Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Unable to access external WD 500 Gb drive: "You need to format the disk"
500 Gb external Western Digital drive won't show any files on it. Purchased in Feb 2007. This happened several months ago. Could not get it to read any files on the drive. We reformatted it in NFTS file format. Ran fine until recently. Have tried other computers and file retrieval programs. Windows says "you need to format the disk in drive J: before you can use it." Properties shows 0 bytes used; 0 bytes free. Windows check says "the disk check could not be performed because Windows could not access the disk". Says the format is RAW. Device is working properly. I'm using Vista on my computer. Any hope for this drive or the files on it? Since it crashed twice, is the drive itself bad? Connie
  • 4 more comments
  • connielusa Sep 23, 2008
    I was using USB connector. It wasn't recognized on Vista or XP. I tried both. I think the drive was just shot for some reason. It started the death click so I sent it in for replacement since it is still under warranty. Hopefully they exchange it for one that won't cause trouble again. Thanks for the suggestions though. Connie
  • Jackblade Nov 21, 2008
    The same problam, i don't have power to write the prob. again...
    Sorry for the doubling but I want to sy another thing: I don't want to format it because all my life is in this and i don't wanna lose my life...
    Jack
  • Anonymous Dec 26, 2008
    Same thing, it's a Vista vs. XP problem.
    Sorry to say I don't know a fix...
  • Anonymous Apr 29, 2009
    see the hd ,but shows at raw filesystem... not able to open.... ;,,(
  • Richard Schabler Nov 04, 2012
    Question: Have you been able to access the files on this drive, using the computer and operating system that's failing to access it now?
    New Friend:
Have you formatted that 500GB external hard disk yet? Have you checked whether there is something different? Dose it show RAW in Disk Management? Honestly, about two weeks ago, my Seagate external hard disk keeps asking me to format and cannot be accessed. However, when trying to test it with CHKDSK, it just says the CHKDSK is not available for RAW drives. Hence, in order not to make things worse, I do have searched such external hard disk RAW file system issues and find RAW drive data recovery software is possible to take everything side back. So, I do not give up and try some of these tools found online. Luckily, I finally rescue most of my original drive files back.
Hence, if you are also interested, get one to take chances.
Posted on Nov 05, 2015
    Novelist:
  • 108 Answers
Another factor in this issue is the USB version too. There are two standard ones, and a USB3 in development. USB1 was the earliest and has minimum capabilities, USB2 can do more (including things the USB1 cannot recognize), and USB3 is more capable, and faster.
If you get a message, (I'm assuming Vista does the same as XP), when you plug the drive in saying, "This device can perform faster if you plug it into a high speed USB terminal. Click here to see available high speed USB ports", then you may have the option to use a USB port on your computer that is more capable.
I'd reccommend trying different USB ports on your computer, some are less capable than others, the ones closest to where the Keyboard usually plugs in, are the best.
One other thing I often find is that the USB ports on the front of the computer are often broken from things plugged in there getting banged with feet, or chairs. The 0 Bytes used, 0 Bytes available sign is often caused by an incomplete usb connection, the power is there, but the signals are not, simply try the plug on another USB port.
Hope that help find some solution.
Posted on Nov 04, 2012
I have battled this for a few days. Your mentioning USB leads me to a possible solution.
I had a 500GB drive and put it in the USB enclosure and could only see 128GB one time, 138GB another. I found that external drive enclosures have their own IDE controller chips with older ones limiting the size of the drive they are able to "see".
The best test is to internally mount the drive (perverts will read this differently than intended and risk injury due to shock!) to make sure it can be seen. If so then the next best step is to spring for a new drive enclosure, one that supports the higher capacity drive. It worked for me! My old external enclosure's IDE controller could not handle the higher capacity drive and the new one was perfectly happy with it. Good luck! - Andy C
Posted on Apr 09, 2009
It seems vista is the problem. On older operating systems the disk's work fine. My dis was formatted with vista and as a result showed exactly the same message when plugging it into a xp system. Back on the vista it works fine. The ntfs is native to win NT/xp there might have been changes in vista. Also do not use the firewire cabling, i had numerious problems until i reverted back to the usb.
Posted on Sep 23, 2008
How to recover my files from HD? I have Western Digital External hard Drive 500 GB.It was nearly full, such there was only 50 gb free space. Day by day it worked slow and one day It stopped working, not...
First thing first - STOP using your WD drive immediately! If you continue using the disk drive, you significantly increase the risk that the files you want to recover will be lost forever due to overwritten. Every new file or action will take up more "free space" and reduce your chances of retrieving your deleted files from WD. The next step - get a good HDD data recovery software to retrieve the data as most as possible.
