TV repair person told me my Toshiba 50HP16 Main Power Supply Circuit Board is bad as well as a secondart board. How do I identify these boards and get part numbers? Its too expensive to have the repair person to fix.
  • 1 more comment
  • sjmhan Sep 26, 2008
    I was told surge in power caused the board to short. The tv does not work, absolutely no power going to the tv. Nothing happens if you press the power button.
    The part number listed on the part number listed on the damaged board states 3501Q00200A. I'm not sure what the Toshiba part number is. I want to try to replace one board at a time to see if the tv is salvagable without spending too much money.
    Do you know if I have to do an alignment for voltage or anything else after replacing the power supply board?
  • Anonymous Mar 24, 2009
    tv will not turn on, possible moisture damage.
  • 4getnow Nov 18, 2010
    Hi, I have almost the same problem with my Toshiba 50HP16. It powers but the image doesn't come on. Any tip?
  • 85 Answers
Even if you buy the parts you may get sticker shock!!! Why did it need a power supply and another board. Will your set come on? I may be able to give you part numbers but you need to be specific about which other board you think you need such as X Y signal board or power supply Some single circuit boards for some sets are as high as 600 bucks hope not for you
Posted on Sep 26, 2008
I have a 55 Toshiba TV that is not showing video but has a buzzing sound. Can I reset the TV?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 06, 2017 | Toshiba Televison & Video
My toshiba tv keeps fading to black
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board....
Jan 10, 2017 | Toshiba Televison & Video
What is causing my LCD tv to turn off on my Toshiba 52hl167 tv.
. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 13, 2016 | Toshiba Televison & Video
Repair Sony nsx-40gt1 tv, no picture, 2 red blinking lights where normally green. Is the power supply board bad, t-con bad or main board bad. Who sells repair manual?
Hello Eric,
shopjimmy has the circuit boards and gives live support..
Check out the URL below.
Also consider getting an anti-static wrist band... so you don't destroy good semi-conductors with tiny static sparks.
Further information on that is under "ESD"
(Electro-static Discharge)
TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 14, 2016 | Sony NSX40GT1 40 Inch Internet TV powered...
What Circuit board is needed to fix this TV?
Jun 21, 2016 | Toshiba Televison & Video
My picture goes black but sound is ok
Mar 27, 2016 | Toshiba 46SL412U 46 in. TV
I have a 6 yr old toshiba 50hp16 that is currently not working. I was watching the tv last night...heard a pop...and noticed the picture got darker and the pixilation got very grainy. The television...
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 11, 2017 | Toshiba TheaterWide 50HP16 50 in. Plasma...
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
No pic and no sound on toshiba regza was told the power board was out is this an expensive fix
The 42RV530U is known to develop problems in both the power board and the main board.
You can check out our power board repair service at
http://www.coppelltvrepair.com/p/442/repair-service-for-toshiba-42rv530u-power-board-75010942-dead-tv-or-clicking-on-and-off-problem
and I'd also recommend that you search for 42RV530U at http://blog.coppelltvrepair.com as we will eventually release an article on how to test the board.
Hope this helps.
Nov 04, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Televison & Video Logo
184 people viewed this question
Top Televison & Video Experts
Electro Med Services...
