Question about Brother MFC-5460CN All-In-One InkJet Printer
Brother5460fax no answer ,line busy when i try to fax .i have vonage for a carrier i have been faxing with it for months.try to fax with brother 5460 all in one?
  • 120 Answers
Turn off Error Correction. Most VoIP cannot handle it.
Posted on Sep 26, 2008
Brother mfc-420cn - fx problem
From the manual for your Brother model: To select or change your Receive mode 1. If it is not illuminated in green, press "Fax" (picture of Fax button) 2. Press - "Menu/Set, 0, 1." 3. Press - (up arrow) or (down arrow) to select "Fax Only". 4. Press - "Stop/Exit." This is just to select the "Fax Only" option, which is what you need - having a phone line strictly for the fax machine. There are 4 options on that setting, and the manual explains them in more detail. You can also set the "Ring Delay" for the fax by pressing "Menu/Set, 2, 1, 1." The options shown are "0, 1, 2, 3, or 4". It's very likely that you want to select an option OTHER than "0". This Brother manual for your model can be found at this URL: --> http://www.retrevo.com/search/fv/1d4caef84f3754461d7ce187341b923c.pdf#page=1 Hope this helps! If not, let us know and we'll try to help further. ;)
Aug 09, 2007 | Brother MFC 420CN All-In-One InkJet...
Cannot receive faxes with my Panasonic Model No.KX-F1050. There is alway busy signal for the person trying to fax me. Is this the fax or the phone line? I have a Vonage Phone System.
Fax machines are ANALOG devices. Vonage, et al are DIGITAL systems.
Your fax will be very unreliable.
Here's a free tip, take the toner cartridge out and remove the swinging drum cover and spring, it's only for shipping. This item will come loose and cause jams.
Dec 18, 2008 | Panasonic Office Equipment & Supplies
Unable to send or receive fax over vonage/dsl
I also have vonage and this fax macine - the incoming fax was going to vonage answering machine.
I went to setup (that little button above and to the right of the OK button to "basic fax setup" and changed my rings to answer from 5 to 2. This will work for me, because I only set it to auto answer when I know a fax is inbound - you might want to adjust so you can aswwer a call if you do not have a dedicated fax line.
Good luck
Dec 05, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Can't Send or Receive Faxes from MFC-7820 N
You may not need a separate fax line from Vonage. If you don't need a dedicated fax line, you can try changing the "Bandwidth Saver" settings on your Vonage voice line from your account on the Vonage website. Perform the following:
1. Login to your Vonage account online and click the "Features" tab.
2. Scroll down to the "Bandwidth Saver" link and click on the "Configure" button.
3. You will see a scrollbar with 3 settings: 30kbps, 50kbps and 90kbps
NOTE: My "Saver" was set to 90kbps (Highest Sound Quality) by default.
4. Click on 30kbps (Normal) and click "Submit".
5. Wait about an hour before testing as it could take that long for the change to take effect.
6. Send a test fax to the HP fax test service at 1-888-hpfaxme (1-888-473-2963).
NOTE: This is a GREAT service provided by HP. If your fax goes through correctly, you will receive a return fax within five minutes.
We upgraded to Verizon FiOS and never thought the increased upload speed (4mbps) would present an issue sending faxes. WRONG. We never had fax issues with DSL, Comcast or even Broadstripe VOIP service but for some reason Vonage + FiOS = no fax. That is until we set our Vonage VOIP sound quality to "Normal". Our phone voice quality has been much more reliable since throttling back. This sentiment has also been shared by other Vonage users who have experienced echoing and noise when utilizing the higher quality settings.
Your phone coversations may not have FM quality sound but they will have AM quality and usually that is just fine.
If your fax machine has a Telephone Answering Device (TAD) setting, you can share your voice line with your fax machine and be able to receive faxes and voice messages. Hopefully this will work for you.
Dave Grannas
Nov 04, 2008 | Brother MFC-7820N Printer
Brother IntelliFAX 4100 shooting out blank sheets
The machine told you poor line quality. Try a different phone line to verify. Try it at a friends house to verify it. If you are using Vonage, that is the problem. I have Vonage and every fax I test with has some issues with poor line.
Aug 07, 2008 | Brother IntelliFAX 4100 Laser Fax
Vonage vs Brither 4100
Have you called your own fax line and just listened to the fax hand shake? might sound simple but I have called fax lines before and it just rang, or it was busy or static, if your not getting a clear fax hand shake, then it is the phone line, if there is no answer you may have turned your fax to manual receive mode, If you don't know how it should sound call a friends business fax line and listen to it. I have actually gone out to businesses that reported send or receive problems just to call the line and listen to a disconnect message, that would make it difficult to fax.
Jan 13, 2008 | Brother IntelliFax-4100e Fax
Faxing
Do you have the phone cable connected to the LINE socket and NOT the EXT socket on the side of the printer? M
Aug 21, 2007 | Brother MFC 420CN All-In-One InkJet...
Outgoing fax never goes
Do you have the same problem with different numbers that you fax to? Are you usinga voip phone service? I use Vonage and have a lot of trouble with faxing. Call the number you are faxing to with a different phone and listen for a fax tone.
Aug 16, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother MFC-5460CN All-In-One InkJet Printer Logo
67 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
