For several months the TV has been working correctly but occationally it will turn off but then come back on after several seconds.
Now it turns off striaght away but still keeps coming back on and then off again.
Remove the lamp and check to see if the connections of the lamp and the lamp driver(ballast) are ok or they look bit burned.Also the lamp should always be replaced first especially if is two years old or more.
Check to see how many times the error indicator flashes.If it flashes 5 times then the lamp driver is probably defective.
common problems are lamp and lamp driver(ballast).
let me know if you need more help.
Good luck.