Learn more how to get the job done from: http://www.western-digital-data-recovery.com/
Dec 27, 2010 | Western Digital Passport WDXML800UE...
External Disk WD Elements problem
did u format the wd 320 gb already
you have to format it first to work from it
Apr 06, 2010 | Western Digital Elements powered by WD 320...
I am having an issue with my WD5000h1u-00 500 GB external drive
Read this instructions my friend
It is possible to use a Western Digital external hard drive on botha PC and a Mac. However, there are some things to keep in mind if youwant to do this. Moreover, Western Digital does not recommend doing it.
  • For both PC and Mac to be able to read the drive, it must beformatted in the FAT32 file format. In order to format to FAT32 on aMac you may need to contact Apple for support. We do have a FAT32Formatting utility for Windows that reformats WD external hard drivesto their full size, but in only one partition. The FAT32 formattingutility can be downloaded from our Downloads Library. You will find it on your WD drive's Downloads page.
  • Critical: Do not attempt toconnect any external drive to multiple computers, simultaneously; letalone to both a Mac and PC. This could quickly damage the drive'spartition and corrupt the data on the drive.
  • Sometimes, PC's won't read Mac FAT32 formatted drives, andMac's won't read PC FAT32 formatted drives. You may have to re-formatthe drive trying both the PC and Mac until you get a format that works.
  • Most WD external hard drives come pre-formatted with one large FAT32 partition, which is accessible by Windows 2000, XP, and Vista, and Mac OS 10.4 and 10.5.
  • Windows 2000, XP and Vista can only create FAT32 partitions that are 32 GB's or smaller.
  • Mac 10.4 and 10.5 can create FAT32 partitions the full size of the drive.
  • There is a 4 GB file size limit on the FAT32 file format. Thisis a file system limitation that affects both Mac's and PC's, and thereis no way around it.
  • Finally, you need to understand that if you are using the samedrive back and forth between a Mac and PC, there is always the chanceof files being corrupted. Mac's and PC's are different platforms, andtheir file systems function differently. Please keep backups of allyour files before you start sharing between Mac and PC computers.
Note: Once the data iscorrupted, that drive may no longer be recognized by one or both of thecomputers. Or, the drive may be recognized, and the data may bevisible, but you won't be able to open any files. At that point, youwill need to re-partition and reformat the drive in order for it to berestored and usable by both computers again. In the process, you willlose all the data on the drive. For that reason, you need to keep abackup of the files you are transferring between computers.At the bottom of the page, you will find links for partitioning and formatting in Windows XP and Vista, and Mac 10.4 and 10.5.
Jan 12, 2010 | Western Digital My Book Premium ES...
External usb hard drive wont format on windows vista
Download a free disk partition manager from somewhere and use that to format it. Western Digital used to have some disk utilities on their website which would do it so it's worth looking there.
Aug 21, 2009 | Western Digital My Book Essential Edition...
External Hard Drive will not show up. Tells me to format it.
I have a Western External Hard Drive 320 and when I plug it in the computer will recognize it and allow me to access my files but after a short while if I go to click on a file t open it the WD 320 will click off for a minute and then reappear in the auto run mode.
Jun 20, 2009 | Western Digital Passport 320GB External...
Wd 500 not showing
It may be in raw format. Go to Control Panel-Administrative Tools- Computer Management- Disk Management. It will show all your drives and their formats. You can format from there if you need to.
Char S.
May 30, 2009 | Western Digital My Book Essential Edition...
I got a 500 gb. x hd. need reformat.
Get your system in safe mode. Just plug in the HDD and hold on the left shift ( dont autorun it).Now open windows explorer.
Rigth click on the HDD and click format..Choose to full format.
Mar 30, 2009 | Western Digital 500GB My Book Pro-External...
My WD 250 GB ext. HDD, not showing data, but showing free space
files are there but data is not there & its showing file is empty
Feb 18, 2009 | Western Digital My Book Essential Edition...
Western Digital WD 1200VE; 120 GB external hard drive unable to boot
You need to send it to a data recovery house like Drive Savers. The prices range from 500 to 3000 USD for data recovery and they can't guarantee 100 percent success. The platters need to be removed in a clean room and placed in a unit to read the data. They then copy the data to another drive or to optical disks. Unfortunately when the drive hit the floor the drive sustained physical damage hence not starting up.
Sorry to be the bearer of bad news.
Cheers.
Dec 23, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
External hard drive disk space
Hi
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
T.Boopathy
Aug 17, 2008 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
3,373 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
