Question about Philips 60P8341 60" Rear Projection Television
Fungus in tube
Send me a email on instructions on fixing the problem
    Novelist:
    Champion:
  • 203 Answers
Email sent
Posted on Sep 20, 2008
Cant reach the center of the lens for fungus cleaning...
Are there two nested tubes involved? Male to female threading?
Feb 25, 2014 | Vivitar 500mm f/8.0 Mirror (Reflex) Manual...
During a 6 week trek in limestone country, we both noticed extensive white deposits in the tubes which impeded the flow of water. Assuming it was calcium carbonate, I have tried vinegar to dissolve it but...
The deposits may be a fungus that grows in camelbak, and other brands of, hydration systems due to sunlight shining on the wet plastic. It's possible that if you were using water containing lime that the lime has mixed with the fungus. To reduce the growth some systems have a black insulation which covers the drinking tube. There's a cleaning kit you can get which consists of 2 brushes, a narrow one for the tube and a larger one for the main water reservoir, and tablets which disolve or break up the fungus. You can get them at http://www.wiggle.co.uk/camelbak/cycle/hydration-system-spares/?utm_source=google&utm_medium=cpc&utm_term=camelback%20cleaning%20kit&utm_campaign=camelbak&referid=googwig&utm_agroup=Camelbak%20-%20Hydration%20System%20Spares
or if you look on google for "Camelbak cleaning kit" you might find somewhere near you that sells them.
The fungus is not harmful but it does put a taste on the water and doesn't look very nice.
May 20, 2011 | Camelbak 09 Classic Hydration Pk 70
Can't share u-tube videos by email
try saving the video to a smaller size. Maybe its too big or your email client isnt set for video transfer.
Jun 12, 2010 | YouTube Videos
Sigma 70-300 4-5.6 DL has some fungus & blur
Fungus etches the glass. This cannot be fixed by just removing the fungus. The lens has to be resurfaced, calibrated, coated and
well, you get the idea. lots of expensive precision equipment and a jig to recalibrate the focusing after you do all that.
Another 70-300 on Ebay is much less expensive.
Dec 18, 2009 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Rear projection tv screen is dark
This unit does not have bulbs it has tubes.What is happening is the coolant fluid in the picture tubes is contaminated with a fungus( blue and green).A repair shop should be able to fix this problem for about $250.I do not recomend fixing this problem youself,but when it is fixed this unit will look like new
Jan 12, 2009 | Televison & Video
Rear projector tv rear blue projector wont focus
Look into the top of the tube. Probably has fungus growth. Do a search. I posted that solution many times this week for that. Normally, focus don't go out on T.V's by themself. Either the tube is bad or has fungus or the screen control is bad.....but very rare will focus part fail...usually brightness/screen is at fault. Don't forget to check the green tube as well when looking. Take the back off and see if your head will fit. If not, a large mirror will do just fine. Put something on with writing displayed....easier to tell that way.
Dec 10, 2008 | Philips Magnavox 51MP392H Rear Projection...
Fungus in blue crt Akai rear projection
I don't have a pdf file for fungus in an akai, but you will need to remove the 2 tubes from the set, take off the cover for the reservoir and dump out the fluids and then fill them back up. you will then need to know how to do the convergence alignment after you put the tubes back in. This is a involved process, if you want to tackle this on your own let me know and we will see what we can do.
Tim Nolan
Sep 21, 2008 | Akai PT5492S 54" Rear Projection...
60" TV Tint does not work
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Sep 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Tint does not work.
This actually prabably being caused by a fungus in the tubes. This model is knowen for fungus to grow in the tubes and cause a pink or red tint. If you are interested in reparing this yourself you will need to change the coolant in the tubes. I have a PDF file that will instruct you on how to complete this. If you have a repairman do this for you you will most likly pay $300-$400 to have this fixed.
Let me know what way you want to go.
Tim Nolan
Sep 18, 2008 | Philips 60P8341 60" Rear Projection...
Phillips rear projection tv has a clear picture but has a pink tint to the screen. How do I fix it
The most common problem for this is a fungus in the coolant of the tubes. In order to fix this you will need to replace the fluid in the tubes. If you are wanting to tackle this yourself you will first need to take the back off and look down in the tubes, the red tube should look clear and the other two you will probably find look like there is some fungus inside them. If this is the case and you want to tackle it yourself, let me know and I will email you a PDF file on how to complete the job. A repair man should cost your somewhere around $300-$400 to fix it. If you look down in the tubes and they all look clear we may have a different problem, if thats the case let me know and we will troubleshoot further.
Sep 18, 2008 | Televison & Video
Philips 60P8341 60" Rear Projection Television Logo
19 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
