Hot water fill is weak - Washing Machines
  • 958 Answers
You can look at the back where the hot water supply is connected.
first, close the hot water valve, remove the hose and at the fitting of the washing machine, there is a stariner at the middle, it could be clogged.
if not then with the hose still attached to the hot water valve, put the hose inside the drum and open the water valve, observe the pressure of water if it is good.
if it is not, then the water source's pressure is the problem.
tnx 4 using fixya,
drcool
Posted on Sep 19, 2008
Changing washing machine heating elemant
washers dont have heating elements, they use hot water from the hot water tank, most likely clogged screen at either end of the hot water hose, replace or clean screen(s) check for screen at water valve, bad,weak or burned solenoid on water valve, replace valve, reason wash cycle is long----- water restriction during fill and rinse cycles they are controlled by the water level switch
Jul 09, 2012 | Washing Machines
Dishwasher is not error ie and not enough water in tub. I put in water manually and runs fine.
here are couple of thing to look for,always remember a dishwasher is not ground in certain parts,,,
you get error code ie if the dishwasher has not filled to normal fill in 10 min,s make sure water supply its on and open all the way,,,make sure inlet hose is not kinked,,check water pressure has
to be over 12 psi ..weak water at sink hot weak water at dishwasher,,you may have a clogged in let vavle or inlet hose screen..reminder the water is not going in dishwasher in the alotted time start there..good luck for mor help repost...
Sep 09, 2011 | LG Dishwashers
My Fisher and Paykel EcoSmart top load washing machine is slowly filling with water. Help!
I am assuming that you have already made sure that your hot and cold water taps are fully open.
If not, then check those first.
Otherwise try this.
First, turn off the hot and cold water.
Remove the hoses from the back of the machine.
Turn the machine to face you and do a visual inspection of the screens on both the hot and cold water valves.
If there are no screens, your valves may have lime and hard water deposits, or they are simply too weak to fully open. Generic, as well as OEM water valves are available on-line to replace them.
Mar 05, 2010 | Fisher and Paykel WL26CW1 Top Load Washer
Run out of hot water quick
There is a thin plastic fill pipe in every storage water heater. Its where the cold water is fed in from the top... it travels the entire height to the bottom, as hot water sits on top. There is likely a crack in that tube. It is replaceable, but it is a very big nuisance depending on the size of your tank.
If thats not it, its potentially a weak high limit. Which shuts the tank heat off and never lets the tank reach it optimal temperature.
Dec 19, 2009 | Rheem 65 GAL ELEC Water Heater 6YR Self...
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
WEAK COFFEE & NOT HOT ENOUGH
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Dec 22, 2008 | Bunn NHB Coffee Maker
The water that comes out thru the coffee gounds and into the carafe is only warm not hot.The coffee that is brewed is weak and only warm.
Sep 12, 2008 | Krups Small Appliances Espresso Machine
Coffee is weak
Check where the water comes out under the brew filter. It sounds like you may be missing the sprayhead. It is a round metal or plastic piece that is screwed on to the water dispense area and acts like a little showerhead forcing water evenly over the coffee grounds. If it is missing, the coffee will be weak. Check the water temperature. If it isn't hot enough, the coffee will be weak.
Jul 11, 2008 | Bloomfield 8571 Coffee Maker
Wet Steam? Weak Espressos
Sep 11, 2007 | Saeco Vienna SuperAutomatica Coffee...
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
