Question about Zanussi Dishwashers
WATER NOT HEATING IN MODEL DE 6850 Zanussi DISHWASHER
  • 126 Answers
YOU NEED TO LOCATE THE THERMOSTAT AND CHECK IF ITS WORKING CORRECTLY IF THE READIND ON THE STAT IS FINE YOUR ELEMENT MIGHT BE FAULTH.BEST YOU GET A TECH TO ASSIST YOU AS ITS A TUFF JOB TO DO ALONE.
GOODLUCK.
MOHAMED
Posted on Sep 19, 2008
Unit is not heating water
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker
Apr 22, 2011 | Zanussi Dishwashers
DE 6850 not drying
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 16, 2010 | Zanussi 24 in. DE6850 Free-standing...
Water not heating up
There is a small round solinoid that might have blown its just under the element, you could try this, it cheaper option.
Jun 28, 2010 | Zanussi 24 in. DE6744S Free-standing...
Electrolux de 6850 dishwasher
I followed some of the good instructions already on Fixya. I had checked the heater and it was o.k. I then took the front door of the washer apart to get at the control box. Sure enough, I also had the common design fault. One leg of the rely had scorch marks and was now disconnected from the circuit board. I will solder tonight and test. I include a photo of the burned board. TNoel P8017c86.jpg
May 07, 2009 | Zanussi 24 in. DE6850 Free-standing...
Dishwasher not heating Zanussi
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
heatman101
lmnbv
Mar 30, 2009 | Zanussi 23 in. ZDi6053SX Built-in...
Zanussi da4342 dishwasher
The dishwasher should heat the water to about 55 C as the heating cycle starts. In these cycle, the dishwasher pauses after has filled with water and wait for the water to reach the temperature. If the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues.
Another possible reason is that the timer unit is defective. If you have observed anything different post a comment.
Jan 12, 2008 | Zanussi 18 in. DA4342 Free-standing...
Zanussi dishwasher
hi there sounds like a possible dry joint on the pcb repair and try first
Nov 26, 2007 | Zanussi ZT485 Built-in Dishwasher
Zanussi de 6850
I've just had similar - seems to be a problem in the controller module - they're reasonably inexpensive online.
Undo the top-part of the door, about 5 screws across the top and side - the top section pops out, and the control module is now on the inside - if you free off the connectors (not too simple, but doable) you'll probably find some scorch marks on the PCB ... hopefully the wiring isn't damaged, and you can just replace the PCB ...
If you also have wiring damage, well, trace back and replace as required
(probably too late for the OP, but worth recording in any case)
Oct 26, 2007 | Zanussi 24 in. DE6850 Free-standing...
if you have a continuity tester (ohm-meter), then yes, you can find the fault. check the heating coil located at bottom of wash basin and trace to wire connections and test for very low ohms through this coil...if not very low ohms (2-10 ohms) found then replace coil. if coil test ok, then continue tracing wires to source driver for any possible fault such as bad over temperature breaker (or fuse) or bad contactor.
Aug 10, 2007 | Electrolux 24 in. ESI6220X Free-standing...
Dishwashers Logo
314 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
