Question about Whirlpool Refrigerators
Water dispenser on our Whirlpool fridge freezer seems to get an airlock from time to time and the water is dispensed noisily and in spurts! Any clues?
  • 126 Answers
TRY AND REMOVE THE PIPES THAT LINK THE WATER TO THE FRIDGE AND REMOVE THE AIR IN THE LINE ALSO THAT CAN BE CAUSED THROUGH THE MAIN WATER LINE TO YOUR HOUSE.
GOOD LUCK.
MOAHMED
Posted on Sep 19, 2008
My whirlpool fridge water dispenser won't dispense water but it shoots out a burst of water each time the door is opened even though I have the dispenser in the lock position.
I'd look for a pinched water tube where it enters the freezer door at the hinge. This would happen when you called for water, but got none because the tubing was pinched. Then, when you open the door and the tube flexes the pressure would be relieved and water would shower out of the dispenser (or on the floor if the tube was damaged.)
Oct 27, 2016 | Whirlpool Refrigerators
Water dispenser not working in my Siemens Fridge freezer
The water line is clogged or water dispenser valve is blocked.Click this link below for troubleshooting:---
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
This should help.Thanks.Helpmech.
Oct 30, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Hi, I have a side by side S20D RBB32-A/G Fridge Freezer with ice and water dispenser. The frezeer and fridge stopped working. I called a local repairer who took away a part for repair. However, the fridge...
Try checking the mesh screen which is in the water line where the water supply connects to the water inlet valve on the back. It can get stopped up with sediment.
Sep 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ed25rfxfw01 whirlpool fridge water dispenser
HI, I can help you. Is the water leaking from the freezer side?
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool american fridge freezer
Hi, this problem IS caused by components that have failed in the rear module! Fact!
There are a few people that sell the kits to repair them on a big auction site.
Hope this helps
bb
Aug 30, 2008 | Freezers
Whirlpool water dispenser not working model ED25RFW00
It is possible that you have an airlock in the chilled water section but not very likely. I would be more inclined to suspect that the water storage section in the fridge compartment (below salad section) has become frozen as I have experienced this before. I would suggest defrosting the cabinet completely and trying again, ensuring that you push the water valve for a long enough duration. Hope this is of some help.
Mar 13, 2008 | Whirlpool ED2FHEXN Side by Side...
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
Refrigerators Logo
159 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
