Question about Logitech 967437-0403 Keyboard
Keyboard click how do I remove the clicking noise fromt the keyboard when keys are depressed
  • mkdande Sep 23, 2008
    this did not work any other, no window came up to turn off noise.
  • Anonymous Apr 14, 2009
  • 21 Answers
I think u will hear the noise whn u pressing shift ,ctrl,and alt keys continusly na..these keys r called sticky keys.....pls press these keys 5 times continusly thn one window will come in that window thr is a option called turn off sticky keys pls tick the box u can remove the noise k
Posted on Sep 20, 2008
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    I hear a cclicking noise when I step on break when key is on. I don't hear the click while car is running. Its a 97 infinity q45
    Most automatics have a lock on the transmission selector.
    When the vehicle is in P (Park) you are not able to select drive or a gear unless you depress the brake pedal.
    My Audi Q7 ha a solenoid and you hear it click when I put my foot on the brake.
    This solenoid stops you from accidentally selecting a gear without the brake depressed.
    Is it a single click when you depress the pedal.
    Or is it a constant click click click ?
    Apr 28, 2015 | Infiniti Q45 Cars & Trucks
    How can i unlock my keyboard
    Recognize that you have a locked keyboard.
    If your PC computer is not responding to keystrokes or is responding very slowly, you could have a locked keyboard.
    Use your mouse to move the pointer over the "Start" button.
    Use the left-click button to bring up the "Start" pop-up menu.
    Position the pointer over "Settings" and use the left-click button to select. T
    hen select "Control Panel." On some versions of PC operating systems, you can select "Control Panel" directly from the "Start" menu.
    Select "Accessibility Options" to bring up another menu, then select "Keyboard."
    You'll see three options that have check boxes.
    Make sure each check box does not have a check mark in it.
    The three options are "StickeyKeys," "FilterKeys" and "ToggleKeys."
    Note that these options can become checked if the keyboard operator has repeatedly depressed the "Shift" key in rapid succession--or if the "Shift" key is held down for longer than eight seconds.
    If the keyboard is still not responding, the problem could be that the computer has lost communication with the keyboard.
    Turn off the computer.
    Disconnect the power supply.
    Remove and then reconnect the keyboard cable, then reconnect the power supply.
    Turn the computer on.
    This will reboot the computer, allowing it to recognize the keyboard.
    hope this helps
    Oct 03, 2012 | eMachines Computers & Internet
    I have a problem regarding my lg x110 notebook. some keys are not working properly like the letter g on the keyboard, when i hit the letter g it appears letter c on the monitor same as letter t and z and...
    Examine your keyboard for any build-up of dust, dirt, liquids or other particles that could be causing the keys to type the wrong characters. Allow any loose dirt to fall out by inverting and shaking the keyboard lightly.
    Confirm that your keyboard is set to the English language. Go to your control panel and click on the "Regional and Language Options" icon. If the setting appears to be in a foreign language, change it to English/U.S.
    Check if your number lock key is on. If so, depress the key to disengage it.
    Run a character key test by using the Microsoft Keyboard Diagnostics (MSKEY) program. While in the MSKEY program, hit several keys to make certain that they are the same keys that are identified in the MSKEY window. To start MSKEY in Windows Vista, select "All Programs>>Accessories>>Run" from the Start menu. Type "mskey" in the box and depress the "OK" button. Start MSKEY In Windows XP by clicking on "Run" from the Start menu. Type "mskey" in the Open box, then hit "OK." Depress either "PS/2" or "USB" to apply it to your type of keyboard hookup. MSKEY software is only available with Microsoft IntelliType version 1.1 or later.
    Remember to clean your keyboard regularly to keep it free of dust and debris.
    Don't disassemble the keyboard because it may affect the validity of your manufacturer warranty!
    May 08, 2011 | LG Computers & Internet
    Hacer documentos
    Create a New Document
    There are several ways to create new documents, open existing documents, and save documents in Word:
    • Click the Microsoft Office Button officebutton.gif and Click New or
    • Press CTRL+N (Depress the CTRL key while pressing the "N") on the keyboard
    You will notice that when you click on the Microsoft Office Button and Click New, you have many choices about the types of documents you can create. If you wish to start from a blank document, click Blank. If you wish to start from a template you can browse through your choices on the left, see the choices on center screen, and preview the selection on the right screen.
