Question about Microsoft Windows Vista Ultimate Edition
About installation of Turbo C in vista operating system
I installed turbo C in my laptop which has vista OS through pen drive of my friend who uses XP.It is functioning properly but i am not getting its full screen view.i gave altenter command after that it showed me the message that system doesn't support full screen view.what should i do?
  • aniket111 Dec 23, 2008
    i have the same problem of not getting turbo c in full screen mode,what will i do to get it ,pls suggest?
    Master:
    Sergeant:
  • 449 Answers
Hi!!!!!
download the latest updates in turbo c plus
or download C++ for windows vista
Posted on Sep 19, 2008
I am using windows 7 ultimate 64 bit OS. i am having turbo c++ 32 bit software.how can i install it in my laptop...
The Turbo C++ you are trying to install is just incompatible for your OS. Because your OS is of 64-bit and you are trying to install 32-bit one. Try to find a 64-bit Turbo C++ program.
You can try downloading this one for 64 bit compatibility:
Turbo C++ for 64bit
Dec 19, 2010 | Computers & Internet
My friend accidentally reformatted my sony vaio vgn-cr23g model and install a different operating system which is windows7. but my laptop have a pre-installed os which is vista, how and can I still use the...
hi once you install another system in preference to factory default in your case vista im afraid you have probably wiped all the on board data that deals with factory default.the only recourse is if your system is sata.you could install a second hard drive ,and put vista on that drive.hope this helps.
Aug 29, 2010 | Microsoft Windows Vista Ultimate Edition
I m using vista home premium 64 bit opreting system & i am unable to run some of the softwares that run on 32 bit OS like TURBO c/c++ compiler. every time i try to run it it shows the message "the...
There are compatability issues with many of the 32 bit software titles. The 64 bit version of Vista is not backwards compatable with all titles of 32 bit Vista. You will have to down load the patch or 64 bit version of the titles you are having trouble with. You can try to run it in compatability mode but things like Turbo C/C++ will not function in that mode correctly. They won't debug right.
Oct 12, 2009 | Microsoft Windows Vista Ultimate Edition
How to run turbo c++in vista 64 bit os
You can run Turbo C++ 3.0 on Windows XP 64 bit , Vista 32 bit and 64 bit OS (in full screen)
Install the software DOSBox ver 0.72 (Freeware) from the link below (Direct Link)
http://prdownloads.so urcef orge.net/dosbox/DOSBox0.72-win 32-in staller.exe?download
Before going to the details u have to create a folder (any name will do).
Here we name it as Turbo
Copy the TC into the Turbo folder
Run the DOSBox 0.72 from the icon located on the desktop or from the location of the installation folder
Then u are presented with two screens which look like the command prompt in Windows
Now u are presented with two screens. One with a Z prompt. U can ignore the other screen.
There type the following commands at the command prompt [Z]:
Mount [Type in any alphabet that u wish except z] [Type the source of the turbo C] press enter
For example (Type in the following commands after the Z prompt):
Z: mount d c:\Turbo\ [The folder TC is present inside the folder Turbo]
* Now u should get a message which says: Drive D is mounted as a local directory c:\Turbo\ ***
C:\> cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
source site :
http://mycomputer.freefor ums.o rg/running-turbo-c-in-full-scr een-m ode-help-t1241.html .
Sep 03, 2009 | Microsoft Windows Vista Ultimate Edition
Problem for installing turboc++4.5 in wista
ok man i too had teh same prob dont back to xp
Before going to the details u have to create a folder (any name will do). Here we name it as Turbo
Now , Type in the following commands after the Z prompt:
Now type d: to shift to d: prompt .
D: cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
D: cd Bin
D: TC or Tc.exe [This presents u the Turbo C++3.0 screen]
On the Turbo C++ goto Options>Directories>Change the source of TC to the source directory [D] ( i.e. virtual D: refers to original c:\Turbo\ . So make the path change to something like D:\TC\include and D:\TC\lib respectively )
In order to get the full screen use the key combination of Alt and Enter
When u exit from the DosBox [precisely when u unmount the virtual drive where Turbo C++ 3.0 has been mounted] all the files u have saved or made changes in Turbo C++ 3.0 will be copied into the source directory(The directory which contains TC folder)
It is a good idea to backup your files in the source directory prior to running DOSBox 0.72
For additional help go through the readme file located in the installation folder or look on the website of the DOSBox forum.
The above procedure has been successfully implemented on Windows Vista Ultimate 64 bit
IMP : Don't use shortcut keys to perform operations in TC because they might be a shortuct key for DOSBOX also . Eg : Ctrl+F9 will exit DOSBOX rather running the code .
Jun 17, 2009 | Microsoft Windows Vista Ultimate Edition
Turbo-c++ is not installed in full screen
Hi sagar,
Turbo C++ 3.0 is made for MS DOS 6.22 environment. In windows also we can run Turbo C because windows environment provides all native services of DOS. But in Windows VISTA some of the services are revoked. So to enable them either Vista is to be reconfigured or some add-ins are to me installed.
Other versions those can work in Vista are BOROLAND C++ 4.5, VISUAL C++ 6.0, and Visual Studio 2008. But in all these the graphics header file <graphics.h> will not work. Try to find an appropriate graphics header file or copy graphics.h in the cource directory and use #include "graphics.h" command in your C Program.
Please revert to me if having problems.
Zulfikar Ali
ali_zulfikar@yahoo.com
09899780221
Jan 31, 2009 | Microsoft Windows Vista Ultimate Edition
I have an easier solution. Please check my blog for more details http://cybercomments.blogspot.com/
Nov 10, 2008 | Computers & Internet
How to install turbo c in vista home basic compaq pressario lapto??
how to run turbo c in full screen mode on vista operating system.
when i am running turbo c it's gives  a message that vista not support full screen. what should i do please suggest me.
Sep 13, 2008 | Compaq Presario Notebook
Microsoft Windows Vista Ultimate Edition Logo
75 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
