Motorola Mobility XOOM Android Tablet Logo
Anonymous Posted on Sep 29, 2011
Our motorolaom is set to chinesewe cannot unerstand the options needed to change it to enish?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 19, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
92
Points
Mine was like this.
Switch on
At top right hand corner there is a + sign. The chinese next to it means apps. Press
This should bring up the page with symbols. Rond symbol with blue ring inside is settings possibly 3 line 6th symbol along. press
4th line up from bottom has a "a" press. This is language. should give you the english option. Good luck
How to set time on Kindle Devices?
You chose a Time Zone setting when you first set up your Kindle Fire. Your Kindle Fire uses the date and time setting to display the time in the Status bar, and also to work with other apps, such as a third-party calendar, for example. If you tap Date and Time in Settings, you see four options:
  • Automatic: If you want Kindle Fire to control the date and time based on your location, tap to turn this feature On. If you'd rather set the time manually, tap to turn this Off.
  • Set Time: To manually set the time, after you turn the Automatic option Off, tap the arrow on the right of this setting to display additional settings. Tap the + (plus sign) and - (minus sign) buttons to change the time, and then tap Save.
  • Set Date: Tap the arrow to the right of Set Date and then tap the + (plus sign) and - (minus sign) buttons to set the date you want, and then tap Save.
  • Select Time Zone: Tap the arrow to the right of this setting to change your time zone.
  • The Set Time settings become available only if you first turn the Automatic option to Off.
I have a 10.1 quad core android tablet. I cannot get the screen to stay illuminated more than a coule of seconds. I have tried to change it in settings but cannot. HELP
Goto..>>settings and after that select display menu and select brightness level chose your compatibility and this option not work so that you can use developer options and goto display settings
How to change the language back to english
From the Home Menu swipe down to get the pull down menu. Select the gear on the right hand side which is Settings. Select the Language option which you'll probably have to figure out by translating the word Language to whatever language the tablet is current set to.. If the menus are in the same order as in English it should be immediately after the Keyboard option which you may have to translate to the tablets language. The first option under Keyboard sets the language for the table. Select the first option. If those options are in English select English.
1helpful
On my new Kindle Paperwhite - language is Spanish --I need to have the language in English
You can change the language by taking the following steps:
1. Tap the menu button(Icon of 3 vertical lines on the top right of the screen)
2. Tap settings(The 6th option)
3. Tap Device Options(The 4th option)
4. Tap language and Dictionaries(The 5th option)
5. Tap Language(The 1st option) and select English(UK or US) from the list.
6. Press OK on the top up window to restart your Kindle and the language will be set to English.
2helpful
2answers
Change language to english
To modify the language on the Fire HD2 and Fire HDX:
Step 1
Swipe down from the top of the display screen and then tap Settings
Step 2
Tap on the 5th object from the top Device
Step 3
Tap on the 4th object from the top Language
Step 4
Tap on the 3rd object from the top English - United States
How do you set tablet to static IP?
If you have Android 3.x, use this procedure:
1)Open Settings
2)Touch Wireless & networks on the left
3)Touch Wi-Fi settings
4)Find the network you wish to connect to and long press it (touch and hold).
5)Touch Modify Network
6)Touch the IP Settings drop down and change from DHCP to Static
7)Enter the settings for your network - if you are unsure what settings to use, contact your network administrator
If you are using Android 4.0, then use this procedure:
1)Open Settings
2)Under the Wireless & networks heading on the left, Touch Wi-Fi
3)Find the network you wish to connect to and long press it (touch and hold).
4)Touch Modify Network
5)Touch the Show Advanced Settings check box in the lower left corner of the dialogue box. If the Show Advanced Settings option is not displayed, you may need to go back a step and Touch Forget Network, and then, when you reset up the network, you will see the Show Advanced Settings option
To ensure that you have got Static IP visit IP-Details.com to have an IP lookup.
I have tried to change my credit card no on my kindle unsussessfully
You need to change the number on the Amazon site. Go to Amazon, your account, Manage payment options, will probably ask you to verify log in info, Click on Add payment method, You MUST set new card as default. That may be what you missed. I did it the last time I changed mine. There should be an option to delete old numbers.
3helpful
Need English Manual for SANEI N78 7 inch Android 4.1 RockChip Dual-core RK3066
If you haven't resolved the language issue yet, try this:
1. power up the tablet by pressing the power button on the left side of the top edge of the tablet
2. slide the lock to bring up the home screen
3. across the top of the screen you'll see a magnifying glass (top left), a microphone, a folder with three dots on it (center) and dark area on the top right corner with six blue squares in it. Press the squares. Now you'll see your apps.
4. swipe your finger across the screen from right to left to show the next screen of apps. Look for the Settings app. It's grey with a light grey gear/sprocket in the center. Press that and you'll go into the Settings screen.
5. Down the left side you'll see a menu of options. Look for the Language and Input option. It is the one that looks like a solid light coloured square with the letter A in the center of it. Press that.
6. when that's hightlighted on the left side of the screen, you'll see the language option at the very top of the right side of the screen. There's no icon beside it, but it's the very top option. Press that.
7. the twelfth option in the list that comes up on the right side is "English (Canada)". Count down to the twelfth option and press it. The language of your table will be English. Go back and change it to something else if you don't want that particular English option.
Hope this helps. I found this youtube video that might help, too.
http://www.youtube.com/watch?v=e_rK6WRT3Ps
Skip ahead to 2:38. That's where he turns it on and then he changes the language (he could be changing it to Spanish, but you'll get the idea).
Mike
Top Motorola Mobility Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Tablet and eReader Expert? Answer questions, earn points and help others
