Question about Bestec (ATX-250-12E) 250-Watt Power Supply
Emachine t2245 - won't start - suspect power supply
Before I buy a new power supply, how can I check to make aure that it did not fry the motherboard .
Thanks.
Jim
  • 1 more comment
  • Bryan Mildort Dec 03, 2008
    I have the same problem, but swapping out the power supply did not resolve it. I think that it may be the motherboard, and I am currently looking for a replacement.
  • larrynels02 Feb 01, 2009
    have same problem with our emachine D2046. suspect power supply since computer wont turn on,not even a light or sound,its just dead.how does one check power supply and mother board?
  • Anonymous Feb 11, 2009
    I have the same problem power supply on an e-machines 250 watt 4 pin I want to order it have the money for it but, if i order it what guarantee do I have its going to work or if it is the mother board. HELP! Normal that all these machines have the same problem or coincidence
E Machine T 2245 wont start power supply 250 what shall I do? Prince Michael @ Rocket mail.com
Posted on Jul 13, 2009
  • 5,568 Answers
It would be a rare incident to have a dying supply cause damage to the board, which is however, not to say that the reverse can't happen; i.e. you could replace the supply and still not have a working unit.
About the only thing you might do is note the position of the individual leads and colors on the main connector, forget the other ones, and measure from one of the ground pins (always black) to each of the other pins, noting the resistance values you find. If you are lucky, the supply may have a chart crossing the colors to voltages; unfortunately they are sometimes not there.
The 12 volt board contacts (+ & -) should measure fairly high (50-1k Ohm or more) the 5V can measure pretty low without being a problem, could be in the 5-20 Ohm area; this is a high current output. Unless black (to black), none of the leads should measure in the tenths of Ohms on the lowest scale.
Since there have been some changes in available outputs and connectors even on ATX supplies, make sure you compare pictures of the supply to your own but in any case, I would recommend using a replacment rated at 350W as this will run more conservatively and not be as stressed as the 250 you now have. It won't cost a lot more and will not consume any more power but the critical components will run cooler.
Not as a recommendation, just a current example on eBay:
http://cgi.ebay.com/Mustang-Switching-Power-Supply-350W-Model-LC-B350ATX_W0QQitemZ250294363195QQcmdZViewItem?hash=item250294363195&_trkparms=72:1156|39:1|66:2|65:12|240:1318&_trksid=p3286.c0.m14
The last couple I bought were $5 each with $7 shipping charge from a US source.
Posted on Sep 19, 2008
I'm trying to "rebuild" an old desktop computer of mine just to play and learn new things. It's an Emachines T2625 . Everything is in working order, but the integrated video seems to have went bad... I...
just start over and buy a motherboard and processor and memory and plug your stuff into it. you will need an operating system because the emachines operating system only workes with an emachines motherboard. emachines is the cheap brand from gateway and i have had nothing but trouble with those machines. Hope this helps and good luck
May 02, 2010 | E-Machines eMachines Desktop PC
I have an emachine t5026 that won't turn on. It sounds like a car tying to start and the lights on the front flash as does the light on the mouse, but it won't start.
Mar 29, 2010 | E-Machines Emachine T5026 power supply **...
I am trying to replace the power supply on my emachine model t2245 - I unplugged the old one and now not sure what and where all the plugs from power supply go?!?!? 0
well ill take a shot here, usuall in most circumstances the plugs should match up shape wise. the plugs for the harddrive and for cd ect. are all 12 volts so if the plug fits should be ok.
Oct 28, 2009 | E-Machines eMachines Desktop PC
The PSU fan does not run, computer shutsdown.
Check the CPU fan, it may be faulty and causes the CPU to overheat and shut down.
Sep 02, 2009 | E-Machines eMachines Desktop PC
On attempting to start desktop Emachine light flickered, went out and would not come on again. No sound of fan or any other activity. Checked cords etc. Could it be just the battery? If so where is it? I...
I'd bet your power supply fried the MOBO. I've had two relatives Emachines do this. Both were purchased around the same time 4-5 years ago. It is a known issue caused by the Bestec Power Supply and Emachines will not help you. Assuming this is out of warranty, your options are to replace the MOBO and power supply or to buy a new PC.
Apr 13, 2009 | E-Machines eMachines Desktop PC
Computer switched itself on and has not worked since.
It's either a dead power supply or a fried motherboard. Emachines are cheap junk, their power supplies and motherboards die all the time, just look around here on Fixya for proof. Instead of saving a buck, consider buying a better brand.
Mar 26, 2009 | E-Machines eMachines Desktop PC
EMachines T2245 won't turn on, front light stays on
IT CAN BE MANY THINGS 1 UNPLUG SYSTEM FROM THE WALL, 2 REMOVE THE MEMORY AND REINSTALL THEM, 2
CHECK ALL CONNECTION INSIDE THE COMPUTER CASE AND THE OUTSIDE TO, 3 TO REMOVE A POWER SUPPLY IS 4 PHILLIPS SCREWS POWER CONNECTIONINSIDE CASE, REMOVE THE POWER FROM ALL OTHER DEVICE CAREFULLY AND TAKE IT TO YOUR NEARST COMPUTER STORE, SAVE YOUR RECIEPTS IN CASE IT IS NOT THE POWER SUPPLY PROBLEM, RETURN IT AND GET YOUR MONEY BACK.
POWER SUPPLYS SHOULD NOT COST MUCH, IFYOU ARE STRAPED FOR MONEY GO TO GOOD WILL AND HAVE THE FIRE UP ONE OF THE SYSTEM THEY HAVE THEY MAY EVEN HAVE A NEW ENPTY TOWER CASE LAYING AROUND FOR 30.00 DOLLARS.
CANDYMANGANDY
Jan 29, 2009 | Bestec (ATX-250-12E) 250-Watt Power Supply
Emachines T2642 Motherboard
Dec 02, 2008 | E-Machines T2642 PC Desktop
H2862 Will not power up
This is a common e-machines problem. You were right to change the power supply. Most e-machines come with dangerously (fire balls shooting out the back) low powered power supplies that can even catch on fire. Most people install their power supplies for e-machines backwards meaning they put the 20+4 pin connector in the 4 pin connector next to the processor and it fries. Others don't do anything and the computer is just fried. It's one of the reasons no one should buy an e-machine. If you want someone to fix it for you or you want a new machine and your files transferred go to www.mindblowingidea.com/ComputerRescue and you can get PCs with XP Pro or Linux.
Dec 09, 2007 | E-Machines eMachines Desktop PC
Video problem after new power supply
You would get this error message when there is a connection problem between the monitor and the port on the back of the computer tower. Please ensure that the moniter cable is properly connected on the back. Get back to me with further observations. Good Luck
May 15, 2007 | E-Machines T2245 PC Desktop
Bestec (ATX-250-12E) 250-Watt Power Supply Logo
957 people viewed this question
Top Bestec Computers & Internet Experts
Allen Lightsey
Allen Lightsey
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
De ice
De ice
Are you a Bestec Computer and Internet Expert? Answer questions, earn points and help others
