Question about HP LaserJet P2015n Printer
HP P2015DN My HP P2015DN Printer has the exclamation point & triangle flasing in the display. I have pulled all the paper trays out, fanned the paper and also turned the printer off for 10 minutues but the problem re-occurs. Not sure what to do. Any suggestions, what are those symbols
  • 3 more comments
  • Anonymous Sep 26, 2008
    I have the same problem. I changed the ink cartrigde too. It's very inconsistent.
  • A-K-N Dec 03, 2008
    i have the same problem
  • Anonymous Jan 06, 2009
    i have the same problem also
  • sally978 Feb 09, 2009
    The paper will print from Paper Tray 1, but not 2, it sounds like it is trying to grab hold of paper from Paper Tray 2 but it will not pick paper up???
  • Anonymous Feb 20, 2009
    same problem
  • 300 Answers
If just the triangle with the exclamation point in it is flashing, the printer is sensing the cartridge door is open
Posted on Sep 19, 2008
The triangle with the exclamation point inside of it is flashing, and I do not have the owner's manual to determine what the problem is. How to I troubleshoot this issue?
The manual is available online from hp web site.
probably either needs new toner or paper jam.
Please dont forget to vote if you liked my answer
Feb 09, 2011 | HP LaserJet P2015dn Printer
The triangle light is lit on the panel. What does
tooner goes to low or paper stucking any where in paper path..check for both ur problem will be resolved
Jul 30, 2010 | HP LaserJet P2015dn Printer
My printer won't print. (HP P2015dn)
If the triangle is on and the powe light is on too, is a Manual Feed or Continuable Error
This state can be reached in the following circumstances:
Manual feed,
General continuable error
  • Memory configuration error
  • Personality/Job related errorSOLUTION: To recover from the error and print whatever data is possible, press theGo button.If the recovery is successful, the printer goes to the Processing Data state and completes the job.If the recovery is unsuccessful, the printer returns to the Continuable Error state
    another reason is that the cartridge cap may be open or not closed, remove the cartridge and put it again, should work
    If you've put a dimm memory (memory expandable to one side of the printer, remove it and try one more time
    if you did not work, it may be a fan failure the printer, or the engine, or the DC controller, if that is your problem is preferable to contact an authorized hp.
    I have the same machine, it is good quality, and does not give many problems. regards
Apr 05, 2010 | HP LaserJet P2015dn Printer
When I try to print the triangle with an exclamation point flashes and doesn't print
This is the 'Attention' light. It indicates that the cartridge door is open, or that other errors exist.
Not great info, but you need to methodically eliminate the possible causes of the error....
1. Try putting some paper into the Manual feed tray / slot. It may be waiting for you to feed paper manually. Check your printer driver settings....
2. Press the 'Go' button. It will make it print from Tray2
3. Check your Printer driver settings, and 'Page set up' in the application
4. Switch the device off, and unplug the data cable.
5.Switch it back on.
6. Print a configuration page from the printer control panel by pressing the Go button (the green one) until the green Ready and Error light start blinking.
7. If it prints these pages successfully, then the problem may be elsewhere (PC software, application, corrupt data, etc) but check the settings on the Configuration page as well.
Make sure they match your system, paper size and type, feeding options etc....
Dec 21, 2009 | HP LaserJet P2015dn Printer
I am trying to print a mail merge letter and I keep getting the triangel with the exclamation mark lighting up. I then press the go button once or twice and one page will eventually print out but this...
    If you hear some noise like it wants to take the paper but does not, then change the paper pickup roller. First of this check if the tray 1 works well to make sure it's because of the roller tray 2.
Nov 14, 2009 | HP LaserJet P2015dn Printer
Won't print. The triangle with the exclamation point is blinking
may be the drivers of printer are not installed properly or ink might not be there or the ink has been dried.............kindly check for possibilities,,,,,,,,,,,,,,even check for proper connections
Oct 15, 2009 | HP LaserJet P2015dn Printer
Our printer will not print documents and it is giving us the exclamation point in triangle?
formatter board or main pc board is defective
need to replace but it is expensive,i'll recommend to buy a new laser printer.
Sep 28, 2009 | HP LaserJet P2015dn Printer
What does the light mean?
the ! in the triangle means manual feed or "continuable error" which means that the printer is manual mode. or there is a paper feed problem.
you need to check the HP print software, make sure all the printer setting are correct.
if so, then check the printer paper tray, make sure they are in working order, and there is no paper jam on the paper path from the tray to the output.
The manual feed use different paper path, so check the tray path.
then unplug the printer from the computer and shut down the printer.
wait 2 minutes, power up the printer and connect the printer tot he computer.
Dec 16, 2008 | HP LaserJet P2015dn Printer
Error light
it detected an error. try opening the paper tray to see if there are paper jammed. take out the the drum with powder and and turn off the printer. then put all back in place and turn on printer. usually the hp network printer is installed on the server. check on the server if you see on error from the hp driver program.
good luck.
Dec 06, 2007 | HP LaserJet P2015dn Printer
HP LaserJet P2015n Printer Logo
2,618 people viewed this question
Ben Johnson
