Question about Whirlpool GU2400XTP Built-in Dishwasher
Soap problems Not only won't the soap dissolve but there are granules on the inside of my glasses. The dishes are also not getting very clean.
  • performprint Sep 19, 2008
    I'm using Cascade which I have always used - this problem I do not believe is a result of the brand/type nor is it due to the water temp.
  • 126 Answers
PLEASE TELL ME WHAT TYPE OF SOAP YOU ARE USING AS WELL AS RINSE AID.NEED MORE DETAIL TO ASSIST YOU.
MOHAMED
Posted on Sep 19, 2008
  • MOHAMED UZAIL ESSACK
    MOHAMED UZAIL ESSACK Sep 19, 2008
    THANK YOU FOR THE FUTHER INFO.WHEN IT COMES TO SOAP NOT DISSOLVING THERE IS NOT MUCH THAT THE MACHINE CAN DO TO CAUSE THAT.YOU NEED TO CHECK IF THE WATER HARDNESS IS NOT ABOVE THE NORMAL OPERATING STANDARDS BEST YOU TOP UP YOUR SALT BOX REF TO USER MANUAL.IN SOUTH AFRICA WITH OUR CONSUMERS USING THE WHIRLPOOL BRAND OF APPLIANCE WE FOUND THAT 75% OF THEM WHERE USING THE 2IN1 OR THE 3IN1 SALT,SOAP AND RINSE AID.ITS BEST THAT YOU NOT USE THAT AND ALSO CHECK THAT THE SOAP IS NOT KEEPT NEAR MOISTURE AS THAT CAN ALSO CAUSE IT.
    LET ME NO IF YOU REQUIRE FUTHER ASSISTANCE.
    P.S. DO SEE IF THE SOAP POWDER AND RINSE AID BRAND NAMED (SUNLIGHT OR SUNLIGHT SUN) DISHWASHER POWDER AND RINSE AID IS AVAILABLE IN YOUR COUNTRY.
    GOODLUCK.
    MOHAMED
Dishwasher soap is not dissolving.
Try emptying the dishwasher and putting a few tablespoons of vegatable oil in the bottom. Run the cycle without soap and no dishs. Often dish soap (palmolive) builds up and creates soap suds that won't go away during a normal cycle. The oil binds with the soap residue to get rid of it. It worked for my Kenmore. I know do it every few months. Good Luck!!!
Thanks
Jun 22, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
Dirty dishes on Maytag 24 inch dishwasher, model no MDBH940AWS, Dishes have caked on gunk on the glasses after washing. The gunk is usually at the bottom of a glass (which is in the dishwasher upside...
This dishwasher has a circular filter path under the bottom plate - 6 screws - that can become filled inside with debris - you can remove it and wash it out with a garden hose.. Paul
Nov 20, 2010 | Maytag 24 in. MDBH940AWS Built-in...
Soap is left on the dishes
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
May 25, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
Kenmore Elite dishwasher will not dissolve soap or wash well.
Temperature should be 140F. and the units heater should energize during fill to achieve this.
May 19, 2010 | Kenmore 24 in. 15173 Stainless Steel...
Glasses do not get cleaned
HI, i recommend inspecting these areas below to combat this issue.
Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Jun 18, 2009 | Maytag Dishwashers
Soap hardens in the dispenser and dishes don't come clean
Either your dishwasher is not getting the water hot enough to dissolve the powder, or you need to switch brands. Try a liquid/gel type of dishwasher detergent.
Try stopping the washer a few minutes after you start a wash cycle. Open the door -- if there is a lot of steam coming out at you, it's not the water temperature. If there is no steam, your dishwasher is not getting hot water and/or the heating coil is not working.
Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
Not all of the soap dissolving, some left in dispenser and bottom
Kitchenaid lists 130 dishwashers with this model. Need the rest of the number
KUDSO1DLxxxx
Back in the day, when I worked on K Dishwashers, the drain valve was the problem typically.
It would get a piece of glass, from broken glass or other item, or a toothpick, whatever stuck in the drain valve. It would not completely close. During the wash cycle, water would be trickling down the drain and by the time the soap dispenser opens, the water would be gone or nearly gone.
Check this. When you hear the dispenser snap open, stop the dishwasher and open the door.
If you have little or no water, you are losing the water during the wash cycle.
Let me know.
Gary
Nov 22, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Soap problems
Either:
1. not enough water gets into the dishwasher. open the dishwasher 3-4 times during cycle, you should see some (quite some) water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Oct 21, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher detergent does not dissolve entirely. Gel is still on side and powerball tabs doe not dissolve. Dishes are not clean. It sounds like it goes through the cycles properly.
1. No waterMake sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
3. Clogged spay arms
4. Water temperature is too low
5. Not enough soap
6. Smoky film on dishes and glasses
Dec 21, 2007 | GE 24 in. GSD3400G Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
93 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
