Question about HP Pavilion DV4015cl Notebook
HP Pavillion DV5000
Computer turns off very quickly. It only stays on five to ten minutes, even when the battery is charged. Sometimes it takes a very long time to turn on. It generates a lot of heat.
  • Anonymous Jan 11, 2009
    I have the same problem with my hp dv5000 series. turns off after overheating. checked the overclocking looks like its not the issue. changed the fan already but it seems to help only a bit but doesnt completely fix the problem. Battery works great so does the charger. Im guessing its something wrong with the motherboard..
    Genius:
  • 1,689 Answers
Hmartinez, there is a strong possibility that the power management on your computer has failed or is failing. if you have not replaced the battery ever since, i suggest you have the battery checked, or replaced.
you may also try to isolate the problem by plugging the charger to the machine without the battery to check if you will have the same issue, if yes, then there is a possibility that the machine is overheating.
if you have other questions just lemme know./
Posted on Sep 19, 2008
HP Pavilion DV5000 battery charging problem
Sounds like you need to calibrate the battery, it is supposed to be done every 3 months. If it is not done, your battery will display the same symptoms are you describe. Yes, this holds true for adding a new battery also.
Here is HP's instructions on how to do it. You want to scroll down to the section called "Calibrate the notebook PC battery".
http://h20239.www2.hp.com/techcenter/battery/Battery_max.htm
Feb 27, 2010 | HP Pavilion dv5000z Notebook
Battery with HP Pavillion DV5000 won't work. Do I need to replace the battery or is there a battery charger I could use to recharge the battery? Dianne
You can order a power cable online or pick one up at your local computer store. They should run between $80-150. The battery itself is very expensive to purchase but is rechargeable.
Oct 22, 2009 | HP Pavilion DV4015cl Notebook
HP PAVILION DV5000 NOTEBOOK BATTERY LOCK TABS BROKEN OFF
You can take it to any HP service center. They'll replace it free of charge if its under warranty and does not have any physical damage.
Sep 27, 2009 | HP Pavilion dv5000z Notebook
HP PAVILLION DV6000 REPORTS BATTERY NOT CHARGING
Your battery is dead when it no longer will hold a charge. Replace your battery.
Jun 02, 2009 | HP Pavilion dv6000z Notebook
Hp Pavillon 8000 laptop will not power up,
This is caused by a circuit breaker in your laptop. when it is overloaded it will kill the power on your computer. you might have a faulty cooling system internally and you need to take it to a shop to repair
Dec 03, 2008 | Computers & Internet
fixed it ( it is bios problem) but besure to down load the fix before formating or use win 98 to fix it
Jul 07, 2008 | HP 530i (Q6750A) DVD±RW Dual Layer...
Computers & Internet Logo
709 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
