Question about Xerox Phaser 7750DN Laser Printer
Phaser 7750DN fan failure Error Code 48
Can i get some help on how to resolve this. There are several fans. I have already replace the one in the center of the rear because it was easy to do. the one on the upper right appears to be the one that needs replace, or is it something else.
    President:
  • 2,072 Answers
Yep, the fuser fan is he one that fails. You can remove the top and rear covers and then carefully remove the shrouding and whatever else makes it easy to get at.
What you can do if you dont have a fan handy is, remove the silver label on the fan. Behind that label there is a black rubber cap over the bearing in the fan. You can flush that bearing out with alcohol several times and then use a very highly refined oil , to lubricate it. Just pretty much fill up that little hole around the bearing, put the rubber cap back on and then wipe it clean with alcohol and tape it back on.
If you need a fan, Go onto google. Type in ( the parts drop) not parenthesise.and call them, Ask for Britt, I dont work for them, but they are 100 percent professional and will charge you a fair price.
Cleaning and lubing will fix it about 60 percent of the time.
Posted on Sep 20, 2008
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
Hey, I know this is an old post, but if anyone else is having fan errors on there 7700, 7750, or 7760 you should replace the three fans to clear the error (part# 7750-Z2 ). Here is a video that shows you how to locate and replace all three fans.
Posted on Jul 08, 2011
Error Code 9-456
This error code means the life of the black developer is at its end. It is probably time to replace all four developers and the only reset is replacing the engine control board.
The costs will come around 1000usd I recommend you buy a new one.
Jun 18, 2008 | Xerox Phaser 7750DN Laser Printer
Tip
XEROX PHASER 7750 7760 FAN ERROR.
Hey guys this is a Xerox Phaser 7750 and 7760 fan error video tutorial.
In this video you will learn how to fix the error code 48 on the Xerox phaser 7750.
Also you will learn how to fix the error codes 010-391,010-392,010-398 that are related to the Xerox Phaser 7760.
This video shows how to remove covers.
All the wires that you need to disconnect from the machine to fix these errors.
There is also another video part two that shows you how to reinstall everything back
in it’s place. Step by step tutorial hope you enjoy.
http://www.youtube.com/watch?v=yMud-Md2xpc
on Dec 30, 2009 | Office Equipment & Supplies
I'm having trouble code 80 for the machine processes the file and not print accuses engine failure''firmware''someone could help me please, I have changed the image processor board and...
hi there
Error Description: Engine Logic Board Failure, Code 80
Possible Solution:
1. Cycle power to the printer to clear the error.
2. Did this clear the error? If, yes problem resolved , if no, replace the engine control board , or,
The image processor board
eng log brd part # required, 160K85653 cost approximate $125
proc brd 650-4306-00 aproximate cost $160
hope this helps -- please send me 4 thumbs up
Jul 10, 2011 | Xerox Phaser 7750DN Laser Printer
Phaser 6360 laser failure code 07
Yeah I had a look at the website there too, try powering down again and plugging it out for a longer period of time. You need to get the whole machine to reset and loose all saved info in the bios. Also cleaning it out of all loose toner on any contacts might help!
Niallbt
Feb 25, 2009 | Xerox Phaser 6360 Laser Printer
Xerox phaser 7750gx
Hiya,
Can you be more specific regarding the Engine Logic Board Failure as in is it timing, rom/ram, micor pitch or NVRAM as code 80 is a failure code for
Engine Firmware Halt Failure .
Ta
Nov 01, 2008 | Xerox Phaser 7750DN Laser Printer
Xerox 7750 fan failure code
That is the fuser fan either running slow or stalled. It is located on the back, looking from the back on the upper left. You will see the slotted opening.
You have to remove the side covers and the top cover to access it, Sometimes taking off the silver sticker in the middle, removing the rubber cap and oiling it will help.
To buy one. Go onto google and search for " the parts drop". Call them and ask for Britt or Joe, they will know what fan and be fair on a price.
Taking your time it should take half an hour to an hour to replace. Not hard, just take your time and make sure you note how you disassemble. You will be fine.
Oct 30, 2008 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750
There is a motor in the laser called the polyogon motor, It turns the mirrors in the laser.
It most likely is not starting fast enough.The laser isnt that hard to remove. But if it has failed, it is pretty expensive.
Let me know if you want to attempt to pull it.
Sep 10, 2008 | Xerox Phaser 7750DN Laser Printer
I am geeting error code 48 on my phaser 7750dn
that is a fan failure code, Either the Fuser fan ( most likely) behind the back cover near the front.Low voltage power supply fan or rear cover fan is not operating.
Most of the time it is the fuser fan that is not running or even if its running slow it will give you that error code.
Here are the notes
Problem:
    Fan Failure Message (Code / Error 48)
Cause:
    The machine logic detected a failure of the Fuser fan, LVPS fan or rear fan.
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix.
  1. Insure there is adequate ventilation around printer. Refer to Section 1 of Service Manual for required clearances.
  2. Follow the procedure in Chapter 3 for this error.
  3. This problem can be very intermittent. Fans can work in diagnostics and fail in the middle of large print jobs. If unable to duplicate problem replace all 3 fans.
  4. Use service diagnostics to verify the Fuser, LVPS, and ROS fans. These fans have a third wire which provides feedback to the Engine Board.
  5. Visually check each or these fans for a build up of dust or toner.
  6. There is a correction to this procedure in the Service Manual. The fans that can cause this error are the Fuser, LVPS, and ROS(laser fan). Not the Rear fan. The rear and bottom (developer) fans are not monitored by the system and won't generate this error.
Parts that may resolve this issue are:
  • FAN ASSEMBLY, FUSER (63%)
  • FAN ASSY; LOW VOLTAGE POWER SUPPLY (45%)
  • FAN REAR ASSEMBLY (Laser Fan) (25%)
May 05, 2008 | Office Equipment & Supplies
Fan Failure Error 54
1 of 2 things.
You need to clean or replace the fan.
You have to remove the back, right side and top cover to access that fan.It is near the back just behind the fuser module.
It could also be the low voltage power supply fan. Most likely the fuser fan.
Once you remove the fan, there is a label on it, remove the label, There is a rubber plug behind the label, remove the plug and drip some lubricant into the fan. Reassembly and it should be ok.
I would recommend replacing the defective fan though.
Here is a very reliable part source.
https://www.partsdrop.com/store/
If you call ask for Britt and specify the model number and that you need a fuser fan and probably order a Power supply fan, Neither are very expensive.
Have both on hand to be 100 percent sure the problem is resolved, But its a 90 percent fuser fan failure code. It operated in a heated area and can dry out faster.
Mar 27, 2008 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 7750DN Laser Printer Logo
1,334 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
