Question about Braun 8585 Electric Shaver
Braun 8585 maintenance
The trimmer tool on my 8585 does not park in its correct place and fouls the swivel head.....can any one say how to split the shaver apart??
theres 2 small screws under the cutter but removing them doesnt allow any access .....
  • mike_bran Sep 21, 2008
    Actually an 8985 but I imagine same thing, the trimmer has come out and wont click back in
    Welcome Back:
    Visited the website for 2 consecutive days.
Look at the bottom of the shaver where the AC cord plugs in. Carefully pry the small black piece of plastic out of the base. Once you have this out, the two chrome side pieces will fall off, and you can split the shaver in half to expose its inner workings.
Posted on Oct 23, 2008
I am trying to remove the pivoting head from my Braun 8585 ... removed screen and cutters and the two screws under the cutters but cannot see what else to do to get the head removed
The swivel frame can not alone be removed from the shaver. It is part of a component called a 'drive unit' which icludes the motor. You will find a disassembly video at shaveroutlet.com. See link below and scroll down for video
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-activator-motor-drive-unit-p-36.html
Mar 17, 2011 | Braun 8585 Electric Shaver
While shaving, I start into stubble and the sound (almost like the speed) ratchets up and doesn't seem to want to cut.It doesn't seem to want to get better until I approach very slowly with very light...
I would speculate that the oscillator on the swivel frame is broken making it difficult for the blade to move correctly. If tis is the case, you will need to replace it. You will find this part at shaveroutlet.com. See link below
For disassembly help, see link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
Jan 22, 2011 | Braun 8585 Electric Shaver
Shaver is getting very loud
Most likely, the swivel frame that the foil snaps onto has a broken piece(s) of plastic inside making a buzzing sound. If this is the case, you will need to replace the drive unit. You will find this part for model 8585 at shaveroutlet.com. See link below
Disassembly video can also be found at shaveroutlet.com. See link below
Jan 07, 2011 | Braun 8585 Electric Shaver
My Braun shaver trimmer is loose and does not function Can this be repaired? The trimmer has fallen out making loud noise.
These trimmers can break internally and require replacement. You will find the replcement for model 8585 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-activator-body-housing-with-trimmer-select-models-p-829.html
For installation, you will find a helpful video at the link below
Jan 04, 2011 | Braun 8585 Electric Shaver
During shaving the shaver makes a loud grating noise. It works fine otherwise. Even during the cleaning cycle, there is a bit more of that noise. Could it need a new battery?
Most likely, the noise is caused by vibration of a broken piece of plastic in the swivel fframe. If this is the case, the part required to fix it for model 8585 can be found at shaveroutlet.com. See link below
You will also find an instructional video for disassembly at the link below
Dec 09, 2010 | Braun 8585 Electric Shaver
My Braun shaver 8585 has died. Foil, cable, box, Clean and charge unit as new. Which Braun shaver replaces Braun 8585 and can utilise good pieces?
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Aug 23, 2010 | Braun 360° Complete 8985 Electric Shaver
Braun Pulsonic model 9595. Trimmer will not close properly. Can I repair this myself?
The trimmer is replaceable and can be purchased as an assembly http://buyitnow64.stores.yahoo.net/brshrese7pul.html You will T-6 and T-8 torx drivers to take apart the head end of the shaver. Using these tools, remove the swiveling head, the hold down cover over the motor assembly, and then pop off the drive arm for the trimmer. Now the broken trimmer assembly can be slid out of the end of the shaver by carefully prying between the case where the on/off button is located and the black trimmer assembly base with a small flat blade jeweler's screwdriver. The new trimmer assembly can then be slid into the case and the shaver reassembled. Just be sure the ends of the retraction spring on the new trimmer assembly are installed over the little chrome retaining lugs for them or your trimmer will not fully retract (my trimmer assembly arrived with the spring ends loose and not retained by the lugs).
Mar 29, 2010 | Braun Health & Beauty
The Charging cord's head that fits into the Shaver is broken. How get I get a replacement?
I have several new power charging cords for this model. If you want one Please let me know and will give you a good price.
Nov 13, 2009 | Braun 8585 Electric Shaver
Braun 8585 Electric Shaver Logo
291 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