    Opening an Existing Document
    • Click the Microsoft Office Button officebutton.gif and Click Open, or
    • Press CTRL+O (Depress the CTRL key while pressing the "O") on the keyboard, or
    • If you have recently used the document you can click the Microsoft Office Button and click the name of the document in the Recent Documents section of the window Insert picture of recent docs
    Saving a Document
    • Click the Microsoft Office Button officebutton.gif and Click Save or Save As (remember, if you're sending the document to someone who does not have Office 2007, you will need to click the Office Button, click Save As, and ClickWord 97-2003 Document), or
    • Press CTRL+S (Depress the CTRL key while pressing the "S") on the keyboard, or
    • Click the File icon on the Quick Access Toolbar
    Renaming Documents
    To rename a Word document while using the program:
    • Click the Office Button officebutton.gif and find the file you want to rename.
    • Right-click the document name with the mouse and select Rename from the shortcut menu.
    • Type the new name for the file and press the ENTER key.
    Working on Multiple Documents
    Several documents can be opened simultaneously if you are typing or editing multiple documents at once. All open documents will be listed in the View Tab of the Ribbon when you click on Switch Windows. The current document has a checkmark beside the file name. Select another open document to view it.
    Document Views
    There are many ways to view a document in Word.
    • Print Layout: This is a view of the document as it would appear when printed. It includes all tables, text, graphics, and images.
    • Full Screen Reading: This is a full view length view of a document. Good for viewing two pages at a time.
    • Web Layout: This is a view of the document as it would appear in a web browser.
    • Outline: This is an outline form of the document in the form of bullets.
    • Draft: This view does not display pictures or layouts, just text.
    To view a document in different forms, click the document views shortcuts at the bottom of the screen documentviewsshort.gif or:
    • Click the View Tab on the Ribbon
    • Click on the appropriate document view.
    Close a Document
    To close a document:
    • Click Close
    Jan 04, 2011 | Microsoft Office Standard 2007: Windows
    Laptop Keybord is not working properly. If we click on one letter it is showing another letter.
    Download and run Ccleaner here:
    Run cleaner and registry cleaner. then:
    Plug your keyboard into another computer. If the keyboard works, then the port on your original computer may not be working.
    5
    Tips & Warnings
    Clean your keyboard regularly to keep it free of dust and debris.
    Don't disassemble the keyboard because it may affect the validity of your manufacturer warranty.
    Good luck. If this helps please consider giving me a good review.
    Thank you and good luck
    Oct 19, 2010 | Acer Computers & Internet
    Right touchpad key no longer works
    Try to make sure the key is not depressed. If it is, you can try to remove the palmrest (plastic that extends from the left to the right side of the computer below the keyboard) and try to put the key back in place. You can check the manual at support.dell.com to know how to remove and reinstall the palmrest.
    If this doesnt work, you must replace the palmrest. Obviously it's a defective hardware. You can call dell's spare parts sales and order a palmrest at 8773723355.
    Nov 02, 2008 | Dell F3534 Touchpad
    Computer is locked in the green symbols of the keyboard
    TO SHUT OFF the green keys, you need to disable the multiligual or French keyboard layouts. For Windows 7:
    Click CONTROL PANEL
    click CLOCK, LANGUAGE, AND REGION
    under REGION AND LANGUAGE
    click CHANGE KEYBOARDS... etc.
    click KEYBOARDS AND LANGUAGES
    .......for example, by clicking on a keyboard name (ie. US or and UNITED KINGDOM for example) and then clicking PROPERTIES to the rtight, you can see the actual key layout.......
    On the list of installed languages, click anything multiligual or French, and then click REMOVE found on the right-hand column
    click APPLY
    click OK
    Then you've removed the French.
    Otherwise you have to click the LEFT ALT key and then the LEFT SHIFT key to swich back and forth between the green keys and the white keys.
    Jan 04, 2008 | Acer Aspire 5500 5570-2609 Laptop
    Keyboard
    Thers a conflick methinks between mouse and keyboard if not BIOS update you may need
    Sep 13, 2007 | IBM ThinkPad R50e Notebook
    Logitech 967437-0403 Keyboard Logo
    260 people viewed this question
    Top Logitech Computers & Internet Experts
    micky dee
    Brian Sullivan
    Brian Sullivan
    Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
