Question about Russell Hobbs RHNPC800P 8-Quart Slow Cooker
Control Panel Started pressure cooking last night.  After several minutes I noticed the control panel was not lit up.  The contents were warm.  There was no power surge or interruption of power.  The outlet is in good working order.  I unplugged the unit and tried again.  Pulled everything apart and found it to be clean and free of debris.  The control panel simply will not function.  This is only about the sixth time it has been used.
  • sugar131 Sep 19, 2008
    It is out of warranty. Did I pay 9.99 to be told to take it for repair? And if so, is it repairable or should I sell it for parts?
    How about refunding my money since you you weren't able to give me help in fixing it.
    Scholar:
  • 163 Answers
Remove control panel to have access at it's contacts and inspect it's general condition. if there is water leak inside they must be cleaned with spray cleaner and let dry before reassemble and try.
Posted on Sep 19, 2008
    Genius:
  • 1,665 Answers
Sorry Unfortunately your model is currently unavailable.Couldn;t find parts somewhere. See link.. perhaps later...
http://www.amazon.com/RUSSELL-HOBBS-NUTRITIONIST-PRESSURE-COOKER/dp/B0009AES0Y
    Master:
  • 763 Answers
Try to send it back to the shop were you bought it if your item is on warranty. so that they can replace or repair it. hope that helps!
CHARCOIS
    Sergeant:
  • 399 Answers
There is something short or some cable wires which helps control pannel to function is faulty.its a common problem faced by many user .it can be repaired if minor short.or replaced if major short.
thanks.
  • masterexpert Sep 19, 2008
    the internal unit is perfectly ok.only the front panel is faulty.get it done.
    thanks
Paula deen pressure cooker. Can I use it for slow cooking? What is temp of keep warm? Could put lid on loose. Also, timing notches are mixed into keep warm button. I overcooked my first batch
A pressure cooker is NOT anything close to a slow cooker. The cooking philosophy are practically totally opposites. A pressure cooker basically cooks your food in a fraction of time because it is under pressure. A slow cooker takes hours.
The whole idea of using a pressure cooker is that it is sealed and applies pressure to cook the food faster. The lid needs to be sealed for the pressure cooker to operate properly. It is frequently referred to as "infusion" cooking now days.
You need to read the instruction book that came with the pressure cooker. Pressure cookers usually cook for less than an hour--my homemade pressure cooker spaghetti sauce is cooked in less than 30 minutes. They are nice and were very popular long before anyone thought of microwaves and slow cookers. However, there are some precautions to be taken. There must be water or liquid in a pressure cooker. The rubber seal needs to be cleaned frequently and, when the rubber seal warps/stretches and no longer seals, it needs to be replaced. There are also certain foods that CANNOT be cooked in a pressure cooker like rice, dry beans, etc. The pressure control valve operates to regulate the amount of pressure and releases extra pressure otherwise the unit would blow up (very dangerous!). Most pressure cookers (required on all new ones) have a small rubber emergency stopper that will "blow off" in case the pressure is too high. I've seen this happen and my mother cleaning potatoes & meat from the ceiling!
Mar 03, 2017 | Crock Pots & Slow Cookers
I have an all clad pressure cooker I need to know how long to cook a 5 pound pork roast for pork tocos
Hi Sharon! If you want the seasonings to get all thru the meat, I would cut it into about 6 pieces. Add your seasonings and cook it for 20 - 25 minutes. I have been cooking for 50 years and bought one of the electric digital pressure cookers. Liked it so much I bought another one. I made a pork roast about 2 weeks ago and I cooked mine for 25 minutes, It was so tender I could pull it apart with dinner forks. The seasonings I used were fresh diced onions ( 1 med) 2 cloves fresh garlic diced, salt and pepper to taste. Hope this helps.
Jan 24, 2016 | Crock Pots & Slow Cookers
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    Oxtails
    The pressure cooking time for Oxtails is 45 minutes at high pressure. Here is a detailed chart with cooking times for all types of pressure cookers:
    http://www.hippressurecooking.com/pressure-cooking-times/
    Jun 21, 2013 | Wolfgang Puck Electric Pressure Cooker...
    I bought Tefal 4 in 1 slow cooker last week and couple of first times it worked OK. Now when I set hours for slow cooking it brings the food to boil in about 6 minutes and then switched to keep warm mode....
    I suspect that is the norm for slow cooking. The cooking temp is brought up and just maintained for the given time. Nothing wrong so :) . You wouldn't want the food to sit in liquid that slow in heating up. It's kinda like bbq'ing. You set the patio on fire and wait till the flames to subside before you put the hot dogs on. I think you are safe. :) - Ned I consulted with a crock pot fanatic, My Wife!
    Sep 04, 2009 | Crock Pots & Slow Cookers
    I have a mirro matic pressure canner model 0406 with a jiggler pressure gauge. how do you know when pressure is reached and how to maintain that pressure for correct time?
    I too have a Mirro 0406 that my mother gave me some 25 years ago. I LOVE it and use it every year! Fortunately, she gave me the manual along with the canner. It states"When correct pressure is reached, control will jiggle and sputter. To reach the first jiggle in a small cooker may take less than 5 min, or less than 10 min, when canning. Large canner may take 45 to 60 minutes for the first jiggle when canning a full load. Count time from first jiggle and reduce heat so control jiggle about 1 to 4 times a minute for cooking (about 4 jiggles per minute when canning). Constant jiggling causes excessive loss of moisture: the occasional jiggle and a hissing sound indicates pressure is being maintained. (I just canned 14 quarts of green beans with my Mirro today 7/26/09 :) Congradulations on your Mirro canner, I hope you have many years of success with it. Good Luck, and Happy Canning!
    Jul 24, 2009 | Crock Pots & Slow Cookers
    Steam escapes from pressure cooker
    the gaskets are junk , i had to toss one myself i used one time then stored for a year and the gasket went bad , mine came from hsn when i called them ,there where no parts made for it . so out it went cheep china junk . sorry , good luck
    Jan 14, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
    Slow cooker not hot
    If you only have High and Low on the slow cooker this will be normal until it reaches correct temp, the trick is Do not remove the lid once you have started the process, you lose 20 minutes cooking time every time you lift the lid during cooking, if you have timed ex,4,6,or8 hours just set to required cooking time and leave until done. hope this helps clarabella
    May 18, 2008 | Crock Pots & Slow Cookers
    Rival 38601 Smart Pot 6-Quart Slow Cooker can't get to to go to warm
    Here is the manual for this cooker; http://www.crockpot.com/manuals/38601-C_English.pdf page E4 and E5 tells you details of programming/timer/temperature. Check through everything and see if you can figure anything out. after cooking, the unit should automatically switch to warm mode, if it isn't doing this then unfortunately i think it needs a replacement control board - probably not worth doing. If you want to give it a try then post again and we can try and source you the bits Hope this helps :)
    Mar 16, 2007 | Rival 38601 Smart Pot 6-Quart
    Russell Hobbs RHNPC800P 8-Quart Slow Cooker Logo
    190 people viewed this question
    Top Russell Hobbs Crock Pots & Slow Cookers Experts
    Tally Girl
    Tally Girl
    Jack Frost
    Tom Chichester
    Are you a Russell Hobbs Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
