Question about ASUS M2N-E SLi Motherboard
ASUS M2N-E SLi Motherboard No Graphics
Hi, i just built a new PC with the following spec:
BFG GeForce 9500 GT Graphics card
4Gb (2x2Gb) Crucial RAM (right type for MoBo)
AMD Phenom 2.5Ghz Quad Core
SeaGate 500Gb SATA II HDD
Sony DVD/CD/Everything Drive
The problem i have is that when i turn the computer on, everything seems to start ok, but nothing happens on the screen. There is also no beep from the PC.
I have checked power connections, Fans are working, HDD spins up, CD Drive has power, LED is on on MoBo, put graphics card in other PCI Express port, other monitor, other port.
Please could you advise on whats going on!
Many Thanks,
I have the same board (M2N-SLI) with a BFG 9800 GTX with no video either. I have the card in the black slot and I have 2 mem sticks in the yellow. Shouldn't make a difference if I'm using a monitor not an LCD right? Everything spins up for me too, hard drive, vid card has power, CPU fan is on, post (green) light is on.
Posted on Sep 25, 2009
I also have a ASUS M2N-E SLi Motherboard
After my hard drive died, i have had various problem getting my system up and running again.
Anyway, i had exactly same the problem you describe yesterday.
I found that if i took out 2 of my 4 x 1Gb stick of ram it started up ok just as it used to. I have spent the rest of the day expirementing only to find that i can use only 3 sticks and not the 4 i had been using.
Its working fine now, i just glad it is but with only 3Gb as i thought the motherboard had gone down the tubes.
Hope this helps
Posted on Dec 07, 2008
I have the same mainboard, and, as far as I can tell the board does not support More than Dual core.
If you can find or borrow a socket AM2 Athlon/Sempron Dual or single core and see of it will post then.
Also, IF you can get it to post (probably with the other processor mentioned above) you can enter into bios and try Updating -- Asus does not ocifcally state that it can run Quad core on even with this update -- some people claim it works but I have not tested it to know for sure. Download the file from SLI/ (or look to see if there is a newer one at Asus's Support Site.)
Unzip the file, place the 1204.bin on a flash drive, then get into the BIOS On the M2N-E Sli machine, use F5 to reset defaults (you probably have not had time to change them, but it is recommeded to set the bioos defaults before flashing) and Navaigate to the Tools menu and launch EZ Flash. From there it's pretty straighforward.
Only do this if you can't retun the mainboard at this point - Otherwise I would suggest you return it and find one that States it will support Quad Core Processors.
Posted on Dec 04, 2008
  • 2,351 Answers
Hi Will,
POST checks the motherboard, ram, & graphics card. You mentioned that the PCI-E card is connected into the black slot named PCiEX16_2. (I gather this is what you meant when you said, other). See the bottom of page 2-18. You must have the graphics card in the blue PCI-E slot (Named PCiEX16_1, see page 2-3 motherboard layout in your manual. Once this is done you should gain video display.
You must run your graphics card from this slot if you are running only 1 video card & you also need to make some changes in the bios as well. Turn to page 4-32 in your manual. AL-Selector. Set to Normal & set configuration to [Single video card]. After you change these setting save & exit the bios. Try not to freak out when you find windows does not show you all of the 4GB of memory you have installed. Please see the FAQ section on Asus web site. Click on this link;
As you read the above pages in your manual you'll find your x16 speed video card will only run at x8 speed if you install a single PCI-E card into the black PCI-E slot.
Everything should work out ok.
If you still do not gain video display just let me know & I'll go from there.
Good luck Will !
Posted on Sep 20, 2008
Hi can i install evga gforce 9500 gt video card
Yes, it will work just fine. Just make sure you uninstall the drivers of the embedded one before installing the new one and you disable it from the BIOS immediately after.
Apr 18, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Nvidia geforce 9500 gt gpu work on asus p5n73-am
Hi! can use that gpu with that mobo, but i wouldent recomend it. The GPU - Requires NVIDIA HybridPower™- enabled motherboard, and that mobo dosent have that. It might work but you cant use the full power of that gpu on that mobo. And beside that, that gpu is bigger then the mobo itself
I sugest you to buy another mobo, the gpu you looking at is a good one but your mobo isent that good.
Here is the spec for the GPU:
And here are the spec for that mobo:
Good luck
Mar 03, 2009 | Computers & Internet
Running dual bfg 8800gtx oc2
Hey, I own the same board, well the brother model, M2N-SLI and on both boards its the same, X8 when two cards are used, 16 when only one card is used, I have 8600GT two of them, previously used in sli, but now with 3 monitors I don't use sli at all, I still think both cards are working at x8 even if sli isn't enabled.
Sep 24, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Graphics card no display, not recognised
Hi DarkPredUK.
You need to check you're bios. (See below).
The PCI-E card (Single video card) must be placed into slot, PCIEX16_1 as shown on page 2-3 & 2-18 in you're user manual. The bios must be set correctly as seen on page 4-26 to PCI-E first. You must have two PCI-E cards installed to run SLI mode. (They must be exactly the same graphic cards).
Asus M2N-E SLI main web site/drivers, manual ect.
Good luck DarkPredUK.
Need more info? Post it here or click the Ask Me.
Jul 11, 2008 | Computers & Internet
M2N- SLI Deluxe Motherboard won't power-up
Look for blown capacitors. Check this site for example pics.
Jun 29, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
SLI Video Cards
Enter you're bios & open you're manual to page 4-32. Set you're
configuration to dual video card. Use the AL software to tweak you're settings in windows. If you find this not helpful than please call Asus tech at: 1-812-282-2787, M-F 8:00AM-5:00PM EST. Unlike other companies you will not be on the phone very long. Please have the S/N of the board handy. This is located on the board, on the LTP port (White sitcker).
Good Luck!
Jun 09, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Vista ultimate - Second card doesn't have enough resources???
thats 64 bit for ya.. welcome to buggy driver "if they support (beta)it"..
chipset, then video driver.. also vista has UAC issues. right click install as admin. good luck (i dont like vistuh)
Nov 26, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Compatible AGP at 16x?
After a brief check of motherboard specs, what I see is, the 7600GT card will run at 16x in the 16x slot, but if you have TWO SLI cards they both run at 8X. Makes sense. Unless there is a public outcry concerning this, I'd suspect the info you have is a bit off. ZT3000 "Beta tester of "0"s and "1's"
Aug 20, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS M2N-E SLi Motherboard Logo
1,416 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
