Question about Jenn-Air JED8430 Electric Cooktop
Spark from burner
I have a gas cook top from Jenn-Air..It is abt. 16 yrs old and now a days -it is continuously make the noise (tik tiktik) & spark from burner. We have cleaned the gas many time but still the noise does not go away.. Any solution?
  • dgutlay Sep 22, 2008
    I have exactly the same problem regarding a contuous ticking of the igniter.
Eddie Rentas
  • 59 Answers
SOURCE: jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
Posted on Jul 23, 2008
  • 222 Answers
SOURCE: why does my jenn gas cook top burners all flicker when turned off
hi im gerbee,i will sujest to clean the area were is the place of ur knob control try to remove the control knob then clean it by using a vaccium coz sometimes the problem is very dirt of the control knob.
Posted on Dec 02, 2008
  • 18 Answers
SOURCE: Stove Ignitor makes tik tik sound and the sparks continuously
may be a loose wire on the spark ignitor ceramic or if you run via main electic it may be your spark generator
Posted on May 17, 2009
  • 222 Answers
SOURCE: turn on one burner, second burnertrise to light
hi.gud day...tnx for question.im gerbee here in the phillipines, the problem of the the unit is have an dirt or water,& oil coz why the unit is not stoping cliking sound.the best thing to is clean the area were the problem it is,first unplug the unit & turn in off the gas line for the safety..get the vacium & bottle of thinner...first remove all the knobs of the control valve(make sure to remember how to remove the knobs coz if turn back as how you remove it). then drops some thinner located on valve switches(knobs position) 5-10ml,,,then put the vaccium in the place were u drop the thinner to suction the thinner,oil & some dirt.try 2 times for good result...after this if is not work n nid to call an expert tecnician to dismantle & clean the micro swicth one by one(no nid to replace the parts)
tnx gerbee
Posted on Sep 16, 2009
  • 233 Answers
SOURCE: conversion from electric to lp gas
Simple answer NO.
Unless Jenn-air has a conversion kit. (highly doubt this)
It would be a serious undertaking to switch out 2 burners for LP use.
Gas tubes, igniters, electronics, regulator, gas jets.
Not to mention the modifications changes needed to the stove top to make all this work. That gas regulator has to go somewhere and piping from tank/regulator/burners.
Not saying it can't be done mind you.
But think about it long and hard before committing to this job.
Small gas leak can become a huge headache later.
Posted on Oct 04, 2009
I have a gas glass cook top (JGC9536) with a problem at the right front surface burner (12,500 btu). I used to be able to just turn the switch on high and the burner would light. Now, there is spark and...
Make sure there is no blockage of the burner near where the spark jumps. All it takes is a drop of water to stop the gas flow near the spark. Most likely you can use a knife or some other thin blade to clear the slots where the flame comes out of the burner.
Feb 20, 2014 | Jenn-Air 35 in. JGC9536 Gas Cooktop
Gas Kleenmaid cook top, one igniter continues to
the switch for the ignitor is stuck. might need to free the switch, of
> call the repair man.
Oct 20, 2013 | Jenn-Air 30 in. CCG2423 Gas Cooktop
The igniter on my gas cook top won't shut off.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Jan 27, 2011 | Jenn-Air Cooktops
All cook top burners spark when any is turned on
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
Nov 04, 2009 | Jenn-Air JGC8430 Gas Cooktop
My burner sparks though my burners are off
did you spill liquid on the cooktop? sometimes if you just let it sit for a few days to let it dry out it will fix itself. but if you spilled oil on it it will not fix itself. you have a bad spark module and the only way to fix that is to remove the cookyop fromt he burner box. and find where all the wire go into this usually redish orange box sometimes its blue. but that is your spark module. let me know if you have any more questions
Jun 01, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
Mar 09, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Bad ignitor needs replacement
it may just need cleaning at where it sparks to the burner if it is sparking back down the electrode then it is cracked . Some igniters pull out others have a screw that holds them in.
Oct 23, 2017 | Jenn-Air JGC9430ADS Gas Cooktop
Igniter will not turn off once burners are lit.
I've had the same problem for 2 years. Today I removed the four burner tops, the 15/16 inch bolt that holds the burners in place, took everything apart (simple connections underneath), completely cleaned and dried eveything. I also cleaned the 4 knobs and making sure the 4 swiches slide up and down freely then dried everything with a hairdryer. Is now works fine but if the problem comes back, I'll simply unplug the cooktop and light it manually. P.S. I stripped one of the large 5/16 inch bolt that had become weak and brittle. - Try using water or some liquid to loosen the bolts as necessary. Good luck, CHEERS!
Oct 13, 2007 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
