Question about HP Color LaserJet 2600n Printer
HP 2600N LASER PRINTER
This printer will not print out Magenta we have tried remans and original cartridges.
Please help
  • kabduljawad Oct 06, 2008
    We have the same problem and have tried replacing the hp magenta toner with no luck.
  • mblaine03 Nov 03, 2008
    I am having the same problem with 6 of these printers. None of them will print magenta. Other colors print fine.
  • 186 Answers
Are you using HP brand toners?
Posted on Sep 26, 2008
    Scholar:
  • 73 Answers
You can try going into your print settings/preferences and checking magenta only. printers you need to keep a watchful eye on your ink levels, because if you are out of ink, you can not print in ANY color, even black.
If the above thing not works You can begin by making sure you are not using anything above 24-bit colour (RGB) in Word.
Also: Word does not use a colour profile. It doesn't make any changes to
the colour, so it doesn't compensate at all. The only colour profile
between Word and the printer is your Printer's colour profile.
Hope this helps
Posted on Sep 19, 2008
I have an HP Color LaserJet 2600n. Recently I had to replace the magenta cartridge. I bought a 3rd-party cartridge and the printer display shows that magenta is now "full." But, it won't...
I guess you should try to reset it ..and get the cartridge out and see if the toner (ink ) is getting out ..by pressing it (with the part where you removed the tape ) on some absorbent paper ..when it is working well it should leave a mark on the paper ..the mark should be not washed ...but real color and all...
If it do not ..just use a syringe and blow air in the cartridge ..just to agitate it ..and make sure it is not dry ..
Insert it back ..repeat the procedure until works ..and also if you have the procedure ..reset it ..
http://www.ehow.com/how_6881778_reset-2600n-toner-chip.html
Aug 09, 2011 | HP Color LaserJet 2600n Printer
Magenta toner is not printing.
Problems with a single cartridge not printing are usually traceable to either a faulty cartridge or a bad laser scanner unit. Try a different cartridge if you have one. Are you getting any error codes?
Jul 20, 2011 | HP Color LaserJet 2600n Printer
Color is offset and blurred. There is no problem printing in black. Printing test page shows the same symptoms.
Hello
The color of HP LJ 2600n fades due to following reasons
1. the color cartridge near to empty 2. due to dust on reflection mirrors inside the printer
if the color cartridges are OK, then you need help of HP technician support, because cleaning of mirrors is very technical in nature for 2600n.
Dusty Environments can lead to Laser Scanner Contamination. The dust layer on the mirrors prevents proper transmission of the laser output in the imaging system leading to faded colors on the printed page. The initial stages of this failure typically occur in the magenta or yellow color planes as faded or light color. Often the left side is more faded than the middle.
You may need to contact the nearest Authorized Service Tech and get teh Laser Scanner replaced with the new released service part that has a mirror in a location where the dust ideally cannot reach easily.
Also, please ensure that the printer is relocated from the current location to a more dust free zone.
Hope this helps, if so do rate the solution
Jan 08, 2011 | HP Color LaserJet 2600n Printer
I am using the HP Laser Jet 2600n and I only use the black ink, I have it set up that way, for financial reasons. Why is it not letting me print? It is saying that my magenta is out, and will NOT let...
First of all, for financial reasons you don't use a color printer. Unless you print graphs.
Second of all, this is a laser printer, it doesn't use ink.
Third, all four toner cartridges must be inserted and working in order to print in any color.
Go back and read the "First of all" again and buy a B and W laser printer.
Dec 07, 2010 | HP Color LaserJet 2600n Printer
MY HP ''COLOR LASER JET 2600n'' HAS FUOLL INK CARTRIDGES BUT THE PRINTING IS REALLY DULL AND FADED LOOKING. CAN ANYONE HELP? TERRY M.
This is a common problem with this model of printer. The scanner optic degenration is due to dust buildup on mirrors and lenses. Since the most vulnerable mirror reflects its laser beam to the magenta toner cartridge, red tones are the first to show fading. Colours shift: purples turn blue and oranges turn yellow. The printer will need to be cleaned by a certified HP technician to resolve this issue as it means dismantling your printer to fix the problem.
May 30, 2010 | HP Color LaserJet 2600n Printer
Magenta colour is very light
fist of all chack print out with useing new cartridge . if prolem not get fix than ...
that fault due to scaner problem .
u have to change scaner printer.
Apr 28, 2009 | HP Color LaserJet 2600n Printer
Hp 2600n error 51.22 magenta cartridge, says turn on and off, hel
51.22 is a Magenta laser scanner error.
Try removing the magenta restarting the printer and reinstalling.
If that does not work you likely need a laser assm.
You might want to call a tech. to replace.
Apr 01, 2009 | HP Color LaserJet 2600n Printer
Magenta covers entire page
I had a similar problem. See: http://www.fixya.com/PostQuestionTx.aspx?prdid=378544&ctgid=0&thid=1044936&type=2
Are you your replacement cartridge orignial HP?
I also had your problem on my previous HP printer (don't remember the model #). And I had it cleaned a couple of times, replaced the magenta cartridge (but with remanufactured), and could not get rid of the magenta. I gave up and bought a new 2600n, but now I wonder if I had used original HP parts if the problem would have been solved.
Sep 13, 2008 | HP Color LaserJet 2600n Printer
Every page covered in magenta and black won't print across the page
This is caused by toner contamination in the laser scanner unit, it is quite a complex job removing and cleaning the laser scanner. I would suggest you contact HP regarding the repair.
Sep 04, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
181 people viewed this question
Ben Johnson
