Can not open the door after cycle is finished
  • welsh0806 Jan 17, 2009
    how do you get the door open if it doesn't open after waiting 3 minutes....i called and one support person told me to unplug it for 30-45 minutes and then retry...but it still doesn't work....HELP??
    thanks
    frustrated
  • dully1 Feb 10, 2009
    i have the same on my novatronic w980 ten yrs old front loader. but when i turned the mains off and on again it blew the fuse, only when i tipped forward the machine which emptied water from the sump, then re fused it .it then open ,but tried another short 30min wash and the same thing happend only this time when i pressed the orange door release button the button above it was going down with it ,this is the start button. wots going please help.thanks dully, mechanic.
    President:
  • 1,294 Answers
  • 958 Answers
I think you are talking about a front loading machine, have you waited for at least 3 mins before opening the door?
these types of washing machines locks the door in order to run. but after a cycle is finished, the door would not open right away, there is a delay on opening the door.
let me know what happened,
tnx 4 using fixya,
drcool
Posted on Sep 19, 2008
3 Suggested Answers
  • 104 Answers
SOURCE: Indesit wd 125. Wash cycle had finished, door lock was off but
Unplug machine, take lid off and locate the door lock. You will have to use a small screwdriver or something to release the lock. Then replace your door handle.
Posted on Jan 28, 2010
blueextc3221
  • 15935 Answers
SOURCE: Can't open door after any cycle but NORMAL
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Red light will not go out so I cannot open the door
Generally machine take time approx 5 minit to open automatically open the door if not open please check door switch or pcb
Aug 07, 2016 | Washing Machines
Dishlex DX203SX Dishwasher door wont close
check the lock maybe it flipped shut lock maybe getting stiff from steam?
Feb 07, 2015 | Dishwashers
Jan 19, 2010 | Washing Machines
Put clothes in washer HOTPOINT modelWML730 started
TURN MACHINE ON TO FINISH CYCLE THEN RE WASH WITH SOAP ETCH,DOOR WILL NOT OPEN MID CYCLE SAFTY LATCH,YOU CAN TURN PROGRAM TO FINAL SPIN TO EMPTY MACHINE AND FINISH PROGRAM THEN DOOR WILL OPEN
Jan 06, 2010 | Washing Machines
Top Load making noise. Wash cycle finished, open
bad lid switch.coupling broke and rubber burning or trans locked up
Nov 15, 2009 | Refrigerators
I can't open the door of my washing machine it is a front loader lg intellowasher 7 kg wd8013c please help asap
FOR ANY REASON THE WASHER MACHINE DIDNT FINISH ITS CYCLE!!! AND IT IS A SAFETY THAT IF DOESNT FINISH ITS CYCLE THE DOOR WONT OPEN!!!!
I HAD ONE LIKE THAT AND I BROKE IT APART!! AND I SAW THE WATER PUMP WAS THE PROBLEM SO I CHANGED IT AND PUT IT BACK TOGETHER AND LET FINISH ITS CYCLE AND OPEN THE DOOR!!! AND STILLS RUNNING!!!
Oct 05, 2009 | Washing Machines
Door will not open on my WM1480FHD after wash
Hi ii_goldie,What about the RINSE cycle... maybe the washer knows the "full cycle" is NOT finished.
The washer will display DONE... and make the door available to you. If not the cycle may not be finished. OR, turn it off, however, DON'T open the door if your machine has not drained all the water out, allow the system to finish.
Aug 19, 2009 | LG Washing Machines
Ge wall oven door will not open
If you can not open this door, then the problem probably is that you stopped the clean cycle before it was finished. Restart the cycle, and set it at the minimum of 3 hours, and then when it is finished, it will release the latch that locks the door. I had this problem last night, and after the cycle was finished, the door latch was released. Hope this helps.
Take Care
Feb 14, 2009 | GE JBP70SKSS Stainless Steel Electric...
Kitchen Aid Superba Wisper Quite will not start cycle
Intermittent door switch, should be available, easy to change out and inexpensive.
Aug 04, 2008 | Dishwashers
Bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
May 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
384 people viewed this question
Top Washing Machines Experts
