Question about Minolta Office Equipment & Supplies
C-1139 Minolta Finisher code 75 CPM - Minolta Office Equipment & Supplies
  • Minolta Master
  • 6,359 Answers
Sir that is the fault code C-1139 what is the model of the machine and finisher?
Posted on Dec 28, 2014
Konica minolta develop 250 error code c11A0 .what is the solution plz?
sir, Check the output of the finisher, the paddles that help the paper out motor and sensor or both worse case the finisher control board recommended a tech look at it.
Mar 14, 2016 | Konica Minolta Office Equipment & Supplies
Konica minolta error code-1183
Did some one hit the output trays on the finisher or did some one leave a trash can or boxes under the finisher trays. This code means that the elevation motor assy. for the output trays need to be re-adjusted. Have to remove the rear cover of the finisher remove the motor assy. Be care that the trays don't go crashing to the bottom. Recommend a technician do this.
Apr 21, 2014 | Minolta bizhub 200 All-In-One Printer
Minolta bizhub c451 error code c- 11b0
Stapler in side the finisher is not moving correctly open the finisher a bring the stapler to replace staple cartridge position. If you can if not get a tech to look at it.
Nov 25, 2013 | Minolta Office Equipment & Supplies
How to fix error c-1183 konica-minolta bizhub 200
This code is for a bin/tray raising or lowering failure in the finisher. This can be caused by either the trays not being fully inserted into the finisher or something stropped the bins from raising or lowering. Check the trays and make sure they are as close to the finisher/fully installed as possible. Then turn off then back on the main power switch (NOT the stand by one on the control panel)
You should see the bins raising and lowering into their home position.
Aug 03, 2010 | Minolta Office Equipment & Supplies
I am assuming you have a finisher attached to the left side of the machine as this code deals with the finisher. Specifically the C1183 code means there is a problem with the elevator lift motor. Check the trays on the finisher and make sure they are fully inserted in the finisher. Turn the machine off then back on again. If the code returns you will need to contact a service company as there is a drive problem in the finisher.
Good Luck and Thank You for using Fixya.
Jun 21, 2010 | Konica Minolta Bizhub C300 All-In-One...
Malfunction Detected code C-12CB konica Minolta
Hi bellotasuelt,
I can't find any reference to that code in the Bizhub C250 Service Maunual.
Having said that, all C-11xx codes relate to the finisher/sorter.
Try opening and closing it. Have a general look in the finisher for jammed paper.
Make sure nothing is obstructing the unit from moving.
Sorry I can't be more specific.
Good luck.
Dec 28, 2009 | Konica Minolta bizhub C250 All-In-One...
Minolta Bizhub C253 - C-11C3 finisher error
The 11XX code refer to the printer and hard .To reset push the reset button or open the front door and close.
Dec 11, 2009 | Konica Minolta Office Equipment & Supplies
Service code C0B52
1. Turn off copier 2.Disconect finisher cable 3.Turn on the copier . If it works properly turn it off &reconnect finisher cable then turn it on .
Apr 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
Bizhub c350 -cobao code
finisher elevator drive error. Check the finisher tray for blockage or something under the tray. If all else fails, unplug and disconnect the finisher
Jan 20, 2009 | Office Equipment & Supplies
Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Jun 07, 2008 | Minolta bizhub 200 All-In-One Printer
649 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
