Question about JVC GR-SXM37 S-VHS Analog Camcorder
Camcorder to laptop connection w/ s-video cable
Computer does not recognize the connection. All other components are regognized when connected. Why not the camcorder. Wanting to download video to disk.
Cavie54,
Look carefully at your camcorder manual. I'm fairly sure that the the s-video is strictly an output to a TV or VCR recorder. Notice that the S-Video connector is located next to the white and yellow A/V connectors which are also output. Do you have an S-video input on your computer? That would be unusual unless you have added a TV tuner/DVR card. The only way I know of getting this camera's output onto a computer is to use an analog A/V converter which outputs on a USB port. One such box is the Pinnacle Dazzle device (just google it). It's about $40. Unfortunately the most popular Movie program is the Microsoft MoveMaker. Unless it has changed recently, it does not support USB input, only Firewire (IEEE1394). Some software I've used (maybe Roxio, maybe something with the Dazzle) can copy the USB input direct to DVD. Once it's converted you can source MusicMaker with an input DVD and then do your editing and creative stuff
Hope this helps??
John Estal
aka Johnny Wayne
Posted on Jan 21, 2009
Hi, I have a JVC GR-D750AA digital video camera. I do not know how to download the things recorded to my PC. I have also bought the USB cable n tried but the camera USB port is not recogned by the PC. I do...
Turn the power switch on your camcorder to "Off." Connect the USB cable that came with the camcorder to the USB port on the camcorder. If you are using the DV cable, connect one end of the cable to the computer first. Put the other end of the USB cable into the USB port on your computer. If you are using the DV cable, connect it to the camcorder. Power on your camcorder. Wait while your computer recognizes the attached JVC GR-D270U camcorder. Typically you will get a pop-up on your screen asking how you want to proceed once the camcorder has been recognized. Open your video editing software, such as Adobe Premiere, Roxie, iMovie or Windows Movie Maker. Import, or capture, the video from the camcorder to your computer using the video editing software. For example, in iMovie you click on "File," then "Import from Camera" to download the movie from your camcorder to the computer.
Jan 13, 2018 | JVC GR-D275 Mini DV Digital Camcorder
I want to connect my sony DCR-TRV260 handycam to my computer...what cables do I need?
Depending on what type of connector your computer has, you will need to get a firewire cable (also known as IEEE-1394a cable). The connector on your camcorder is a 4-pin connector. You will either have that same looking connector on your computer (some laptops now have the 4-pin connector) or a 6-pin connector (D shaped). 884068d.jpg This picture is of a 4-pin (right side of pic) to 6-pin (left side of pic) cable. These are available at many electronic stores and online. To be safe, have your camcorder powered off when connecting to the computer. Once you have connected the cables, turn your camcorder on and insert the tape that you would like to transfer. Your computer should recognize it and install the appropriate driver. Most computers have some sort of free video editing program (like Windows Movie Maker). Depending on the software, you may have the option to import the entire video tape or only parts.
Hope this has helped you.
www.austintelstarservices.com
Jul 20, 2011 | Sony Handycam DCR-TRV260 Digital Camcorder
Why will my laptop recognize the ZR85 camcorder in the card position and not in the tape position?
Because if you only connect with USB that's normal.
USB tranfers still photos.
For Video you will require a firewire cable connected to camera and computer.
Al
Feb 11, 2011 | Canon ZR85 Mini DV Digital Camcorder
Having difficulty connecting the jvc gr-d370 to my computer using Windows Media. What must I do to retrieve the video from the camcorder using the USB cable?
I had this same issue. I solved it. The USB cable will NOT work to transfer video. You need a IEEE-1395 fire wire cable. I purchased the internal card and cable for under $20.00 for my DELL computer direct from dell. After you connect your camcorder to your computer, I clicked on windows photo gallery. Then in top left corner, click file and "import from camera or scanner. Your camcorder must be on video mode and play mode. Your computer should recognize the camcorder, click on it and then it will give you options, like you can upload and record direct onto DVD. I liked the option of uploading manually because if there are blank sections on the DV tape, the computer will stop uloading. Hope this helps.
Dec 28, 2010 | JVC GR-D370 Mini DV Digital Camcorder
How do i get video from my vx1000 to my compuiter
You will use the DV (firewire) jack on your camcorder. It is located on the back of the camcorder under the door for the battery. Depending on what type of connector your computer has, you will need to get a firewire cable (also known as IEEE-1394a cable). The connector on your camcorder is a 4-pin connector. You will either have that same looking connector on your computer (some laptops now have the 4-pin connector) or a 6-pin connector (D shaped). 884068d.jpg This pic is of a 4-pin to 6-pin cable. These are available at many electronic stores and online. To be safe, have your camcorder powered off when connecting to the computer. Once you have connected the cables, turn your camcorder on and insert the tape that you would like to transfer. Your computer should recognize it and install the appropriate driver. Most computers have some sort of free video editing program (like Windows Movie Maker). Depending on the software, you may have the option to import the entire video tape or only parts.
Oct 05, 2010 | Sony Handycam DCR-VX1000 Mini DV Digital...
I have a Canon 7.4V video camera and want to connect my camera to the computer. How do I do that?
Instructions:
  1. Connect an i.LINK (firewire) cable (also known as IEEE 1394) to the i.LINK port on the digital camcorder.
  2. Connect the other end of the i.LINK cable to the computer. NOTE: The computer i.LINK ports and capture cards may have either 4-pin or 6-pin connections. If your computer only has a 6-pin i.LINK port, then it will be necessary to use a 4-pin to 6-pin i.LINK cable.
  3. Turn on the digital camcorder by moving the POWER switch to the VTR position.
  4. Cue the camcorder tape to the beginning of the video footage.
  5. Turn on the computer. Your computer should recognize your camcorder and automatically install the needed driver.
  6. Start the video capture software on the computer.
  7. Begin playing the recorded video in the camcorder.
  8. Begin importing the video with the capture software. It should now be possible to copy the video using the video capture software if the computer hardware and software are configured correctly.
Sep 04, 2010 | Canon Video Cameras
How to trasnfer videos on tape for DCR-TRV33 to file on a pc?
Since you've got a MiniDV camcorder,you only need firewire(IEEE1394) card&cable to establish connection to your PC.Those card&cable should be available at any computer hardware store in the world.
Sep 03, 2010 | Sony Handycam DCR-TRV33 Mini DV Digital...
How to connect JVC GR-D820E camcorder to PC
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | JVC GR-D370 Mini DV Digital Camcorder
NOt recognized
if your trying to download video usb won't work! must use firewire cable hooked up to dv port on cam and connection on laptop or tower called 1394-cable is either 4 pin or 6 pin-depends on computer- cam is always 4 pin-says dv on camcorder-usb only for still pics-use windows movie maker in xp or vista to edit
Jun 28, 2008 | Canon MV700 Mini DV Digital Camcorder
JVC GR-SXM37 S-VHS Analog Camcorder Logo
1,104 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
