Question about Electrical Supplies
Can't find wheel kit
DeWalt DG2900 generator
    Problem Solver:
Hi there , if you can't find a wheel kit , you can make yourself one with wheels of an old bike for kids or something like that . That's what i did and it didn't cost me money. good luck !
Posted on Sep 21, 2008
Drill tipped over on bench and ran battery completely dead. Put battery in charger and it does not even light up. Not charging?
I would suggest getting your battery tested at one of our Factory Service Centers. Please click the link provided and search using your zip/postal code or city and state. DEWALT com
Mar 07, 2015 | Dewalt 20v Max Cordless Lithium-ion...
My Dewalt cordless drill, model DC970, is fully charged and turns. However, when I try to turn a screw, the drill does not move. What should I do?
There is a collar that controls the torque of the driver just behind the chuck. Rotate it until the drill icon lines up for full power.
Mar 05, 2015 | Dewalt 18v Cordless 1/2" Adjustable Clutch...
Why do i only have 94 volt output on dewalt generator 2900 watt
It should change with the load, the more load you put on the line the magnetic field increases with the amperage and the gen will produce more output until its rating is reached. This happens especially if it has been sitting a long time.
Aug 15, 2014 | Dewalt DG2900 Heavy Duty 2900 Watt Gas...
No engine speed change under load
Sounds like the governor is not adjusted right or is broken internally. With the engine off make sure the throttle in the carburetor is full speed and unloosen the bolt that holds the governor arm on the shaft and make sure the shaft is turned the same way the carburetor linkage moves to full speed and tighten the bolt.
Mar 26, 2014 | Dewalt Tools Generators DG2900 , 2900 Watt...
Where do I find the wheel kit assembly instructions - I cannot find them in any of the books
You have an axle, some washers, the wheel/tire assembly and a cap for the axle. Slide the axle through the frame and out the other side. place a washer on each end and the place the tire/wheel on each end of the axle. Put a washer on each end of the axle and then hammer the cap on the end of the axle to secure the wheel in place.
Aug 27, 2011 | Porter Cable 4,500 Watt 9 Hp Portable...
I have a dewalt dg2900 generator. at normal running speeds the generator is putting out 2volts ac, but if you push the governor linkage over and speed up the motor i can get it to 60 volts. is there any...
Does your motor run at the same RPMs that it did before? It sounds like your motor is running to slow to produce the 120V ac.
But it could also be that you have one or more diodes blown.
Since the generator is selling for $1,100.00 on several sites, make sure that you don't spend more for repair parts/labor than what you can replace it for.
Anything can be repaired, but some aren't economically repairable. So if you have to pay someone to work on your generator, it might be better to replace han repair.
Jul 08, 2011 | Dewalt Electrical Supplies
Generator runs but wont idle up i change gas clean carb it will try to run when i turn circuit on?
Check the carb gaskets,the fuel bowl for dirt and float needle and seat. Bad gasket can cause loos of vacum and dirt can cause the float needle and float to get stuck.
Jan 31, 2011 | Dewalt DG2900 Heavy Duty 2900 Watt Gas...
What should the gap be on the spark plug for the Dewalt DG 2900? I have lost my manual.
When you get a new SP the gap is already set for your machine.So when buy it be sure is for your specific machine
Oct 21, 2010 | Dewalt DG2900 Heavy Duty 2900 Watt Gas...
Won't start, checked spark plug, turned engine switch on, checked fuel line.
make sure unit has oil.some of them have low oil switch which will not let it run or start usually if it has triggered the low oil switch to open you have to reset it manually by pushing it in.also check that you have turned on the fuel .
Aug 22, 2010 | Dewalt DG2900 Heavy Duty 2900 Watt Gas...
Only getting 4vac output on a DG2900 generator
You need to use a Voltmeter and go right to the Output Terminals on the Generator, Disconnect anything from them, and measure that Open Circuit Voltage. If it is OK there, then the conditioning circuitry AFTER that is faulty. BE CAREFUL.
Feb 09, 2010 | Dewalt DG2900 Heavy Duty 2900 Watt Gas...
Electrical Supplies Logo
138 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
