiba Satellite A45-S250 Notebook
I have a toshiba a45-s250. the screen is dim but
Have you adjusted screen brightness control as I have seen lots of Laptops with the screen brightness control "bumped" to min.!!!
Nov 20, 2009 | Toshiba Satellite A45-S250 Notebook
The cooling fan is not working
THe shutting down is your laptop's thermal protection. It is trying to keep the CPU from being destroyed.  You should stop using it until you fix it, or you will destroy it.
The fans are not hard to replace and toshiba disassembly is fairly straight forward. Just get your #1 and #2 phillips head screw drivers and pay attention to how you take it apart.
Call Toshiba and order replacement fans for your laptop as they will not set you back very much.
Feb 16, 2009 | Toshiba Satellite A45-S250 Notebook
I need all the drivers for toshiba satellite A45-s250.
You should be able to visit this link: Toshiba Download Center and select your Satellite model from the Portables section.
Feb 01, 2009 | Toshiba Satellite A45-S250 Notebook
Toshiba Satellite A45-S250 PC - where is the ram located?
The memory is under the keyboard on these models. Remove the plastic piece with the power button, and you will see the screws for the keyboard. Don't forget to rate me (fixya). thanks
Jul 31, 2008 | Toshiba Satellite A45-S250 Notebook
Manual
There's only one guide that I could find for the A45. It should help, depending on how far you have the machine torn down.
http://www.irisvista.com/tech/laptops/ToshibaA45/Satellite-A45-remove-hinges-1.htm
Toshiba Satellite A45-S250 Notebook Logo
177 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
