A
few days ago, I found a
password reset
product
Windows Password Seeker which has been recommended at about.com and use it to
remove
my lost password successfully. It is a very easy
and helpful
utility.
Follow
the step-by-step instructions at http://www.passwordseeker.com/howtouse.html
Are you sure that you are resetting the password for the correct account?
If the password is right, then maybe the account name is wrong.
I'm always asked to type my password.When I do it says I need to verify my account which basically means I have to type my address and password again.The same thing happens again and I'm still refused access.Two error codes keep appearing,they are 80048821 and 80048823.After typing the address and password,the address remains but the password disappears when I press submit.
A. Create App Password in Microsoft Account 1. Open your Microsoft account security settings page by clicking on following link:how that helps good luck.
Open Microsoft Account Security Settings Page
2. You'll see "App passwords" section at the bottom of the page which shows following information:
Some apps and devices don't support security codes. In these cases, you need to create an app password to sign in. 3. Click on "Create a new app password" link and it'll immediately provide you a new password generated randomly.
Now you can use this new password to sign in to a 3rd party mail app or device.
B. Create Application Specific Password in Gmail Account
1. Open your Google account settings page by clicking on following link:
Open Google Account Settings Pag
2. Now click on "Security" tab given in left-side pane. Scroll down on the page and you'll see "Connected applications and sites" section at the bottom of the page.
3. Click on "Manage access" button and it'll open a new page showing following information:Some applications that work outside a browser aren't yet compatible with 2-step verification and cannot ask for verification codes, for example: email programs including Outlook, Apple Mail, or Thunderbird, older Android smartphones. To use these applications, you need to generate an application-specific password. 4. Type any desired name in given text box and click on "Generate password" button.That's it. It'll immediately provide you a new password which can be used in any mail app or device to sign in.PS: If you want to remove or disallow any mail app or device to access your account, you can remove existing app password or revoke access from devices using the same account security settings pages as mentioned in above instructions.
When you log in to MSN a website powered by Microsoft you also log in to its Hotmail and Messenger programs.
Hotmail is MSN's email program, while Messenger is an instant messaging and networking program.
Because Messenger and Hotmail are connected to MSN, if you have problems logging into one program, you'll likely have issues logging in to all of them.
Register for Account
The first step to logging in to any MSN-powered sites is to have a Windows Live ID.
This includes an email address, which acts as your username, as well as a password.
The email address must end in either "@hotmail.com," "@live.com" or "@msn.com."
Even though these emails use different domain names, all can be accessed by logging in to the Hotmail homepage.
If you try to log in to MSN or any of its partner sites like Hotmail or Messenger using anything but a Windows Live ID, you won't be allowed to access or create a profile and will be prompted to create a Windows Live account.
Incorrect Password
The most likely reason you aren't able to sign in to your MSN accounts is user error.
Entering an incorrect email address or password will return an error message, informing you that either the email address you provided isn't registered with MSN, or that you entered an incorrect password.
MSN and, hence, Hotmail and Messenger passwords are case sensitive, so check your keyboard's settings before retyping your password a second time.
If you don't remember your password but know your Windows Live ID, you can opt to reset your password by answering some security questions pertaining to your account.
Browser Issues
A slow browser can impact your ability to log in to your MSN accounts.
Try deleting your browser's cookies and clearing its cache before attempting to sign in again. This process varies from browser to browser.
For example, in Internet Explorer, click on the gear icon, "Internet Options" and click "Delete" under Browsing History.
Check the "Cookies" box and click "Delete."
Internet Issues
A slow Internet connection can also hinder your login attempts.
Check your Internet connection to make sure you're connected to the Internet.
Also, check that you're working online instead of offline, which can prevent you from logging in.
Click on the "File" tab at the top of your browser, and make sure there's not a check mark next to the words "Work Offline."
If there is, click on the words to uncheck that option and sign in again.
There might be some interference from another browser
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Click on the tools at the bottom of the drop down list will be internet options or
click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in MSN.com) or you preferred home page and browser
below that will be change search defaults click on settings you will see all search providers you have if dont need any of them you can disable or remove them.
Hope this helps.
What happens when you attempt to reset your password?
It took a while before I managed to get to that stage as I kept following the advice links but the layout meant I kept going round in a loop without actually getting that far.Eventually I managed to re-set the password but it was still rejected,so I've really no idea how to progress.
