I have a canon PIXMA MX300. IT is joined with my computer and telephone line. When I get a phone call, I can hear the caller, but I also get the fax. noise, which is very loud and intrusive Help
Block out the noise of the fax until it goes away , or use another phone .
Posted on Sep 28, 2008
While on the telephone the caller is cut off and the caller hears a fax signal. How do I prevent this from happening?
set the number of rings to answer as many as possible so it gives you chance to answer before it kicks in. Also find out (normally *123 )on how to divert a fax call to the machine
Oct 09, 2013 | Canon Pixma MX452
What does the L input mean on the back of the printer?, it's right by the telephone input. Thank you
The L input connector is the Telephone Line Jack for connecting your telephone line to your fax machine.
The adjacent jack if for connecting your telephone or answering machine.
See the Easy Setup Instructions.
Trust this is helpful. Please vote.
Dec 28, 2010 | Canon PIXMA MX300 All-in-One Printer
If I have my canon mx300 connected to my phone line, what else must I do in order to send my first fax??..I appreciate your help Im new to faxing!!!
You need to run the software that came with that all in one printer to configure the fax features and after that everything should be working for you....
Jul 11, 2009 | Canon PIXMA MX300 All-in-One Printer
What connection do i need to connect my canon mx300 printer to a telephone. There are several connection wires that have been included with the printer but i do not know which one to choose??
You need the cable that looks like a telephone jack where you can connect it to your printer and to the phone line so you can use the fax service of it...
PIXMA MP780 will not receive fax with Verizon DSL connection. Before unit was ok with comcast cable, Note: I'm able to send fax. RBRANT
Solution: Contact local phone company to check the telephone wall jack for low ring voltage.
Ring-in Voltage Facsimile equipment?(fax machines), like other telephone anwering devices, require ring voltage at a telephone jack to answer automatically.? The ring voltage is one of the services provided by the local phone company.
  • Low ring-in voltage can cause short bursts of ring tones at the phone jack.
  • Callers may hear one or two ring back tones and then ringing will stop and nothing else will be heard.
  • Inside the home, the called party will hear a brief ring and then nothing else will be heard. If the telephone handset is lifted, the caller may be on the other end.
To check if the fax will not answer due to low ring-in voltage, do the following:
  1. Disconnect the fax at the telephone wall jack.
  2. If an answering machine is available, connect it directly to the telephone jack. If an answering machine is not available, connect a telephone to the telephone jack.
  3. Dial the fax line and see if the answering machine answers the call, listen for uncommon ring tones inside the home or check for similar symptoms as described above. If any of the above symptoms occur, please contact your local telephone company.
May 05, 2009 | Canon PIXMA MP780 All-In-One InkJet...
TELEPHONE
how can i use the fax machine canonemx30 please
Mar 23, 2009 | Canon PIXMA MX300 All-in-One Printer
I have a similar problem. My FAX is connected directly to my
Yes,
Fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines
Feb 14, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon pixma mx 300 won't send or receive fax
Dear friend,
it's very important to connect your MX 300 with the telephone line the right way! Please read once more the part "Preparing the machine for fax" in the chapter "Faxing" of the MX 300 User's Guide and mind the hint "Important: Do not connect the machine and external devices in parallel to the same telephone line using a splitter (A). The machine may not operate properly."
Greetings from Cologne (Germany) to the UK!
Dec 02, 2008 | Canon MX300 Office All-In-One Printer
Auto-answer issue: fax beeps on line when voicecall received
Try changing the receive mode from automatic to FAX ONLY and set the number of fax rings higher. You should be able to receive phone calls and if you are not answering your phone it will automatically receive a fax.
Mar 27, 2008 | Office Equipment & Supplies
Incoming telephone calls
Refer to your manual. It may be under RX(recieve settings). Go disable FAX/Tel SW and make sure it is fax mode only
Jan 11, 2007 | Canon FAX-B820 Plain Paper Bubblejet
Televison & Video Logo
Top Televison & Video Experts
