Question about Samsung Refrigerators
I need a replacement door for a Samsung Fridge / Freezer – Samsung RSJ1FERS , can you help please
  • andydibs Sep 22, 2008
    the door is dented and i would like it replaced for a customer of mine, i work for a building company and a removal firm we used damaged the door, the removal company have now gone into liquidation and we cannot get any compensation from them,hence trying to replace the door only
  • 126 Answers
FIRSTLY WHY DO YOU NEED TO REPLACE THE DOOR OF THE APPLIANCE.
MOAHMED
Posted on Sep 19, 2008
  • MOHAMED UZAIL ESSACK
    MOHAMED UZAIL ESSACK Sep 22, 2008
    FIRSTLY TO LOCATE A SAMSUNG DOOR IS GOING TO BE A BIT OF A HASSLE AS I HAVE COME ACROSS MANY PEOPLE WITH THAT PROBLEM I SUGGEST YOU TAKE THE DOOR TO A AUTO BODY REPAIR SHOP AS THEY MIGHT BE ABLE TO REPAIR IT CHEAPER FOR YOU
    GOOD LUCK.AND PLEASE RATE THE SERVICE.
    MOHAMED
    HI.FROM MY EXPERIENCE IN THE PAST I HAVE FOUND MANY PEOPLE HAVING PROBLEMS WITH SAMSUNG FRIDGE DOORS THEY ARE HARD TO GET AND VERY EXPENSIVE.YOUR BEST OPTION IS TO HAVE THE DOOR REPAIRED BY YOUR NEAREST AUTO BODY REPAIR CENTRE IT MIGHT BE CHEAPER THAN REPLACING AND TRYING TO LOCATE A NEW DOOR.
    GOOD LUCK AND PLEASE RATE THE SERVICE AND ADVICE,
    MOHAMED
Samsung French Door model number RF26J7500 freezer is not working properly but the fridge is fine. Help please
This makes no sense since it is the freezer unit that feeds cold air to the fridge unit. Now if you have two separate compressors, one for each unit, my comment does not apply. Did you reverse the two in your query?
Sep 08, 2017 | Samsung Refrigerators
Samsung Fridge Freezer Door Handle Came Off - No screws is it vacuum based.
The screws are in the holes on the side. You will need an Allen wrench to tighten them
Sep 29, 2015 | Samsung RSA1SHPN American Platinum Inox...
Fridge won't cool past 57 degrees
Guessing ether a fan, damper our defrost issue. Sorry cant be much help.
Aug 19, 2012 | Samsung RF266ABRS Bottom Freezer...
Just noticed that the bottom of samsung RFG238AA
Your settings should be -5 to -10 in freezer and +37 in the fresh food compartment. This will keep the unit from running too long and your floor temp to be normal..
Consult your users manual!
Oct 15, 2017 | Samsung RF265AA Bottom Freezer French Door...
Motor noisy, stops when open refrigerator door
i had this problem then turned off fridge freezer for 24hrs and it was gone it was more or less needing defrosted
Apr 29, 2010 | Samsung Refrigerators
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
Samsung Fridge Freezer Model RS20
Renee,
There are a few things we need to look at. The likely cause is frosting up of the coils. This will also stop the fan. The best thing to do is to defrost the unit completely. The easiest way to do this is to shut it down and leave the doors open for 24-48 hours. You'll have to mop up a surprising amount of water. Now, why did it happen? Probably humidity due to 'window shopping', not closing the doors/bad/dirty gaskets, leaving liquids in the box which are uncovered. If this doesn't fix it...and you'll know after a week or so, it may be that the unit is low on gas or has a defective defrost timer...but that is getting ahead of ourselves.
Jan 22, 2008 | Refrigerators
Samsung SRS2028CVW fridge freezer
check out this samsung diy repair channel on youtube ... some great stuff on samsung
samsung fridge freezer problems
Nov 02, 2007 | Refrigerators
Refrigerators Logo
163 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
