2008 Smart fortwo Logo
Anonymous Posted on Sep 28, 2011
I think a mouse chewed my wiring harness three bars flashing on dash! I am in need of a wiring diagram for a 2008 pure.. Thanks, Cliff....
SPEEDY CAR WORK SHOP
Level 2:
  • Smart Expert 489 Answers
  • Posted on Oct 22, 2013
Smart Expert
Level 2:
Answers
489
Questions
Helped
159848
Points
671
Let me know which diargam you need exactly
2 Related Answers
Anonymous
  • 33 Answers
  • Posted on Mar 23, 2009
SOURCE: need wiring diagram for 2008 ford crown victoria
You can purchase the wiring diagram for $5.99 from the following site: http://www.wiring-diagram.com/. You can also purchase a wiring diagram book from the following link: http://cgi.ebay.com/ebaymotors/2008-FORD-CROWN-VICTORIA-MARQUIS-WIRING-DIAGRAM-MANUAL_W0QQitemZ120394723100QQcmdZViewItemQQimsxZ20090320?IMSfp=TL090320147007r15080.
Hope this helps,
Chris
Anonymous
  • 869 Answers
  • Posted on Jan 06, 2011
SOURCE: 2008 GMC C5500 factory wired for trailer harness
well i suggest you check the manual of ur gmc sierra to get the exact wiring diagram and there only u'll get port to plug into.
Battery goes dead overnight and clicking noise behind dash when moving acc. fuse
Chances are you have a short behind the dash. The clicking might be wires arching off metal or other wires. may have been pulled from a harness or maybe a mouse chewed on it. Unfortunatly, open the dash and look.
My 94 sl500 dash lights and door lights start flashing when I turn on either blinker
Hmm sounds like the classic mouse has had a chew of the cables ,also some of these older cars wiring looms have dodgy plastic insulation which goes all sort of soft and dissolves on its own ,their is a short somewhere but where ?? is the big dollar question ,where to look ? start at the rear of the vehicle in the boot and check the wiring loom although if dash and interior lights then i would suspect behind the dash ,might be cheaper to buy a new car iam sorry to say
2answers
2008 GMC C5500 factory wired for trailer harness (7 pin). I just purchased brake controller and am trying to find where the controller harness plugs into the truck harness. Looking under the dash. Plug...
You are probably going to find four wires together that do not have a plug on them. There should also be a tag taped on the wires showing that it is for the trailer. You will have to put a plug or some kind of connection on those wires.
1helpful
1999 ford windstar speedometer not working keeps blowing fuse to speedometer. Thanks!
Check the wire harnesses on top of the transmission for any signs of open plastic casing. You may of had a mouse or some other critter chew their way through some wire insulation which is causing a short to ground,,,, or a short to power. If any are found, spice wires back together ( same colour wires ) and try speedo again.
2answers
DOG CHEWED WIRING HARNESS BETWEEN CAB AND REAREND NOW CANNOT SWITCH BETWEEN FRONT AND REAR FUEL TANKS NEED WIRING DIAGRAM TO TROUBLE SHOOT
If the harness was in a straight line ( no wires going a different direction ) you should be able to re-connect them by the colours of the wiring. Buy yourself some new wire and black tape.
# 1 injector not firing
Well you need to check the harness to see if it is getting power. You may need to take the plentum off and then unplug the harness and then reinstall the plentum but make sure that you leave the harness out so you have access to it.
Then you can make a test light or purchase one. Plug the test light into the harness and start the car. This light should flicker, if not you didn't repair the wire properly. Doesn't sound like a fuse being that none of the injectors would work if a fuse blew.
It could also be that the PCM grounded out when the mouse chewed the wire and needs to be replaced.
Don't worry about checking the ASD Relay because that would cut off all power to the injectors and coils.
Top Smart Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Are you a Smart Expert? Answer questions, earn points and help others
