Question about Singer 3116 Simple
Bobbin winder wont engage properly
Bobbin was stuck on winder I yanked it and the holder came out with it
finally got it off now wont rewind bobbins
  • 1 more comment
  • goal6068 Sep 19, 2008
    need to rewind bobbins again
  • Anonymous Mar 13, 2014
    bobbin winder assembly broke
  • Anonymous Mar 24, 2014
    how to rewind the bobbin
  • 2,071 Answers
Just click below for the guide how to put the needle ;
Sewing Machine 101- Sewing For Dudes (and Ladies) No. 2: Stitches ...
Anatomy of a Sewing Machine. 1) Bobbin winder 2) Spool pin 3) Thread guide 4) Tension Knob 5) Foot and needle 6) Bobbin housing regards,
Hope it may helps you;
Regards,
VOTIT
Posted on Sep 19, 2008
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
Why can't I get the rewind bobbin to work?
Consult the owner's manual and verify that you are threading the bobbin winder properly and following all the steps to wind a bobbin.
If you are unable to get it to work, you can purchase a stand-alone bobbin winder at the local fabric store (JoAnns or Hancocks) or from Amazon.com for ~$25.
Nov 21, 2015 | Sewing Machines
My needle still goes up and down when I put the machine in the bobbin wind position.
There are two possibilities here; 1 you may not have the bobbin all the way down on the holder, 2 you may not have really engaged the bobbin winder. I would take the bobbin off, return the machine to sewing position, turn it off. Then turn it on, replace bobbin in position and re-engage the winder firmly! Good luck.
Jan 18, 2015 | Husqvarna Viking Emerald 116 Sewing...
How do I wind my bobbin
Bobbins are wound at the top of your machine. There is a post on the top right that your empty bobbin is slid onto, a chrome latch that pushes towards the bobbin. A spool of thread is set into another post, usually right behind the little bobbin winder post. A length of thread is guided thru a post at the opposite end and brought back to the bobbin-winder post. Nowthe power is engaged. At the time of power applied, the post upon which the bobbin is seated on, spins and accumulates the thread. Note: Bobbins must be removed from underneath the sewing stage to be rewound with new thread. Replacement is much the same as removal, with a plate that slides away, a reveals the shuttle where the bobbin is located. The rewinding happens at the top.
Nov 03, 2014 | Sewing Machines
Bobbin stuck on bobbin winder spindle
you might have to use some force but not enough to break
the bobbin winder spindle. it's also possible that there is something
wrong with the bobbin for it to get stuck on the bobbin winder spindle
like that.
Nov 29, 2012 | White Sewing 2037 Mechanical Sewing...
Bobbin winder won't work
it needs to be taken to a repair shop to be readjusted
May 20, 2012 | Singer Sewing Machines
Bobbin will not rewind
SE270D. Lift the bobbin and reposition, making sure it is down against the pin.
If this is not the problem, a Sidewinder Bobbin Winder (auxiliary bobbin winder sold with most sewing notions) is a lot cheaper than taking the machine in for service.
Mar 14, 2010 | Brother Sewing Machines
Bobbin winder shaft won't spin. LCD says bobbin winding.
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Jun 16, 2009 | Brother CS-8150 Computerized Sewing...
I need to rewind a new bobbin
My SE-270D bobbin winder is located on the top of the machine to the far right. From the picture of your machine it looks to be in the same place. The larger spindle is for the spool of thread and the shorter spindle is for the bobbin.
You need to wnd the thread around the bobbin a few times just to make sure it is started properly, and then move the bobbin either forward or backward to engage. (It's different on some machines.) You may also have to move the outer edge of the machine wheel (the large wheel on the outside right) to keep the needle from moving up and down while the bobbin is filling. When the bobbin is full the machine should shut off by itself.
Then you will have to re-tighten the machine wheel to engage the needle.
Hope this helps.
Apr 05, 2009 | Brother Sewing Machines
Singer 750 how to rewind the bobbing?
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Feb 09, 2009 | Sewing Machines
Singer 3116 Simple Logo
339 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
