Question about Canon PIXMA MP810 All-In-One InkJet Printer
Error 6A00 in Canon MP810
Hello, I got a clarification request. I have my printer with that error, but seems that the problem is in those ink absorber cushions. I opened my printer to get to the place but now i dont know what to do with it. I took out the cushion and now i am not sure what to check. Do yo have any suggestions?
  • 3 more comments
  • tabbed74 Sep 20, 2008
    here is a video.
    http://mx.youtube.com/watch?v=nAAxT75leg...
    i just forgot to say that there are two cushions, i still have not found the smaller rectangular one, but it seems that for the moment that is not the problem.
    at the end of the video u can see a white part moves to the opposite side. then u hear a noise like little engine is being forced, and then the error appears.
    i think this cushion should also move , no? now it does not move at all.
    it means that i broke it for good ?
    thank you.
    this is a video.
    at the end of the video you can see that a white part moves all the way, then you hear a noise like a little motor forcing, then error occurs.
    this cushions are down, at first they were not so down, and now they dont move anymore, i pressed them down and now they dont come up, which i suppose they should move up or something.
    the rectangular cushion i still dont find it, but i think that is not the problem for now.
    any suggestions, please,
    thank you.
    hello
    well thankx for the help. i turned the gears. at first even when i turned the gear, the cushions did not come uo and the purge unit (i think the white plastic part) did not go back and forth. so i decided not to turn carfefullr the gear and started to desperately make it turn back and forth until the cushions came up. i still dont know where one of the cushions is, i guess is somewhere in there but if i tried to dismantle it even more, i m not sure i can put it back together.
    i turned on the printer and seems that everytime is a different error, (now purge unit moves ok), first time came up the error code 5110, next time, was error code 6502, i ll turn it off and on to see what error i have. (i m using re-filled tanks), maybe that can be a problem now.
  • tabbed74 Sep 22, 2008
    hey stellatorty,
    I did what you said and until now is working!, Althought I feel that I really did not fix it, because I just moved things around hopping that the object jamming it go somewhere else. The small cushion is still lost, but in the meantime is ok, thanks for the help.!
  • Anonymous Feb 06, 2009
    error code 6A00
  • 39 Answers
What colour is this cushion? You should not be able to access them without major dismantling of the printer. If it IS an ink absorber it will be white (other than where ink is)
Posted on Sep 19, 2008
  • Paul Bell Sep 20, 2008
    At the front right of the purge unit which is the unit with the cushion, you will see some white gears. Carefully with a small flatblade screwdriver you can turn these gears and the slide should operate and the cushion should lift. If it does not there may be something underneath jamming it.
Error6A+MP810 No print, no scan, no normal operation
12 times AP position error [6A00] An error occurred in the AP motor during purging
operation.
- Sheet feed unit
- Purge unit
- Logic board*
Try to manually move print head at left position and then try torotate the gears of purge unit, if it moves (purge unit) switch off and on printer
Jan 12, 2010 | Canon PIXMA MP810 All-In-One InkJet...
How do I remove the print head from my Canon MP810 printer for a clean? :o)
I just replaced my MP810 printer head. Procedure: open printer - remove ink cartridges - Pick up arm located on right side of cartridge holder- remove printer head by picking up by the cartridge slots. Place new printer head in holder - replace printer cartridges - press arm down and your done....However, the error message stays on and reset procedure doesn't remove it. Canon tech support said their solution (because of distance from canon support) is to replace MP810 with comparable printer, which came to $299 with 15% discount and free shipping. My solution, I’m checking out other printers.
Jan 11, 2010 | Canon PIXMA MP810 All-In-One InkJet...
My canon mp810 get error code 6a00 what i must got to do??
this error belongs to carriage jam or mechanism .... my point of view go for a service center and fix it ...if you try you won it may damage your printer
if you want to fix this problem in your own goes through below link may it help you
http://www.fixyourownprinter.com/forums/inkjet/37440
Dec 10, 2009 | Canon PIXMA MP810 All-In-One InkJet...
Error Code 6A00 is appearing and does not change no matter what I do (shut down, change ink cartridges, restart, etc). Any ideas? Thanks
6A00 means the purge assembly on the right where the printhead parks, is jammed and cannot move. If nothing is caught in it you will need to have it replaced. The part is around $30.00
Aug 03, 2009 | Canon PIXMA MP810 All-In-One InkJet...
Canon MP810 Error Code 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 22, 2009 | Canon PIXMA MP810 All-In-One InkJet...
Mp810 printer
That error code refers to the AP position during the purge operation., basically is means there is an error in the purge unit of the printer, either the purge unit is out of position or there was a power issue while the printer was shutting down. So it could be as simple as removing any foreign object in purge unit or it could be the sheet feed unit, the logic board or the purge unit.
I hope this helps you to understand what the printer needs. Good Luck with it.
Oct 29, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Canon Pixma MP810 Error messages 6A00, 5110, 5C20, 5100
Pixma pro 9000
service error 5110 after paper jam.
BEST QUICKEST WAY TO FIX THE PROBLEM!!!!
DUST BLOWER ALL OVER THE AREA INSIDE
AND TURN IT BACK ON U SHOULD HAVE SOLID
GREEN LIGHT FOR SURE!!!!!!!!
DAMN I CAN'T BELIEVE I BROUGHT THIS SAME PROBLEM
TO SERVICE CENTER THE FIRST TIME!!!
NO MORE WORRIES!!!
Oct 25, 2008 | Canon PIXMA iP5300 InkJet Photo Printer
Cannon MP810 when turn on display error A600. There is also no light displaying on the printing cartridge.
A600 or 6A00. If 6A00 then the fault code is for the AP motor position error. Error lies with the sheet feed unit, Purge unit or Logic board.
http://www.tradebit.com/filedetail.php/4588588-canon-pixma-mp810-printer-service-manual
This is a complete service manual
Sep 14, 2008 | Canon PIXMA MP960 All-In-One InkJet...
Canon Pixma MP 810
Try moving the cartridge unit back and forth a few times, this usually works.
Jul 15, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Canon iP4300 service error on my printer
dear
Don't waste money on Printer Ink. Save up to 65% on toner cartridges, ink cartridges and printer supplies. <a href="http://www.concordsupplies.comhttp://www.concordsupplies.com">http://www.concordsupplies.com</a>
May 28, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA  MP810 All-In-One InkJet Printer Logo
669 people viewed this question
old marine
old marine
