Palsonic 180gb hdd, no picture, voice okay and the only thing we can get on screen is a wobbly white and black square
I plugged a computer monitor into dvd recorder, this allowed a screen and menu to surface. From there we found RETURN TO MANUFACTURERS SETTINGS. The television was still attached, turned off recorder, waited required 3 seconds, lo and behold, we had picture as well as sound.
Posted on Sep 20, 2008
How to clear a square on tv screen that has a black rectangular block in middle of picture?
it could be you have pressed the old teletext service button, look for a button with 3 lines on it in a box and press it or try turning the tv off at the plug then back on again.
Jan 22, 2015 | Televison & Video
Flashing black and white squares instead of picture on screen.
This might require attention by a qualified service technician.
Jul 13, 2012 | LG 50PC3D 50 in. Plasma Television
The colour on my TV is a reddish colour. Have tried the colour adjustment. Skin colours in particular.
simple. easy. you have 3 screen adjustments. red green blue. turn color all the way down. you should then get just a black and white picture, but in your case, it will still be reddish. behind the speaker grill is an access panel for screen adjustment. remove speaker grill. remove access panel. you will see a block assembly roughly 6 inches square with 6 knobs on it. 3 are for screen, 3 are for focus. adjust until you have a black and white picture. then go into menu and turn your color back up. enjoy!
Nov 14, 2009 | Televison & Video
HDD upgrade to extensa 6601 Wlmi.
The BIOS determine the maximum size hard drive that can be installed in the laptop. Put a smaller hard drive in the laptop say 120Gb hard drive, you will lose approx 10% in the formatting process.
Use the 180GB in another laptop or put it into an USB hard drive adapter case and use it as a portable external hard drive.
Jul 18, 2009 | Acer Computers & Internet
Palsonic lcd tv will not show any images on screen, hear noise of
means you prolly have something wrong in the tv with the actual board or chip in your tv. im not fimiliar with your model but i have a panasonic viera and it wouldnt tuen on shortly after and they said i had to send it in for repair
Jun 04, 2009 | Televison & Video
DVD picture is in Black & White only.
Are you trying to play an NTSC disc in a PAL player, If so,your player has a switch or
on-screen setting to select the output format for NTSC discs,
Or maybe you have connected one of the component outputs (Y, R-Y, or B-Y) of
your DVD player to the composite input of your TV.
Please rate this solution
Jan 20, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
Black/white checker pattern on screen. Sound okay
Sounds to me that the menu is in convergence adjustment mode. Try the menu key on the remote and follow the prompts.
Oct 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Toshiba TP50G60 Big Black Square Covering the screen?
try the closed caption adjustments. i had a tv that did the same thing and the captiong did it. turn caption off nd try.
Oct 09, 2008 | Toshiba TP50G60 50" Rear Projection...
Hitachi 50 Rear Projection color TV
the easiest way is to turn the color all the way down to zero. Then notice the overall color of the screen, if it doesnt appear as a good black and white picture you will have to adjust the screens. To do that you have to remove the speaker grill cover and the small access panel, then depending on the chassis you will see a small square with 6 dials on it 3 on top and 3 on the bottom it will have screen stamped on it. adjust those 3 untill your screen appears the best black and white picture as possible. Now if your chassis only has 3 dials on the sgaure control box those are focusdont adjust them. . then the 3 CRT boards will have the dials you need adjust those for the best black and white picture. when your satisfied that you have a good black and white picture. then turn your color back up and adjust the tint.Let me know if you need more assistance.
Jun 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
62' Mitsubishi WD-62525 little black and white squares instead of picture but I have sound
Mitsubishi list this problem and has a solution of replacing several small surface mounted caps and diodes. we have tried this repair 5 times and only successfully done it once. so replacing what is called the formatter board part # 930B924002 for around $ 350.00 usually repairs this type of failure, However changing this board is a time consuming thing and takes a lot of Patience. It is buried deep in the set and several other board have to be removed just to get to it
Oct 17, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
